Old Mar 04, 2012, 05:06 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
100" Pusher Glider with Twin Booms A-tail
Glider with Pusher motor project.
How long shall the the Twin booms be compared to the wings?
Is there a certain percentage when measuring compared to wing span(ie...100").?
This plane is not mine, but I may want to re-create it with the help of someone.
http://www.rcgroups.com/forums/showthread.php?t=1148980
I would use the main canopy and wings only on these:
http://www.hobbyking.com/hobbyking/s...102in_ARF.html
http://www.hobbyking.com/hobbyking/s...9_6in_ARF.html
Thank you.....
rclab1 is offline Find More Posts by rclab1
Old Mar 04, 2012, 07:00 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
I'd go with the ASW, looks like it has more room for stuff. I'd use carbon golf shafts off ebay for the booms. That's a cool idea to lop off the fuselage and add a pusher. I'd use photographs to get the decalage.
As for your question about ratios of wing span to tail moment, use the full scale as a guide. Find a 3 view of the full size, since those HK models are scale, and determine wing area/tail area ratio and length. If you shorten the tail distance, then increase the tail area. Do a search of this site for tail moment formulas and V tails, anything by Dr. Drela or Don Stockhouse is good info.
HELModels is offline Find More Posts by HELModels
Old Mar 05, 2012, 04:22 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Be very careful with large hand launched pushers.
Luckily the scars across the back of my hand have now faded
eflightray is online now Find More Posts by eflightray
Old Mar 06, 2012, 03:33 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
That looks like the SR Batteries free flight e-version.. I wanted to make an RC Version.. looks like someone did it already..
For 10 bucks. .buy it and you'll have a fully fucntional prototype to scale up...
http://srbatteries.com/x70.htm
Thermalin is offline Find More Posts by Thermalin
Old Mar 06, 2012, 05:43 PM
rclab1 is offline
USA
Joined May 2010
Thermalin,
Thanks for the post, but I want to make a;
1. VeryHigh performance OverPowered Glider....
2. able to Glide very well (long flightimes power 'off'),...
3. must be 'fast' (thinner wings) during the glide,
4. and over powered brushless motor just for fun (strong wings).....
HELModels,
thanks for the input up above:-)
I'm just throwing ideas here
This is a scratch build using another plane so my hopes are high
...again, this is for fun and experimentation and if it works out well, it would be worth it
Sold DLG carbon fibre tail booms [HM carbon] DLGjunkyard Aircraft - Sailplanes (FS/W) 3 Feb 28, 2012 04:39 PM
Found mcpx tail motors with wire no booms, charge adaptors, hyperions that fit stock tray. CorgiCowPockets - xxDExx Aircraft - Electric - Helis (FS/W) 0 Jan 15, 2012 05:27 PM
Sold NitroPlanes Honda Jet Twin Pusher ARF- $100.00 + actual shipping Bajora Aircraft - Electric - Jets (FS/W) 7 Nov 05, 2009 10:08 AM
For Sale German Easy Riser 100" twin boom pusher {not sold} Ron Cate Aircraft - Sailplanes (FS/W) 0 Nov 21, 2007 07:47 AM
For Sale German Easy Riser 100" electric pusher twin boom Ron Cate Aircraft - Sailplanes (FS/W) 0 Nov 11, 2007 11:09 AM
