Old Mar 05, 2012, 02:27 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Making a mould for fibreglass
For several years now I've been making moulds to make fibreglass components for various parts of my aircraft. I make them out of balsa usually, then after rough sanding them I apply car body filler and sand until smooth. I then apply a spray coat of car body primer paint, but then the problems start. The grain of the wood swells, so I have to then go over the sanding process again, then more primer, then more sanding, until I get tired of it and apply a coat of finishing paint. The resulting fibreglass part, or mould, still shows signs of wood grain, but I then sand these out.
But now I'm doing a more ambitious mould -- the complete 40"-long fuselage for an F16 -- and I'd like to have a grain-free result first time round. This mould is balsa infill between sections which have been cut from 3mm liteply. Filling and sanding is progressing well, and I'm now trying to figure what's the best way to finish it off. Is there any particular material that would (a) minimise the amount of swelling and (b) harden any exposed wood so that, once sanded down, it won't swell again with the second coat? Instead of automotive paint, I've been wondering if polyester finishing resin, or water-based polyurethane paint, would be good.
I've already experimented on a small separate piece applying release wax direct to the wood/filler mould surface, and then pva release agent, but the pva swelled the wood.
abenn is offline Find More Posts by abenn
Old Mar 05, 2012, 03:58 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
two things you can try, if you haven't already tried :
proposal 1 : apply a wood sealer. I don't know the right english term, but is a thing "like a paint" that is used to fill the pores of the wood before painting it. You can find it on every shop that sell paints.
proposal 2 : apply a coat or two of slow cure epoxy resin on the whole surface, then sand it smooth. You obtain a sealed wood surface.
FlyDave is offline Find More Posts by FlyDave
Old Mar 05, 2012, 04:16 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If possible I prefer to use foam for any fiber glassing work, mainly because I have had similar problems using balsa, especially where the end grain comes to the surface.
I use a very 'fine grain' blue foam for the plugs, it sands quite well. I then use a matt ceiling emulsion as a 'sealer' and as a good sandable primer. Any water based product tend to make balsa even more 'hairy'.
The - Composites Fabrication forum - is very good for finding what others have used.
I have never tried a full fuselage, good luck with the project. Thread ?
eflightray is offline Find More Posts by eflightray
Old Mar 05, 2012, 05:00 AM
abenn is offline
Joined Jul 2004
I've got a thread going here http://www.rcgroups.com/forums/showthread.php?t=1559345, eflightray.
And thanks for the link to the Composites Fabrication forum -- I hadn't realised it was there as a separate topic.
Where do you get blue foam from, and how do you define your sections without using ply (or similar) slices?
FlyDave, I think my primer is what you'd call a sealer though, admittedly, it's not designed for wood. I'll try some wood primer on a sample and see how that goes.
Old Mar 05, 2012, 07:01 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
My better quality blue foam, (which I have recently run out of), was called 'Floormate'. It came in 2" thick, and something like 8ft x 2ft sheets.
I bought mine from a builders insulation stockists back in Coventry.
I never made anything as big as fuselage, but see no reason why you couldn't use temporary thin other material for a former for any hot wire cutting, in smaller sections where possible. Then discard the former and butt join the sections together for final shaping and sanding.
I did make some 'reverse profile' formers once, (the remaining material after the former has been cut out), for checking the outside shape of a section. But then I still tend to treat 'scale' as "it looks about right", rather than keeping to accurate profiles.
Old Mar 05, 2012, 07:34 AM
abenn is offline
Joined Jul 2004
Thanks. I'm not planning to be super scale, but "looks about right" including details such as gun ports and other various bulges is what I want -- and no wood grain.
Anyway, this afternoon I'm going to make up a balsa/liteply test block and try some wood primer, some wbpu, and some finishing resin on it.
Old Mar 05, 2012, 07:42 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I usually coat the plug with epoxy or polyester resin (on wood only, not foam ), sometimes over tissue, then sand that for a good clean surface. I also prefer to make plugs from softwood or foam rather than balsa as either of those have better surfaces in the first place.
I started using resin because I always had some around on account of that's what I'll be using for the layup. But I've sometimes used out-of-date resin for the plug that I wouldn't really trust for the main layup .
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 05, 2012, 02:38 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Be careful if you plan to use wbpu directly on wood because the water will swell the balsa and you risk to ruin the plug.
This is a product you can find on UK, to fill the pores before the finish :
http://www.tooled-up.com/Product.asp...ferrer=froogle
(surely you can find many other similar product, but as i don't live on uk i cannot find the right term)
Old Mar 06, 2012, 02:22 PM
abenn is offline
Joined Jul 2004
Test results!
