Old Mar 04, 2012, 11:01 AM
daveay is offline
Find More Posts by daveay
Joined Jun 2006
Help!
No throttle control for EFlight Park280
Hello All
I have recently purchased a Park 280, a 10 amp ESC, and a new Spektrum DX6i. I believe I have the 2s 800 mah battery charged and everything connected correctly (ESC in the throttle port, battery polarity, etc). Everything seems to cycle throught the power up correctly.
The problem is, when I begin to advance the throttle, the motor spins up very quickly for 2-3 seconds then drops to a very low idle for another 2-3 seconds and then shuts off as if the battery were too low and cuts off the drive power (like a BEC).  This happens wheather or not I move the throttle lever to any setting and it doesn't control any of the motor speed, however the motor will stop if I return the throttle to zero.  When I do return the throttle to zero I can immediately repeat the same problem again. The rest of the controls still work while this is going on.
So, I am not sure if this is motor, radio, esc, or battery issue.  Any help will be appreciated.
Thanks, Dave
daveay is offline Find More Posts by daveay
Old Mar 04, 2012, 11:12 AM
Challenger 413 is online now
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Sounds like LVC to me. Have you checked the battery voltage while doing the motor run up?
Challenger413
Challenger 413 is online now Find More Posts by Challenger 413
Old Mar 04, 2012, 02:21 PM
buracho topspin is offline
Find More Posts by buracho topspin
Joined Feb 2012
I agree, it sounds like the ESC is set for 3S low voltage cutoff, about 9 volts. It needs to be set for 2S or around 6 volts.
buracho topspin is offline Find More Posts by buracho topspin
Reply With Quote  (Disabled)
Old Mar 04, 2012, 03:44 PM
daveay is offline
Joined Jun 2006
Thanks, I will try to reprogram the ESC for 2S.
Old Mar 04, 2012, 10:14 PM
daveay is offline
Joined Jun 2006
That did it! All is running fine now. Thanks again for your help.
Dave
Old Mar 05, 2012, 05:41 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
those little eflite speedo's all come set to 3s and they do not have auto detect.
MANY people have run into this issue over the years.
cryhavoc38 is offline Find More Posts by cryhavoc38
New Product Tactic TTX600 2.4GHz radio (TWIN THROTTLE CONTROL) 6789boat Scale Boats 10 Nov 10, 2014 12:48 PM
Question No throttle control with Orange Rx 610 receiver DCAirlines1 Power Systems 19 May 01, 2012 11:01 AM
Question No throttle control with A9 as student NefariousRC Hitec/Multiplex USA 3 Sep 21, 2011 07:22 PM
Throttle control with no ESC. pc_pilot Parkflyers 18 Feb 22, 2003 01:54 AM
Motor cuts on automatically...no throttle control austinflyer Power Systems 1 Jan 17, 2003 05:45 PM
