Old Mar 13, 2012, 09:55 AM
ThomasLee is offline
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Just for fun, I tried to snap a flaperon horn today with my hands and couldn't break it.
ThomasLee is offline Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Mar 13, 2012, 11:42 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Joined Apr 2010
Try freezing it first
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Mar 13, 2012, 11:52 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Never gets below freezing here Already wearing shorts!
Old Mar 14, 2012, 12:22 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Some photos of the servo installation last night.
As you can see the bolt hole is too close to the front spar. We will be moving both spars slightly forward so that the bolt hole will go between them and let the hardpoint tie everything together. That will also mean that the servos can be placed in an even thicker part of the wing.
The remaining things I need to do:
-install blade
-connect elevator to servo
-solder wing servo connections
Fingers crossed to get it to maiden tomorrow morning before work!
Old Mar 14, 2012, 11:56 AM
robust is offline
Find More Posts by robust
Beginner
Shenzhen , China
Joined Feb 2008
Thomas, what servo you used with your flapron?
robust is offline Find More Posts by robust
Old Mar 14, 2012, 12:09 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Tahmazo TS-D6011, down to my last couple sets....
Very good servos, basically the same as the Hyperions
Old Mar 14, 2012, 01:25 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Done!
Maiden when I wake up in a couple hours
I have set the CG a bit rearward on this one @ 73mm, will see how well it flies with that CG.
Old Mar 14, 2012, 06:02 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
These look great. What was your AUW for these.
davidjensen is offline Find More Posts by davidjensen
Old Mar 14, 2012, 07:13 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Thanks Dave,
The Shift is 291 grams, and the Neos is 270 grams.
Shift is just below 22dm^2 of wing area, and the Neos is just above 22dm^2. Very floaty when needed
The Neos actually came out a bit heavier than I want with the new tailset. We will pull a bit more resin from the tails and save a couple grams overall.
Can probably save another few grams from the wings. I'm expecting production AUWs to be about 265grams.
Old Mar 14, 2012, 10:10 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Okay, back from my morning flying session with my Neos and Shift planes.
Man! Those things are light in the air
The Neos is very forgiving, and is doing everything it was designed to do, as with previous iterations of the model. Drop the nose a little and it will speed up, but the thing I like more is how much it likes camber... I am currently using 5mm for my float mode and it just goes on and on. CG is at 73mm, I am going to try it at 75mm tomorrow morning and see how it works.
I was able to catch 4 5~6 minute thermal rides with it at 8:30 in the morning... and the slightly wider tips, slightly forward swept wings, and washout combo allows it to turn very very tightly without tip-stalling, which allows it to work very small and light lift.
One of the flights I was coming back, and at the half-tree height I felt a bump and tried to take it up. Bank angle was 50degrees +/- with a radius of 4 meters or so... took it up for one of those 5~6 minutes flights. Don't think I could have done that with the other planes in my stable (maybe the FW5).
Enough hyping for today There are several changes we will be doing to the production wing. We will extend the flaperons to 1 inch from the tips and forego the trileron setup. We will also cut the flaperons like 'normal', and instead post a tutorial on how to post-bagging preface it with our tape method if you wish to do that. We think the tape method is great, but some of the guys I've spoken to didn't like the way it looks, and didn't like using tape hinges (especially on a wing that's already kevlar!).
We will also extend the reinforcements on the tips for another 2cm because on the current configuration it still doesn't give the feel I am looking for.
Old Mar 16, 2012, 11:53 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Here's a short video we took this morning before work, sorry about the image quality! I had it set to 640 x 480 and forgot to change it back to 1980 x 1080...next week, I promise
Neos DLG (3 min 53 sec)
Old Mar 18, 2012, 01:40 AM
Airbud is offline
Find More Posts by Airbud
Airbud's Avatar
Canada, BC
Joined Jan 2010
Launches nice. floats nice. Looks nice. Are you bringing any home for the Home Boys to try out. I am in.
Wayne.
Airbud is offline Find More Posts by Airbud
Old Mar 18, 2012, 08:26 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Hey Wayne, thanks for the compliments!
I'll be bringing a few new sets to Vancouver but they're all accounted for by the Washington guys and a buddy from Brazil. I probably won't be able to finish anymore than that before I leave for Vancouver.
You can check out the prototype that I will be flying and I can ship you guys some kits if you want
Thomas
Old Mar 19, 2012, 08:23 PM
tailsld is online now
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Thomas
Looking awesome...travel safe
Rick
tailsld is online now Find More Posts by tailsld
Old Mar 21, 2012, 12:54 AM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Thanks Rick
Got some more fuselages ready, hardware packages half-done, just waiting for some surfaces and the first few kits will go out the door early next week
And something in HD
Neos DLG HD (4 min 42 sec)
Discussion Vibe - ArmSoar Composite Gliders ThomasLee Hand Launch 1341 Today 09:08 AM
New Product GO -> fly DLG - ArmSoar Composite Gliders ThomasLee Hand Launch 529 Yesterday 10:15 AM
Discussion Arctus - ArmSoar Composite Gliders ThomasLee Hand Launch 56 Oct 18, 2015 04:56 PM
News ArmSoar Composite Gliders GO DLG Jason Cole Hand Launch 6 Jul 04, 2015 11:32 PM
Sold Armsoar Kevlar Neos DLG NorCal Hobbies Aircraft - Sailplanes (FS/W) 3 Jun 11, 2012 12:58 AM
