Old Mar 04, 2012, 11:13 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Mini-HowTo
How to make a good ground station
I see a whole lot of tech on here, but not much on ground stations. Ground stations are generally more important than what is on the airplane. Here is a quick guide on how to make a good ground station:
#1. Consider your goals - This might seem simple, but not a whole lot of people put much thought into this step. If your goal is to fly within a mile, complex diversity and tracker schemes are pointless. However if you plane to do long range with no pre-flight planning, you might consider a tracker.
#2. Follow Occam's Razor (keep it simple) - The simpler the ground station, The less the setup time. Less complexity also makes it more fun to use.
#3. Try to keep it as compact as possible. You will be lugging this around. Keep it easy to transport.
#4. Make it stable. If the wind knocks over your station, you will be in trouble in a real hurry. People walking around tend to touch things as well. They'll knock it over just as fast as a wind gust.
#5. Consider your flight areas - If you fly with other pilots or in a multitude of areas, it might be a good idea to be capable of multiple bands so you can choose your frequency.
#6. Consider a ground recording device for any flight exceeding 1km. While you might have no use for a ground recording when flying, what about when you wreck or need to ditch the plane. The ground recording allows you to locate the plane and is more reliable than any RTH device. The little LCD screen is also a great emergency backup if your goggle battery goes dead on you.
#7. Consider powering everything from a single battery and monitor the voltage. Voltmeters are cheap and give you a good idea of how much battery power is remaining.
#8. Lock your cables. Use tape or velcro to keep your cables from pulling out of your goggles. If you pull your cable from your goggles, you are going to crash.
That said, I will show a few ground stations of various complexities for different goals.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 04, 2012, 11:18 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Near field station
For near field flying, nothing beats an all-in-one head mounted ground station.
FatShark and FOXTECH make All-In-One goggles. Quick ad easy. Good for flying inside 2km.
However, you can always make your own as well. Trimersion headsets are pretty good. You can also mount your RX to a hard hat with a flip down goggle or use a welding helmet with the screen cut out and the RX mounted to the helmet.
These stations do really well with circularly polarized antennas with gain less than 8dbic. The only restriction is the size of the antenna you are willing to mount on your head. 1.3GHz directional antennas are huge with CP. 5.8GHz is very small, though. With lower frequencies, you might consider CP omni antennas such as the BluBeams or TrueWired systems or a linear system with a 3 or 4 element Yagi. With higher frequencies (ie 5.8GHz) a 3 turn helical rules with a CP omni on the aircraft.
-Alex
Old Mar 04, 2012, 11:27 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Stand alone directional antenna
For moderate range with minimal planning, nothing beats a low gain directional antenna on a tripod. Simple. Nothing complex. You can even mount a recorder and/or a voltmeter to the back of the directional antenna.
If you fly multiple bands, you can incorporate them all into one complete ground station. In my case, this ground station covers 1.3 and 2.4GHz which uses a small 5.8GHz transmitter to "repeat" the signal back to a set of FatShark goggles. However, I can always hard wire into the VRX with wired goggles, too.
Dual band station features:
-Dual band (1.3GHz/2.4GHz). Changing frequencies requires moving 2 plugs to another RX.
-Voltmeter with an on/off switch.
-Built in recorder which is powered from the ground station battery.
-5.8GHz repeater. Transmits to a set of FatShark goggles. It is completely wireless.
Dual band station capabilities:
6 miles within a 75 degree beam in front / 4 miles in front within a 120 degree beam.
1 mile to the sides
2000 feet behind
2500 feet through buildings and hills or 1.5 miles through trees within a 90 degree beam.
3 minute set up time.
Old Mar 04, 2012, 11:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Simple Diversity station
This illustrates a really simple diversity station. An omni for close range and a moderate directional antenna for more distance. You can also use two directional antennas for broader coverage out in front of you. Generally these are restricted to single band, but cover the greatest flight area.
When considering diversity, figure where you intend to fly. If you only fly out in front of you most of the time, two directional antennas is going to be better. If you fly behind yourself, an omni antenna and a directional antenna work better.
The good thing about diversity is that it is so easy to setup. The problem is that the ground station becomes larger and more cumbersome and certain diversity systems do not play well with circular polarization.
Capabilities of omni/directional:
- 1 to 2 miles (2 to 3 km) in all directions
- 3 to 4 miles out in front (90 degree beam)
Capabilities of dual directional
- 3 to 4 miles anywhere out in front (180 degree beam)
- 1000 or so feet from the rear
Features:
- Minimal set up time
- Little or no planning required before flight
-Alex
Old Mar 04, 2012, 11:42 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Tracking station
The tracking station is the coolest FPV gadget out there. Generally the rely on a GPS feedback to aim a directional antenna for you. These are fairly pricey and take time to set up, but they offer long range without any real prior planning. The downside of these is you need the OEM's OSD on board and will need a GPS lock. An AAT (auto antenna tracker) automatically sets itself where others need to be aimed manually.
