Old Mar 04, 2012, 08:48 AM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Swift Coast Guard thread
Does anyone know where the manual is for this fuselage?
Greybird is offline Find More Posts by Greybird
Old Mar 04, 2012, 11:54 AM
VictorN is offline
Find More Posts by VictorN
Hawaiian Shores, Big Island, HI
Joined Jul 2006
Attached is all I've ever found.
VictorN is offline Find More Posts by VictorN
Old Mar 04, 2012, 05:09 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Thanks.
Old Mar 05, 2012, 07:02 AM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Does anyone know how many amps a Swift will pull in scale type flying with a fuselage? The motor is Z30-800, 9 tooth pinion. It will have 550 blades on 6S.
Old Mar 05, 2012, 08:18 AM
McXtreme is offline
Find More Posts by McXtreme
McXtreme
ChicagoLand, Romeoville
Joined Feb 2008
I own the fuselage and thats all i have found on it also. I have not started my build yet.
McXtreme is offline Find More Posts by McXtreme
Old Mar 05, 2012, 02:00 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
The amperage will depend a lot on the rotor speed you set for. Two calculate that I would need to know what size battery packs you plan to use with it.
With a 6S pack and your 800KV motor using the 9T pinion, and with your ESC set at 100%, you will get a pretty low rotor speed of about 1500. (fine for scale flying).
At that rotor speed you will be needing about 450 watts.
But to do a better calculation, we really would need to know how many celled battery you plan to use.
rotoraddict is offline Find More Posts by rotoraddict
Old Mar 05, 2012, 07:57 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
6 cell batteries. Where do you get 450amps? I think a Swift 16 on 6 cell 800KV with 10 tooth only uses 30 amps in hover.(read that somewhere) I might have to get a data logger or something to figure it out. I have a CCHV 45amp controller I want to use if possible.
Old Mar 05, 2012, 09:40 PM
Joined Jul 2008
Sorry, I meant watts...I have edited my post.
I have also have now had a chance to check my Eagle Tree readout graphs from my 5S powered A109/Swift and its average watt requirement for a flight was 511 watts with an average amp draw of 30 amps. It uses the 530mm grey FunKey blades from Century and set for a 1750 head speed.
Old Mar 06, 2012, 06:03 AM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Thanks rotoraddict. Hmmm. What do you think of a CC45HV for this heli? They are actully rated for 60 amp spikes. I have 3 of these (2 in Swifts) and they have never even been warm on landing. Maybe I should change ths thread to Coast Guard scale. Mant people seem to have them...
Old Mar 06, 2012, 07:07 AM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
I got the landing gear working. Watched the wheels go up and down many times. Pretty cool. rotoraddict, did you re-enforce, the glued joints? I was thinking of making a bead of epoxy around some of the wood parts. Might just be un-needed weight though.... What do you think?
Old Mar 06, 2012, 12:09 PM
Joined Jul 2008
Sounds like your CCHV45 might be OK when using the lower rotor speeds we use for scale flying, as I have used the Century 55A one on the A109A.
I loved the retracts. My 14MZ radio has a servo speed adjustment so I set the servos that operate the retracts for a slower speed.
As for the glue reinforcements, I think that is a good idea though I did not do it on mine and it all seemed to take some of my harder landings in the following video pretty well. I do not think the extra weight would be all that significant as the Swift handles the scale weight very well.
Here is a video of mine doing multiple take offs & landings. It shows the retract operation very well:
Scale RC Coast Guard A109A (4 min 10 sec)
Old Mar 06, 2012, 08:11 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Is the Swift inside all plastic except for the tail assembly? Has that video been around awhile? That might be the video that inspired me to buy mine...
Old Mar 06, 2012, 08:17 PM
GyroMan is offline
Find More Posts by GyroMan
Joined Apr 2009
Those are much the same as I have found with mine on 5S (515 watts) and a friend, using 4S packs at around 1450 for rotor speed, reads 458 watts.
P.S. Thanks for the great video. Do you have more?
GyroMan is offline Find More Posts by GyroMan
Old Mar 07, 2012, 01:52 PM
Joined Jul 2008
Yes, that is the stock Swift 16 with the metal gearbox at the back to facilitate installation.
I understand that the current stock Swift NX gearbox is a plastic version of this metal one so it may be used also.
Yes, that video has been out for awhile as are others on that same youtube site.
Old Mar 07, 2012, 09:28 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
I got the heli programmed and ready to fly. Need to strap on a battery and balance it. If it flys OK, without vibration, it goes in the fuselage. It has been very windy here..
Found Agusta 109A (Coast Guard) Swift Scale Fuselage Part# CN4027CGSW GOOBERSEPTEMBER Aircraft - Electric - Helis (FS/W) 0 Mar 31, 2011 03:52 PM
Sold Century AGUSTA 109A 30 size FUSELAGE (COAST GUARD) - Swift on Ebay Hoverup Aircraft - Electric - Helis (FS/W) 0 Apr 01, 2010 04:24 PM
Sold NIB Coast Guard Prepainted Swift fuse laughingstill Aircraft - Electric - Helis (FS/W) 2 Feb 10, 2009 07:34 PM
Discussion Century Swift with Coast Guard 109A scale fuse Heli Pic Scale Helicopters 17 Oct 09, 2008 04:25 PM
Cool Century Swift in Agusta 109 Coast Guard rotorsport Large Electric Helis 48 Sep 14, 2008 10:22 AM
