Old Mar 04, 2012, 06:32 AM
RcLento is offline
Find More Posts by RcLento
Joined Jul 2011
Amazing !! A model cricri that takes offf,flies and lands that slow
http://www.youtube.com/watch?v=PKfYv...ature=youtu.be
RcLento is offline Find More Posts by RcLento
Old Mar 04, 2012, 08:10 AM
abieex is offline
Find More Posts by abieex
abieex's Avatar
United States, OH, Cuyahoga Falls
Joined Oct 2011
Amazing!!! How big is that thing? Motors? Very nice job!
abieex is offline Find More Posts by abieex
Old Mar 04, 2012, 10:46 AM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
There is another video in the motor threads. Call me a skeptic, but I dont believe what I am seeing. IMO, either it is slowed way down or it's fake. There is no way that little amount of wing loading can fly that slow. With a lot of speed maybe, but I dont think the wing has the lift to fly that big of a model that slow. Here is the other one.
http://www.rcgroups.com/forums/showt...5#post20934230
After further discussion, I agree in the other post that it has to be filled with helium or some other lighter than air, inert, gas. That would explain the big fuse.
Byrdman is offline Find More Posts by Byrdman
Old Mar 04, 2012, 12:26 PM
RcLento is offline
Joined Jul 2011
Byrdman;
lets say its slowed something i dont understand that in normal how can it fly in that small place ! If it flies normal speed and everything is normal its not possible ! it should fly slow that kind of big plane in this kind of small place isnt it ?
Old Mar 04, 2012, 01:01 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
2.4 M Christen Eagle indoor (3 min 20 sec)
The Cri Cri probably has a much lighter wing loading since the Eagle is running a 6s pack.
Azarr
Azarr is offline Find More Posts by Azarr
Old Mar 04, 2012, 01:08 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
This is pretty slow for an 8ft span B-17, flown indoors.
Slow flight is all about weight, the lack of it.
8-Foot B-17 RC Model Indoors (2 min 48 sec)
eflightray is offline Find More Posts by eflightray
Old Mar 05, 2012, 03:26 PM
how much is offline
Find More Posts by how much
how much's Avatar
United Kingdom, England, Wigan
Joined Jul 2011
"Helium"
the cri-cri's huge bubble canopy is actually a huge helium filled balloon and the rest of the fuselage my well have other helium balloons enclosed
so a very very lightly built model reduces its weight by half
a mix of differential throttle (its a twin) and there you you have it.. a very nice guided balloon!
simple
David
how much is offline Find More Posts by how much
Old Mar 06, 2012, 11:16 AM
beerbrewer is offline
Find More Posts by beerbrewer
Microbiology at it's best.
beerbrewer's Avatar
Waverly, Nebr.
Joined Apr 2009
Take a look at the bottom of the fuse. It is a lifting body like the space shuttle. The surface area is massive, possible greater than the wing. You can also see the tail section "wiggle" so it is built extremely light. Even if it was filled with helium, that volume is so small it would have little effect on the weight.
beerbrewer is offline Find More Posts by beerbrewer
Old Mar 06, 2012, 11:58 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
BTW, that thing looks like it is almost full scale. That plane is TINY in real life. I would say it is probably 80-90% scale.
SGTalon is offline Find More Posts by SGTalon
Old Mar 06, 2012, 05:21 PM
how much is offline
how much's Avatar
Joined Jul 2011
[QUOTE=beerbrewer;20954928 Even if it was filled with helium, that volume is so small it would have little effect on the weight.[/QUOTE]
so run that by me again!
lets try a basic maths lesson....
you have a vessel that weighs say 3pounds
you displace the volume of air within it with helium
said helium produces half a pound of lift
what does the vessel now weigh?
go ask mr Zepplin about it... he might just put you right on a few points
Old Mar 06, 2012, 08:44 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
I'm guessing it was built by the same guy who did the helium filled fuselage Airbus 330. the fuselage was some sort of membrane filled with helium. no internal structure, the wings probably depron. it flies just like this - there are videos of it somewhere here on RCG.
jonquinn is offline Find More Posts by jonquinn
Old Mar 07, 2012, 02:17 AM
RcLento is offline
Joined Jul 2011
I dont think so that it can be depron because its quite heavy it should be something like paper covering !
Old Mar 07, 2012, 09:14 AM
beerbrewer's Avatar
Waverly, Nebr.
Joined Apr 2009
Dear HM,
These are the basic math facts
The bouyant mass for 1 cubic meter of helium at sea level and 0 deg C is: .178 Kg * (1-(1.292/0.178))= -1.113 Kg. If the Cricri did have a volume of 1 cubic meter, the helium would reduce the weight by only 1.113 KG.
Why do you think the Zepplins were so big? They had to be so as to displace enough air to lift.
Old Mar 07, 2012, 02:42 PM
how much is offline
how much's Avatar
Joined Jul 2011
Originally Posted by beerbrewer View Post
Dear HM,
Beerbrewer
well done... now we are getting somewhere!
you calculate 1 cubic metre of helium generates "only" 1.113kg of lift?
well lets look at the cri-cri... that canopy and fairing alone could easily hold 1 cubic metre of helium
now 1kg = 2.2 pounds so 1.113kg is near 2.5 pounds of lift
so if he built the model at 5 pounds weight and displaced the air with helium...
yep! his cri-cri now only weighs 2.5 pounds
and as "jonquinn" said... do you remember the helium filled airbus?
well i do and here it is... all 285grams at 2 metre span
for you guys in imperial measureland... thats.. 78" span and 10 ounces heavy (28.34 gram = 1oz)
Airbus A310 by MM - indoor airshow Leipzig [HD] (5 min 19 sec)
and no the film is not slowed down or photo-shopped or any other new fangled jiggery-pokery.... what you see is how it is... 9 servos, working slats and flaps with lights! that fuselage is an 80" long helium balloon with a nose cone
old Von Zepplin knew a thing or two about lighter than air
d
Last edited by how much; Mar 08, 2012 at 12:10 AM. Reason: ounce conversion corrected... oops
Old Mar 07, 2012, 03:35 PM
how much is offline
how much's Avatar
Joined Jul 2011
and just to throw "a random one" in..
how heavy would a 1/3rd scale "piper" be ??? or could you fly a 1/3 scale Cub indoor?
lets see 120 4 stroke or 38cc petrol might just do it???
nope! watch and learn about lightweights..
modell-hobby-spiel 2011 - Piper PA-18 in Action (1 min 45 sec)
d
Discussion Amazing ! A model airbus a310 that takes offf,flies and lands that slow ! RcLento RC Airliners (Commercial, Cargo, Troop Carrier) 19 Mar 11, 2016 06:34 AM
Discussion Anyone know the best Warplane from Nitroplanes that takes off from grass thor4944 Electric Ducted Fan Jet Talk 1 Feb 11, 2012 02:39 PM
Question Is there a 2M plane that flies and costs like the eHawk 1500? Powerbud Electric Sailplanes 8 Jan 16, 2012 10:43 AM
What 3D plane takes off and lands vertically? sloper steve Foamies (Kits) 13 Jun 15, 2004 03:30 PM
Renauld R17 Flies (and lands) ekeitt Scale Kit/Scratch Built 3 May 21, 2001 08:34 PM
