Old Aug 17, 2012, 08:52 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Can anyone here tell me where the current best deal on purchasing a Easy Trainer 1280 is?
Thank you?
itsme2 is offline Find More Posts by itsme2
Old Aug 17, 2012, 09:17 AM
Swammy1979 is offline
Find More Posts by Swammy1979
Crashmaster
Swammy1979's Avatar
United States, CA, Lakewood
Joined Jul 2012
Thank you?
To my knowledge, this plane is only available at the bananahobby website.
Swammy1979 is offline Find More Posts by Swammy1979
Old Aug 17, 2012, 10:44 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Thank you?
Yep, it seems that only Banana carries the excellent FMS EZ Trainer models, but their prices are pretty good:
http://www.bananahobby.com/easy-trai...5359-prd1.html
http://www.bananahobby.com/easy-trai...5693-prd1.html
http://www.bananahobby.com/easy-trai...5360-prd1.html
Doubletap is offline Find More Posts by Doubletap
Old Aug 20, 2012, 06:41 PM
Crashmaster
Swammy1979's Avatar
Joined Jul 2012
Well, my plane landed in a tree today (about 40 feet or more up) after a transmitter glitch...not sure if I'll get it back. For now, crashmaster is grounded...or treed.
Old Aug 20, 2012, 08:08 PM
TNug is offline
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Bummer
I was lucky mine were only ~15' up - both times
Maybe some wind will dislodge it.
TNug is offline Find More Posts by TNug
Old Aug 20, 2012, 10:43 PM
ariveroll is offline
Find More Posts by ariveroll
Joined Nov 2011
Fms 1280 video
This plane is great, flies hard when you push it, floats like a bubble when you donīt... donīt hesitate, buy now and enjoy!
FMS 1280 OVER CARACAS (1 min 1 sec)
ariveroll is offline Find More Posts by ariveroll
Old Aug 20, 2012, 10:55 PM
Doubletap's Avatar
Joined Jul 2005
It looks like you really took to this model, although originally you were very skeptical over whether 2S would have adequate power. It just shows that a properly designed model, doesn't need to be overpowered, as the FMS Easy Trainer 1280 is so well designed that it is extremely efficient.
Old Aug 21, 2012, 08:09 AM
Joined Nov 2011
Absolutely right! although a little more power for emergency climbs would make it perfect!
Old Aug 22, 2012, 01:14 PM
pat.curtin is offline
Find More Posts by pat.curtin
United States, WA, Port Angeles
Joined May 2011
Fms radio
Does any one know who makes the receiver/transmitter for FMS 2.4 ghz radio. Is there a ful size Transmitter that you can buy that will bind with the FMS radio ? thank you
pat.curtin is offline Find More Posts by pat.curtin
Old Aug 22, 2012, 02:14 PM
Doubletap's Avatar
Joined Jul 2005
If you want to upgrade to a better transmitter, then it's easier to get a compatible receiver while you're at it, as the receivers are typically fairly inexpensive.
Old Aug 23, 2012, 04:13 PM
TNug is offline
Waypoint Collector
TNug's Avatar
Joined Feb 2012
As an FYI, I logged a 3S static run with my EagleTree just because I had the lipo laying around. No rpm or thrust measurement.
I did this because some others were asking about running the EZ1280 on 3S. I would not recommend it without upgrading at least the ESC. See below.
Battery: Zippy Flightmax 3S 1500mAh 20C
Otherwise stock electronics & prop
Pack voltage starting: 11.8 V
Pack voltage during full throttle: 10.8 V
Peak current: 26.6 A
Steady state current during full throttle: ~25.5 A
Peak power: 290 W
Steady state power during full throttle: ~275 W
There seemed to be significant voltage droop with the 30A capable 3S pack, so for giggles I hooked up my 3S 5000mAh pack - which was at storage voltage. (a little low)
Battery: Zippy Flightmax 3S 5000mAh 45C
Pack voltage starting: 11.3 V
Pack voltage during full throttle: 11 V
Peak current: 27.9 A
Steady state current during full throttle: ~26 A
Peak power: 306 W
Steady state power during full throttle: ~286 W
For comparison, these are numbers from a 2S test:
Battery: Zippy Flightmax 2S 2200mAh 25C
Pack voltage starting: 7.9 V
Pack voltage during full throttle: 7.6 V
Peak current: 16.0 A
Steady state current during full throttle: ~15 A
Peak power: 122 W
Steady state power during full throttle: ~115 W
Without thrust measurements, I can't tell you how much of the increased power translated into additional thrust. All I can say is I held the plane while running the tests and the 3S push startled me. I certainly felt like it could be 2X the thrust. I probably won't go through the trouble of measuring thrust, but I hope this may be helpful to others.
Old Aug 23, 2012, 05:35 PM
neil_f_real is offline
Find More Posts by neil_f_real
United States, CA, Laguna Niguel
Joined Jun 2008
FMS Easytrainer 1280 - radio upgrade advice sought
I have the RTF model and love it, but regularly suffer radio drop outs and loss of control with the stock radio, so looking to upgrade. Thinking about the Turnigy 9x Radio / Module / Receiver combo but need advice on what else I may need. For example, will the existing FMS servos and ESC work with the Turnigy receiver?
neil_f_real is offline Find More Posts by neil_f_real
Old Aug 23, 2012, 06:33 PM
TNug is offline
Waypoint Collector
TNug's Avatar
Joined Feb 2012
Yes, the Turnigy (FlySky) 9x will work just fine. I use the FS version with the 6 channel rx. It's quite a bit bigger than the stock rx, but smaller than the 8 channel rx. The servo connectors are labeled, so it should be straight forward. I also got a tx lipo from HK for it.
Old Aug 24, 2012, 09:48 AM
Crashmaster
Swammy1979's Avatar
Joined Jul 2012
I, too, switched to a turnigy due to cost and reviews. Do yourself a favor and make sure your batteries have a solid connection if using the supplied AA battery pack. Mine had a weak connection which ended in an in-flight power outage.....sending my plane into a nearby tree.
I can attest that the tx/rx will work just fine with the stock servos, no issues there.
Old Aug 24, 2012, 09:55 AM
Doubletap's Avatar
Joined Jul 2005
Any luck retrieving your model yet?
Cool Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest 3D Flying 41 May 19, 2012 07:17 AM
Discussion crash Video - Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest Crash Discussion 1 Jan 01, 2012 10:51 AM
Video Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest Electric Plane Talk 2 Dec 12, 2011 12:02 PM
Wanted Want: Trainer/Easy Fly - 3DHobby Shop EBT Trainer or similar rstoomanyhobbies Aircraft - Electric - Airplanes (FS/W) 3 Sep 11, 2008 10:56 AM
