Old Mar 04, 2012, 02:41 PM
Vishnuasalways is offline
Find More Posts by Vishnuasalways
Joined Mar 2012
Help!
Powerplant requirements for Quadrotor
Hey I am planning to Design and Develop a Quadrotor. So I need some formulas and calculations that might help me to choose the optimum powerplant requirements for the vehicle. For example lets say the Quadrotor is confined within a 1kilogram weight inclusive of all the components (frame, motors, payload,etc..). So how do i theoretically find out the optimum RPM required and the optimum Propeller dimensions and also an optimum battery to support the flight.
THANKS IN ADVANCE
Vishnuasalways is offline Find More Posts by Vishnuasalways
Old Mar 04, 2012, 08:04 PM
Helno is online now
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
This site does exactly what you need.
http://ecalc.ch/xcoptercalc_e.htm?ecalc
Helno is online now Find More Posts by Helno
Old Mar 06, 2012, 03:16 AM
Joined Mar 2012
Thank you very much it was a great help. But it would be more helpful if you can elaborate the steps or formulas based on which the calculator actually works.
Old Mar 06, 2012, 08:26 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
http://www.rcgroups.com/multi-rotor-helis-659/
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Mar 09, 2012, 02:01 AM
Joined Mar 2012
I have selected these for my quadrotor can you take a look and let me if they are good? This small help from you gurus can help me a lot.
MOTOR:
http://www.hobbyking.com/hobbyking/s...dProduct=21480
BATTERY:
http://www.hobbyking.com/hobbyking/s...dProduct=11956
ESC:
http://www.hobbyking.com/hobbyking/s...ontroller.html
PROP:
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
THANKS IN ADVANCE
Old Mar 12, 2012, 01:08 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
MOTOR:
BATTERY:
ESC:
PROP:
THANKS IN ADVANCE
motor 84grams x4 = 336grams
lipo = 457grams
esc x4 = 112grams
905 grams
no wire to connect everything
no servo leads
no flight controller
no frame
if your really good? might be able to make a frame for 200grams
so the very lightest you can possibly make your quad? 1.1kg
see the problems yet?
those props will snap like twigs
those props and motors together will be hard pushed to give enough thrust to fly
if you can make a 200gram frame it might just fold like a pretzil when you try to lift off at 1.1kg your build with everything will probably be more like 1.3kg
it will not fly!
read this and start again!
link fixed '
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Mar 12, 2012, 03:23 PM
Joined Mar 2012
Why wont it fly ?? the overall weight is only 1.3 kg (max).. the 6x5 propellers with WOT on a 1800Kv motor provides a thrust of 732g of thrust so for quad it is 732 x 4 = 2928g... so why wont this fly??
"those props will snap like twigs"
I am sorry I don't understand why will it break?? please care to explain??
Thanks in advance
Old Mar 12, 2012, 05:41 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Those plastic slowfly props will not take the 16000+rpm required to get 732g thrust. They will flutter, and the blades probably will snap off.
Besides, a prop with high pitch to diameter ratio is very inefficient at producing static thrust. You would get much better performance with a lower Kv motor (eg. Turnigy Park450-890) and larger diameter lower pitch prop (eg. APC 10x4.7).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Mar 13, 2012, 12:26 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Hi,
Go for a lower KV motor. Something around the 900 to 1,000 KV range.
Props of around 10inches * 4.5 inches will work well with this range of motor on a quad.
Most use slow fly style props or GWS 3 bladed props, although these take a lot of balancing.
The 5,000 mAh battery will be heavy. 2200 mAh would probably be sufficient - unless you need long flight times.
The ESC you chose may not work well - some ESC's don't work well with multirotors, I think this may be one of those that give problems. Try the Hobby King SS ESC's. These are cheap, many people use them and they are known to work well.
Lower KV motors give better response for multirotor craft. I use E-Power 2215/25 motors and SS 25 - 30 Amp ESC's on my quads. These weigh around 1 kg or so without camera and lipo.
You will get more advice here http://www.rcgroups.com/multi-rotor-helis-659/
I use the multiwii controllers, which I build myself, and you will see there is a VERY large thread on these. The first page (of many) is here
http://www.rcgroups.com/forums/showthread.php?t=1261382
sparklet is offline Find More Posts by sparklet
Old Mar 13, 2012, 02:00 PM
Joined Mar 2012
Thank you for your replies.. But i still have a problem.... I have designed and fabricated by quadrotor frame using carbon rods the overall dimension is 500mm x 500mm ( app 19" x 19") so can a quadrotor of this size support the propeller dia of 10 x 4.7?? wont the vorticity of the propellers affect each other?? If not can i make a 7 x 4 prop and a 1200 kv motor??
THANKS IN ADVANCE
Old Mar 13, 2012, 02:20 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
You'll also need two reverse-rotation props to cancel torque effects.
Piece is offline Find More Posts by Piece
Old Mar 14, 2012, 02:41 PM
sparklet is offline
Cumbria in the U.K
THANKS IN ADVANCE
No problem.
A lot of quads are built with 15 inch arms and use 10 * 4.5 props.
It's advised to allow the diameter of a propeller between propellers.... 10 inch props would have a distance of 10 inches between the prop blades when the tips were facing towards each other. That's just a rough guide.
Quads are built with less clearance than this and seem to fly well. Longer arms of 15 inches and above tend to be best for a quad that is going to be used for photography.
Arms of 15 inches length give good stability without having flex problems. Try the 19 inch arms and see how it flies. If necessary you could always cut them shorter after you have tested it.
The links I posted have lots of information, more than you will get here.
Discussion Sig 600 Battery Requirements NEW222 Power Systems 6 Mar 01, 2012 05:37 PM
Discussion Powerplant question for all you Foamy gurus... Balloon Man Sam Foamies (Scratchbuilt) 4 Feb 22, 2012 10:12 AM
Discussion Recommendation for specific requirements bluesk1d Batteries and Chargers 13 Jan 11, 2012 08:43 PM
Question requirements for a mac glenbees Simulators 9 Jan 05, 2012 04:02 PM
Discussion Looking for a 300 g or less quadrotor mitscientist Multirotor Talk 2 Oct 11, 2011 11:40 AM