OK, I've done a quick and basic test. A sandwich of balsa and liteply, sanded smooth, then a layer of auto body filler applied and sanded down, then three strips of different "paints" -- water-based polyurethane, water based wood primer/undercoat, and polyester finishing resin. After leaving it overnight for the resin to harden, I then sanded it smooth using my Permagrit fine sander, then a 3M "180 Fine" sanding block. Lastly I gave it a quick spray coat of auto primer paint, and sanded that with my 3M block.
My initial observation is that none of the paints had caused any significant swelling of the balsa -- probably because there was an extremely thin layer of body filler covering most of the surface. Secondly, the resin cured with "dimples" in its surface, and was so hard that sanding it completely smooth was a chore that I'd rather avoid. My opinion is that the wood primer/undercoat paint was the best solution -- it was easy to sand smooth and, after a second coat and sanding, took a thin spray coat of auto primer which sanded down to what I think is a very good finish.
I'm still not sure if I need a finishing coat on top of the primer before I start applying mould-release wax. I'll try a few coats of wax straight onto the grey primer, and see if the pva release agent then causes any grain to show. I'm guessing it's a case of having to put on many more coats of wax than I usually do (one!), so that it will be impervious to whatever goes on top.
Old Mar 14, 2012, 05:58 AM
abenn is offline
Joined Jul 2004
Originally Posted by eflightray View Post
My better quality blue foam, (which I have recently run out of), was called 'Floormate'. It came in 2" thick, and something like 8ft x 2ft sheets. ....
Any idea if Jablite http://www.diy.com/nav/build/insulat...T-50mm-9273749 is equivalent? It seems to be the most readily available one in small quantities -- I've seen Floormate for sale at 82 for a pack of eight sheets, but B&Q do Jablite much cheaper, and single sheets.
Old Mar 14, 2012, 08:41 AM
Staffs, UK
Joined Nov 2003
If that's the stuff I'm thinking of it's a lightweight open-cell expanded polystyrene (EPS) foam and almost impossible to get a decent finish on.
The good stuff is closed-cell extruded polystyrene (XPS) foam. If you need some relatively small bits I've got a fair amount of 80mm Floormate I deliberately over-ordered when I was insulating my garage/workshop (drop me a PM). Alternatively you can buy it from Balsamart in smallish amounts for a lot less than 82 quid http://balsamart.co.uk/store/index.p...roducts_id=428
Steve
Old Mar 14, 2012, 12:31 PM
abenn is offline
Joined Jul 2004
Thanks for the info, and the offer, Steve. I didn't know the terms EPS and XPS but, now that I do, I'm better equipped to search for the right thing next time I go to B&Q. According to a thread on another site http://www.modelflying.co.uk/forums/...s.asp?th=49615, they stock some kind of XPS.
Old Mar 14, 2012, 01:05 PM
EINA is offline
Find More Posts by EINA
South - Africa
Joined Nov 2007
I use PU foam, carve and sand easy, apply grey primer, sand apply again, sand polish, release lay up.
EINA is offline Find More Posts by EINA
Old Mar 15, 2012, 07:33 PM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
I've been making plugs from balsa for vac forming canopies and I've always managed to get a good finish.
Firstly I try to get the best surface I can from the bare balsa, finishing with 400 grit paper.
Dents or joints are filled with dope/talcum mix and sanded back.
Then I give it a coat of dope to seal it.
Then I spray it with high build automotive primer. It needs a few coats to fill the grain. Then I sand it smooth.
On a small part I will use dope/talcum mix spread on with a knife in lieu of the spray primer.
Scaledown is offline Find More Posts by Scaledown
Old Mar 15, 2012, 08:08 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Best way to seal a wooden plug in order for it to last... FIBERGLASS IT!
No point in being cheap in not putting a layer or 1 or 2oz glass cloth over the plug to give a nice dent resistant surface, that will Also seal it to keep it from any moisture from ever reaching the wood and causing it to shrink or swell.
invertmast is offline Find More Posts by invertmast
Discussion A quick mould making lesson from my son steve wenban Australia 30 Sep 13, 2006 11:12 PM
Mould-making questions?? spitfirem9 Slope 8 Feb 05, 2006 11:53 PM
Making a mould(mold)... types, methods... pkrska Composites Fabrication 8 Jan 21, 2006 04:01 AM
Female mould making.Anyone tried silicone with a catalyst added? bipeflyer Electric Ducted Fan Jet Talk 18 Aug 08, 2003 12:16 AM
