Old Mar 04, 2012, 02:23 PM
R0yalty is offline
Find More Posts by R0yalty
Joined Feb 2012
First LiPo plane, need some help connecting
Hi,
I just received my first LiPo plane (Dynam Spitfire 1200mm).
The battery connector in the plane looks like this:
The battery that came with looks like this:
All clear so fat.
I also separately ordered a balance charger:
It has the following adapter for balance connectors:
And the following connectors:
I also ordered a couple of extra batteries, but unfortunately with a different connectors thats on the plane:
So I have a couple of questions.
1. As the charger did not include any cordings for the type of connector I have on the dynamo battery that came with the plane, how do I charge it using this charger. Can I use the cord in the middle on the picture above, where I simply connect the T-connector to the charger and "snap" on the other ends on the battery? Or would that be not safe?
2. As you can see, the balance connectors on the batteries look a bit different. The plug it self looks the same, but the colors of the cords are different, can both be connected to the lower right socket on the screen above?
3. How would I go about to connect the batteries with the T-connections to the plane, are there any adapters?
R0yalty is offline Find More Posts by R0yalty
Old Mar 04, 2012, 07:11 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Yes
Yes
If you be careful, yes
If they fit in the board they are right no matter what color the wires are. Most likely the red or the black wire is in the same place.
You may need to either buy an adapter or change a plug somewhere so everything is the same.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Discussion ULTRA 16 receiver diversity Need some help? sky cam FPV Talk 2 Mar 06, 2012 01:28 AM
Discussion Need Some Help...Which heli? 3D-flyer-93 Beginner Training Area (Heli-Electric) 4 Mar 04, 2012 08:31 AM
Discussion Need some help with my power system copperbricks Power Systems 1 Mar 03, 2012 10:20 AM
Discussion Need Some Help DLC Vintage & Old-Timer Designs 6 Feb 26, 2012 01:56 PM
Help! Ok guys need some help picking my first plane stafphoto Electric Plane Talk 19 Oct 20, 2006 11:34 AM