However, the real treat with tracking is not long range. The real advantage is being able to fly behind objects with impunity. Use of a higher gain directional antenna and a tracker lets you drop behind objects with rock solid video. Mind you, you risk control loss of your airplane if you do this at too great a distance.
Capabilities:
- Up to 10 miles reliably in any direction with no planning
-Alex
Old Mar 05, 2012, 12:21 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
What not to do
While there are many correct ways to build a decent ground station, there are many ways to do it wrong as well.
Tracking and diversity
This is a disaster waiting to happen and is a huge expense. If you think you need tracking and diversity, chances are you have not flown yet. Consider a single directional antenna on a tripod.
Dual omni antenna diversity
Occasionally I see a dual omni antenna diversity system. While this does work for WiFi, it doesn't work well for FPV. Diversity systems do not make a dual omni any more reliable. It actually makes it less reliable.
High gain antenna aimed straight up
This station is rare, thankfully, but every once in a while, one pops up. If you want to make an altitude attempt, the best thing to do is get out in front of yourself a bit and climb that way. Climbing straight up above you should be limited to 100 meters and at that height, you don't need a high gain antenna. An omni will do.
High gain antenna and a multicopter
This is getting very common. While this can be utilized to punch through solid objects allowing you to duck behind hills and buildings, it is often used for LOS operations. Helicopters are not long range vehicles and excet for cases where you intend to violate the Fresnel zone, anything more than 8 dbi is excessive.
-Alex
Old Mar 05, 2012, 01:06 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
Nice one IBCrazy I certainly agree with #3. I swear groundstations are getting bigger and bigger these days and I also see most that have the entire grounstation in a case when most of the time all of it would fit inside a backpack quite easily.
#4 is definatly something rcexplorer would agree with. Ive seen some videos of his tricopter flying over niagra falls and his groundstation nearly fell down.
malcr001 is offline Find More Posts by malcr001
Old Mar 12, 2012, 03:50 AM
Moelich73 is offline
Find More Posts by Moelich73
Bazinga!
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
Excellent info, thanks!
I couldn't help but notice that there seems to be a windsock on a pole stuck to your head!
Moelich73 is offline Find More Posts by Moelich73
Old Mar 12, 2012, 04:19 AM
slarys is offline
Find More Posts by slarys
The Netherlands
Joined Jul 2011
WTB your ground station...!!! Those helicals look awesome...
slarys is offline Find More Posts by slarys
Old Mar 12, 2012, 04:52 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
I actually made a second one yesterday... my primary is the Skylark AAT which I LOVE...
I made another for grins..... it's a patch with a RX and a battery velcro'd to the back. Thats it.
It doesn't get any easier than that.
Blue Chip is offline Find More Posts by Blue Chip
Old Mar 12, 2012, 08:12 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
My first ever ground station was just that! I set it on the trunk of my car. I could set the whole thing up before my OSD got GPS lock.
-Alex
Old Mar 13, 2012, 06:30 PM
k6821340 is offline
Find More Posts by k6821340
Joined May 2007
Hi dude,
Im newby.
I am wondering if I can not use both tracking and diversity?
thanks
k6821340 is offline Find More Posts by k6821340
Old Mar 13, 2012, 06:47 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Anybody try a tracking system with pan only? maybe with a 3,4 turn helical?
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Mar 15, 2012, 02:47 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by k6821340 View Post
Hi dude,
Im newby.
thanks
Bad idea! Read the thread. Seriously. So many newbies "want it all" then end up gaining experience and shelving 70% of what they bought.
You are new. Your ground station should consist of 4 items:
1. Viewing screen
2. Video receiver
3. Single RX antenna with gain no more than 8 dbi
4. Battery
-Alex
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I did one of those with a BiQuad once. I didn't fly it much as I hated the complexity of a tracker.
-Alex
Discussion Looking for cheapest Vtx and rx for ground station... jsxx FPV Talk 11 Feb 26, 2012 11:53 AM
Sold EagleTree Eagle Eyes Ground station NEW Ifly101 FPV Equipment (FS/W) 1 Feb 24, 2012 07:34 PM
Wanted WTB - DVR for ground station JBeloncik FPV Equipment (FS/W) 0 Feb 24, 2012 10:30 AM
Sold BEST GROUND STATION DVR EVER...PERIOD! Make an Offer RChelisrule FPV Equipment (FS/W) 25 Jan 09, 2012 11:31 AM
Discussion Is this Ground Station any good?? cougar2465 FPV Talk 2 Dec 14, 2011 04:18 AM
