Old Mar 04, 2012, 10:20 PM
bigfoot216 is offline
Find More Posts by bigfoot216
United States, MI, Davison
Joined Feb 2012
cheapest wild hawk motor upgrade help!
I have ready many other threads on here and can't find an answer.
I am looking to get more power for my $60 wild hawk and I don't want to spend more than the plane cost. I'm not really sure how. Do I need a Brushless motor and ESC or is there a more powerful motor that I can buy and just swap out for the original?
bigfoot216 is offline Find More Posts by bigfoot216
Old Mar 04, 2012, 10:58 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
HobbyKing has the best deals on motors.
Just figure out what your motor weighs and how much thrust it puts out, then buy something not much heavier, but more powerful.
Maybe something to run on 3 or 4 cells, but with your size prop.
You can also search the WildHawk threads to see what others have done.
Butch777 is offline Find More Posts by Butch777
Old Mar 05, 2012, 08:36 AM
startazz is offline
Find More Posts by startazz
RC plane addict ;-)
startazz's Avatar
United Kingdom, England, Norwich
Joined Aug 2008
Yep i'd agree with Butch777 and say your best bet is with Hobbyking.com and if you do a google search you might even find the right HK motor to fit it because i bet there is a few out there that have used there motors for the Wild Hawk.
If not find out what size motor you have and go over to Hk and find a close match for it,when you think you have the motor you want check out the comments under the motor you like and see if anyone else has used that motor on your WH and see what they say about it.
Thats what i use to do for my warbirds and it worked out well.
startazz is offline Find More Posts by startazz
Old Mar 05, 2012, 10:07 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
The Exceed Wildhawk /Super Lightning come with a brushed 480 motor, which is a 28mm motor can. If you want a direct replacement for the stock motor, you need a 28mm inrunner brushless motor and a 30A brushless ESC. Also, you need to decide how many cells Lipo you want to run, either 2S or 3S. If you want to run 2S, best KV motor is between 2700-2800 kv, whereas, if you want to use 3S packs, you want a motor between 1900-2200kv. I run all my EZ style planes on 2S 2200mah and they have ample power for brisk climbouts and aerobatics, for good power-off soaring performance, as these types of planes are gliders after all. Assuming you are in the US. Here is a good US source for a 28mm 2700kv inrunner for 2S use:
http://leaderhobby.com/product.asp?I...85&Location=LA
You will also need a 3.17mm adapter, and APC 6x4E prop for this setup.
Doubletap is offline Find More Posts by Doubletap
Old Mar 05, 2012, 12:12 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
A really great on-line vendor is www.headsuprc.com
Jeff can advise you as to exactly what you need. His prices are very fair.
I've placed over 20 orders with no problems. $2 three day shipping.
lindart is offline Find More Posts by lindart
Old Mar 05, 2012, 06:23 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
I'll second that. Recently got a 1100 watt setup for an 8 pound plane from him..flies great and got it for really cheap compared to other places.
Endlesslag is offline Find More Posts by Endlesslag
Help! Wild Hawk motor rotation? flashbang Parkflyers 3 Dec 11, 2011 07:50 AM
Discussion Wild Hawk motor/lipo upgrade plan? flashbang Electric Plane Talk 1 Dec 04, 2011 06:58 PM
Help! Harbor Freight Wild Hawk LIPO upgrade? flashbang Electric Plane Talk 7 Dec 02, 2011 06:05 PM
Sold Wild Hawk 3ch tx/rx, brushed ESC, motor, 2 servos and wings cardnation Aircraft - General - Radio Equipment (FS/W) 3 Nov 02, 2011 11:35 AM
Help! what do i need for wild hawk upgrade? joshuablume Electric Plane Talk 11 Jun 13, 2010 08:56 PM
