Old Mar 11, 2012, 06:32 AM
robust is offline
Find More Posts by robust
Beginner
Shenzhen , China
Joined Feb 2008
wow! shining VT
robust is offline Find More Posts by robust
Old Mar 11, 2012, 09:30 AM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
And the weight is very good too Robust
Here's a list of the weights of the main parts:
Fuse: 41.67g
Vertical: 7.58g
Horizontal: 7.6g
Wing: 113.94g
Total: 170.79 grams
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Mar 11, 2012, 08:00 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Got the vertical set up sans the glass on either side, and got the horizontal tapped for the screws and control horn installed.
Pics as soon as I get in the office
Old Mar 11, 2012, 09:03 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Some photos of what I did last night.
I cut the vertical to the shape of the boom, and notched the boom a couple mm to go over the forward carbon spar on the vertical. I then wrapped the end of the notch with some kevlar thread and CA just to be safe.
I can see it taking shape!
Old Mar 11, 2012, 09:40 PM
Waymon is offline
Find More Posts by Waymon
中国, 广东省, 深圳
Joined Jun 2011
Great! Finaly!
How I wish to see them be flying...
Waymon is offline Find More Posts by Waymon
Old Mar 11, 2012, 10:04 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
hey come to hk next weekend to see it fly!
Old Mar 11, 2012, 10:15 PM
SOARenity is offline
Find More Posts by SOARenity
United States, PA, Columbia
Joined Jan 2009
Thomas,
In the picture of the stab, what is that control horn made of & what are you using to glue it?
By the way, nice pix & nice plane.
Tom R.
SOARenity is offline Find More Posts by SOARenity
Old Mar 11, 2012, 10:45 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Hi Tom,
The horn is made of 2.0mm PMMA, laser cut.
It is glued with 3hr epoxy and microballoons.
Thanks!
Thomas
Old Mar 11, 2012, 11:05 PM
Nick Milligan is offline
Find More Posts by Nick Milligan
SOARda involved
Canada, BC, Kamloops
Joined Jul 2009
Hi Thomas,
Can you give a reason to use a PMMA as a horn material over something fiber reinforced?
I have always know plexiglass and other poly carbonates to be quite brittle and easily fractured. The plexi I work with is used for commercial store fixtures and signage.
Nick
Nick Milligan is offline Find More Posts by Nick Milligan
Old Mar 11, 2012, 11:11 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Hi Nick,
Main reason is because we don't have access to a cnc to cut CF boards at the moment, and laser does not cut through CF or FG boards. However, I have been using some 1mm horns of the same material and haven't seen one fail yet. These are 2mm, and I doubt it will fail before the servo arm fails (although that's not as brittle...).
Thomas
Old Mar 11, 2012, 11:23 PM
SOARda involved
Joined Jul 2009
Thank you for the clarification Thomas.
I imagine the forces on an elevator control horn are quite small without any real shock loads (In flight ). I wonder if PMMA is what CDs are made of...
Old Mar 11, 2012, 11:25 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
..besides, they don't have drag since you can't really see it
Waymon is offline
中国, 广东省, 深圳
Joined Jun 2011
Yes, i think that a bit easily fractured horn even can keep the sevor plastic gear savely.
Old Mar 12, 2012, 07:45 AM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
G10 can be laser cut with the proper laser.
samc99us is offline Find More Posts by samc99us
Old Mar 12, 2012, 08:59 PM
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Didn't get a heck of a whole lot done last night.
Applied FG cloth on both sides of the vertical and boom connection. I know common practice is to only use foam-safe on XPS foam, but I have a habit of using just regular super-thin CA to stick the cloth to this connection. Key is to get it to kick before it soaks into the XPS by rubbing it with a small piece of plastic, works everytime and super quick.
I would probably just use foam-safe if you have that laying around, but I don't and I'm cheap
I also installed the spring on the horizontal last night. Used 5-min epoxy to glue in 2 small lengths of toothpicks for the wire to stick into. Strong and clean.
In case you missed this earlier, the plane is rudderless, and comes with the vertical uncut. If you do build rudderless, you will need about 12 grams of noseweight.
However, I designed the vertical so you can cut a hinge at 60% of the chord, just don't cut through both kevlar skins.
If you place a second JR 285 in the nose for the vertical, you will end up only needing a couple grams of noseweight. At least, with my equipment that's the case.
-I'm actually tempted to fit all 3 of my servos in the pod and do something like the FW5... maybe in a few months when I have more toy to play with Yes... that's how roomy the nose is
Sam, thanks for the info, I will take a look into it.
Discussion Vibe - ArmSoar Composite Gliders ThomasLee Hand Launch 1515 Today 08:47 AM
Discussion Arctus - ArmSoar Composite Gliders ThomasLee Hand Launch 123 Today 02:12 AM
New Product GO -> fly DLG - ArmSoar Composite Gliders ThomasLee Hand Launch 581 Apr 14, 2016 09:02 PM
News ArmSoar Composite Gliders GO DLG Jason Cole Hand Launch 6 Jul 04, 2015 10:32 PM
Sold Armsoar Kevlar Neos DLG NorCal Hobbies Aircraft - Sailplanes (FS/W) 3 Jun 10, 2012 11:58 PM
