Old Mar 05, 2012, 12:46 AM
X30PILOT is online now
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
Build Log
Giant scale X-2 project!
In honor of Jean Skip Ziegler, Lt. Colonel Frank K. "Pete" Everest, Capt. Iven C. Kincheloe, and Capt. Milburn G "Mel" Apt I have decided to build a 1/5th scale X-2. This model will be powered with a high K to a low M.
I am planning on flying this at Balls in September, but I may have it ready for LDRS in July.
X30
X30PILOT is online now Find More Posts by X30PILOT
Old Mar 05, 2012, 01:08 AM
X30PILOT's Avatar
Joined Aug 2007
Here are some of the CAD drawings for the model, and the drawings showing the fuselage structure.
X30
Old Mar 05, 2012, 08:30 PM
X30PILOT's Avatar
Joined Aug 2007
These photos show some of the laser cut parts and the right fuselage side I built this past weekend.
X30
Old Mar 05, 2012, 10:34 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
Looks good, what are your balast plans and what do you think your AUW will be?
Frank
burkefj is offline Find More Posts by burkefj
Old Mar 05, 2012, 11:07 PM
X30PILOT's Avatar
Joined Aug 2007
Hi Frank,
Right now Im estimating it to weigh around 30 pounds without the motor.
Ill calculate the C/G envelope and see if I can stay within limits during the motor burn. This worked well on my ME-163 and X-30 projects.
X30
Old Mar 06, 2012, 09:18 AM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
I hope that works out, looks like you are going with a full flying tail, that will probably help allow a somewhat larger trim for range for post boost CG as well. My smaller X2(which has no fuse area and flat plate wing) lives with a 3.2%(relative to fuse length, forget what the wing chord is) CG shift without issue.
looking forward to the progress.
Frank
Originally Posted by X30PILOT View Post
Hi Frank,
Right now I’m estimating it to weigh around 30 pounds without the motor.
I’ll calculate the C/G envelope and see if I can stay within limits during the motor burn. This worked well on my ME-163 and X-30 projects.
X30
Old Mar 06, 2012, 10:44 AM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
+1
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Mar 08, 2012, 08:57 AM
joelkirsh is offline
Find More Posts by joelkirsh
United States, TX, Dallas
Joined Dec 2008
looks great cant wait to see it
joelkirsh is offline Find More Posts by joelkirsh
Old Mar 10, 2012, 11:25 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Even on a low M you are going to be pushing Mach 1. You'll be over 10:1 at liftoff with the smallest on M's, the AT M1297, at ~450lbf initial thrust. I'm assuming a 75mm motor tube? Very cool project indeed. I need to get back to Blackrock, the east coast is like the black hole of real high power rocketry.
scatsob is offline Find More Posts by scatsob
Old Mar 10, 2012, 10:39 PM
X30PILOT's Avatar
Joined Aug 2007
Yes its a 3-inch mount. Right now my guess is that the first flight would be on an L. Once its complete and I have a final empty weight I can do the math and see if I can tolerate the C/G change with bigger motors.
If I do go with an M Id use something with a gentler ride, like an AT M650, Hypertek M740 or a Loki M900.
X30
Old Mar 11, 2012, 07:13 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Even that M650 packs quite a punch. It pushed my little 3" Tomahawk to 25,000ft. Even at 30lb it seems the K560 would be needed to keep it visible for the flight back. This project poses some unique challenges.
Cal poly did something similar for a reusable booster project. They had big models and had to use M1939's so to get the CG in front of the CP they put water in the nose. When the model arched over the water fell out and the CG moved forward for flight.
Old Mar 11, 2012, 10:31 PM
X30PILOT's Avatar
Joined Aug 2007
Nice!
Im planning to fly a 3in rocket on an M1400 at Balls as well.
As you know drag is a big issue. My 7 1/2 in Nike Smoke went to 6415 on an M1315 at 47 pounds loaded. The X2 is almost 11inches in diameter; Ill have to see what the final weight of this thing is prior to committing to a motor. I have considered the water ballast idea before and it is a good one. I have managed to fly a 10 foot long X30 and a 5 foot wingspan Me163 by just be working within the allowable C/G envelope. If I can do that with the X-2 I will, otherwise Ill go the water route.
X30
Old Mar 11, 2012, 11:40 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
Man you are killing me. I really want to go to Balls this year but I don’t think my work schedule will allow it. It probably won’t be until 2013 or 2014 before I make it back to the playa. What rocket are you flying the M1400 in? I love minimum Diameter rockets; they are all I fly now. I am addicted to speed and altitude. My current project is a 4" that I am going to try and break the N-class altitude record with on a CTI N5800. My dad and I are also working on a 102mm minimum diameter rocket that will fly on one of Frank Kosdon's (RIP) O6000 motors. It will be a fitting tribute flight for Frank. We are hoping to get around 60k ft. at a little over Mach 4.
Sorry for getting off topic, I don’t get to talk rockets much anymore. I'm an aeronautical engineer stuck in a civil engineers career .
Old Mar 12, 2012, 07:10 PM
X30PILOT's Avatar
Joined Aug 2007
Here are a few photos from this past weekend.
They show the addition of the forward left fuselage and the installation of the motor tube.
X30
Old Mar 12, 2012, 09:18 PM
X30PILOT's Avatar
Joined Aug 2007
Sorry for getting off topic.
No problem, it certainly sounds like youre doing some really cool stuff! This will be my first trip to Balls, something that I have wanted to do for years. Im still finalizing my design for the 3in rocket. I got the motor case and the altimeters. I have plenty of time to get this done but the X2 is going to take some time.
I just couldnt go out to Black Rock without punching a hole in the sky, hopefully not the playa.
X30
For Sale Giant scale planes p-51 Cactusflyer Aircraft - Fuel - Airplanes (FS/W) 3 May 14, 2013 04:11 PM
Sold Top Flite Giant Scale Corsair receiver ready LPU TFOA Aircraft - Fuel - Airplanes (FS/W) 6 Feb 27, 2012 04:13 PM
Sold Giant Scale Landing Gear w/Wheels and Pants! Nogahyde Aircraft - Fuel - Airplanes (FS/W) 2 Feb 24, 2012 03:19 PM
Sold Giant Scale Landing Gear w/Wheels and Pants! Nogahyde Aircraft - General - Miscellaneous (FS/W) 0 Feb 23, 2012 02:58 PM
For Sale 2 Hitec HS700BB Giant scale Servos $24 shipped! HD Hucker Aircraft - General - Radio Equipment (FS/W) 0 Jan 22, 2012 12:32 PM
