Old Apr 19, 2012, 11:17 PM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Hey Norm, they're $399USD each
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Apr 21, 2012, 01:17 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Here's my rudderless install on the Neos with a JR285. Lottttssaa room to play with!
Easily installs 3x JR285 in the pod.
Old Apr 21, 2012, 02:29 PM
hohensej is online now
Find More Posts by hohensej
United States, SC, Mt Pleasant
Joined Nov 2003
Thomas,
With the servo set like that, how do you connect the string for pull spring setup?
hohensej is online now Find More Posts by hohensej
Old Apr 21, 2012, 11:53 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
James,
The included 'middle' wire is for making the 2 hooks on each end of the pull string. I just use the 2 hooks to connect to the control and servo horns.
Old Apr 22, 2012, 09:11 AM
robust is offline
Find More Posts by robust
Beginner
Shenzhen , China
Joined Feb 2008
I'd really like all servos in the fuse. 3x JR285 could installed inside neos' fuse would be great!
robust is offline Find More Posts by robust
Old Apr 22, 2012, 09:14 PM
Art_Boy is offline
Find More Posts by Art_Boy
Veradale, WA
Joined Jun 2007
Slowly making progress. After getting out the yard stick (er meter stick) and a slide rule, I determined that the distance between the stab leading edge and the front bolt was 5mm. Hard points were made as Thomas showed earlier. Also got the "spring" installed along with the control horn. It seemed a tad too long so some was trimmed off the base (plus roughened up) prior to epoxing in.
Also got the "holes" for the wing servos made (plenty of room for the Airtronics 802 servos) plus the channel for the top drive wire. Made some "relief" cutouts in the root for the wing bolts hard points (hard to tell in the picture). Wing panels were epoxied together (currently drying).
Checked the wing leading edge with templates and it is pretty close. Looked sharp but not used to the thin airfoil. Will "polish" up the leading edges later.
A pretty fast build (just need to find the time to work on it). Using West Systems slow epoxy so that needs some time to cure.
Thomas, what kind of foam did you use? Does not look like the usual stuff I have used. Also, would like to see how you attached the wire to the string for the elevator.
Thanks for all the pictures since helps with the build.
Art
Art_Boy is offline Find More Posts by Art_Boy
Old Apr 22, 2012, 10:54 PM
ThermalThief is offline
Find More Posts by ThermalThief
Do it AGAIN! This time BETTER!
ThermalThief's Avatar
WA
Joined Jan 2005
Art,
I would suggest the hardpoint extend to both sets of carbon rods. The carbon rod ends need to be held apart at the center joint. You may need to plug the wire channel with piece of foam until the epoxy kicks.
Sorry you missed some incredible thermals at the field today.
Ken
ThermalThief is offline Find More Posts by ThermalThief
Old Apr 23, 2012, 05:30 AM
Joined Nov 2003
Dudes,
Sorry I have been slackin on pictures, but I have been busy building!
Wings are joined and re-enforced, tail is mounted, wing servos are installed. Only thing is i'll have to to re-install the servos, looks like things were not set up right when i first installed the horns. A little wierd because i KNOW i checked prior to gluing them in. Oh well!
Things to do, Fuse wire harness, battery pack, install horn and spring for elevator, and fix ailerons. Then peg and we will be ready to go! Should be do able by the end of the week!
James
Old Apr 24, 2012, 04:37 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Robust, I'll be doing that for my next 3 planes I'm building for myself. You saw those new special fuselages
Art, Looks good so far! I agree with Ken, I would tie the hardpoint into both the front and back spars as well. Minimal weight increase, but much stronger joint.
The foam is a XPS foam, the cell structure is quite different than the other ones we tried and the strength along the Z-axis is very good.
I'll take a photo of my string/hooks in a couple mins and upload it.
James, can't wait to hear back on how it flies!
Old Apr 24, 2012, 05:47 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
my pull string setup
I crimp the string with aluminum tubing and pliers, and just put a drop of CA to fix it.
Old Apr 24, 2012, 05:50 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
even more new toys!
lots of planes to ship out when I get back to Hong Kong, can you guys guess which fuselages are mine?
Old Apr 24, 2012, 09:58 PM
tailsld is online now
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Not sure Thomas but the second, third and fourth from the right are mine!
<evil grin>... got your Neo tails on my super topsky 2 allready for a nice day to maiden.
Rick
tailsld is online now Find More Posts by tailsld
Old Apr 25, 2012, 04:44 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
Looking at getting 2 of the newest layup's ? Any carbon dbox or full carbon wings yet. . Pm me any news please. Kane
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Apr 25, 2012, 08:55 AM
Joined Nov 2003
The main structural building is completed. Only items left are radio/electrical. Looking good for this weekend but the Mom-in-Law is coming into town. Hopefully that does not slow the process up too much.
James
Old Apr 25, 2012, 11:42 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Rick, for the right amount of $$$$.... Haha, let me know how you like those tails! Those things are stiff!
Kane, the carbon's on it's way to Hong Kong, but I'm still in Canada on vacation until the 7th. We're looking at the first Dbox kits rolling out around early June. I'll PM you in a sec.
James, maybe you can interest her to help you film! Hohhooho
New Product GO -> fly DLG - ArmSoar Composite Gliders ThomasLee Hand Launch 583 Today 12:28 AM
Discussion Vibe - ArmSoar Composite Gliders ThomasLee Hand Launch 1519 Yesterday 11:00 PM
Discussion Arctus - ArmSoar Composite Gliders ThomasLee Hand Launch 123 May 27, 2016 02:12 AM
News ArmSoar Composite Gliders GO DLG Jason Cole Hand Launch 6 Jul 04, 2015 10:32 PM
Sold Armsoar Kevlar Neos DLG NorCal Hobbies Aircraft - Sailplanes (FS/W) 3 Jun 10, 2012 11:58 PM
