Old Oct 06, 2012, 08:24 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
I bought the RTF version, after I glued in the horizontal stabilizer I noticed a serious misalignment. Apparently the fuselage is twisted, arrgghhhh....now what?
itsme2 is offline Find More Posts by itsme2
Old Oct 06, 2012, 08:45 AM
Swammy1979 is offline
Find More Posts by Swammy1979
Crashmaster
Swammy1979's Avatar
United States, CA, Lakewood
Joined Jul 2012
There was an earlier post about this as well:
Originally Posted by TNug View Post
I had the exact same issue (and a few dings on my wings) out of the box. There are very good guides on this forum on repairing/reshaping foam. (sorry i don't have the link) Dipping the tail boom in hot water seemed awkward to me, so I wrapped it in a wet towel and steamed it with an iron while twisting. It worked fairly well, but the steam gatored my foam. Over the course of a week or so, the twist came back. I just twisted the other way and squeezed the foam with my other hand. This seemed to work pretty well and also compressed the gatored foam a little. Not perfect looking, but that just matches the rest of my beat up plane.
I relocated my ESC to above and behind the canopy on top. My 2200 mAh battery fits nicely down in the slot in the battery compartment, but blocks the airflow through the inlet under the nose. I fly on a grassy field and get tons of grass and debris inside with each landing. So I moved the ESC as described for better cooling and taped off the hole to keep the grass out. My receiver is mounted inside between and behind the servos.
I may add a cooling hole or two in the canopy area. I'm not sure it's needed.
I see Tnug online, maybe he can give more info if he has it.
Swammy1979 is offline Find More Posts by Swammy1979
garryarm1 is offline
Find More Posts by garryarm1
NiteWkr
garryarm1's Avatar
Virginia Beach, Virginia
Joined Sep 2004
Unless it's wayy out it's not going to affect anything
garryarm1 is offline Find More Posts by garryarm1
Old Oct 06, 2012, 08:46 AM
Crashmaster
Swammy1979's Avatar
Joined Jul 2012
By the way, you should always dry fit everything prior to gluing so that you can identify and correct any flaws.
Old Oct 06, 2012, 09:14 AM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Yup, I'm out and about again so still no link to give but a quick search should turn up some good threads about repairing and reshaping foam. It's not perfect, but like someone posted above, it doesn't really affect the plane that I can tell. I love it. About to fly it actually!
TNug is online now Find More Posts by TNug
Old Oct 06, 2012, 03:51 PM
NorCal is offline
Find More Posts by NorCal
United States, CA, Chico
Joined Mar 2011
How to fix warps, dents, twists or uncrunch foam parts
I read your dilemma & a 2 min google revealed this link:
http://www.wattflyer.com/forums/showthread.php?t=65933
Let us know if this did any good or you came across more valuable info that we can all use.
NorCal is offline Find More Posts by NorCal
Old Oct 06, 2012, 08:23 PM
TNug is online now
Waypoint Collector
TNug's Avatar
Joined Feb 2012
That's exactly the thread I used as a guide. Good stuff. Must read IMO. Getting the twist out was sorta successful for me, but the nose repair after I crashed into a building at about 20mph was like magic.
Good luck and let us know how it goes.
Old Oct 07, 2012, 07:48 PM
NorCal is offline
Joined Mar 2011
Finally gettin around puttin the Easy together. So far I'm impressed w/ the design (beefier fuse) compared to other gliders in this price range. No regrets getting the "kit" as a backup to the ARF.
1.) Reinforcing the nose, leading wing edges/tips, tail & elevator w/ packing tape (sparingly).
2.) Plugging up the "grass catcher" bottom vent hole & trying to figure out where to drill a couple of other effective vent holes. Anybody have any ideas or pics?
Old Oct 23, 2012, 12:42 PM
donjuanob1979 is offline
Find More Posts by donjuanob1979
Joined Oct 2012
First plane .new to hobby..couple adjustments to elevator..wanted to nose up and stall..now it flys great! Cant wait to post vid of flight
donjuanob1979 is offline Find More Posts by donjuanob1979
Old Oct 23, 2012, 12:48 PM
Joined Oct 2012
Put in time on sim..to get orientation down.. other than wanting to nose up when i first got it..no probs...onlu complaint is cant really do rolls ...is there any mods i can do to the wings?
Old Oct 23, 2012, 03:56 PM
Crashmaster
Swammy1979's Avatar
Joined Jul 2012
Rolls were a pain in the #&! for me at first on this plane. It would do them, but very slowly. This is good though, because it gives you time to learn as a beginner. When I got more comfortable with the plane, I sliced off the swoop from my wingtips (the decal makes a perfect guide for the slice angle)...and she rolled a little better. After that, I added a more powerful motor with a 6x4e prop....and she rolled much more to my liking. Each of these mods will drastically change how she flies....seeming like an entirely different plane.
I would do these steps gradually (as in...not all at one time), as you become more and more comfortable with the plane. Probably the last thing you want is an overpowered plane that does snaprolls. You may end up doing a death spiral to the ground if you're not careful.
Have fun, and don't forget to come back and tell us your stories!!
Old Oct 23, 2012, 08:51 PM
rcdw is offline
Find More Posts by rcdw
United States, CA
Joined Aug 2012
How do you fix the nosing up? I've put the battery far forward and added some larger metal washers. The balance is more forward than the manual calls for. It's still nosing up. Gliding is fine.
rcdw is offline Find More Posts by rcdw
Old Oct 23, 2012, 09:24 PM
NorCal is offline
Joined Mar 2011
rcdw
Have you ck'd cog @ 70mm per manual? I added a lot of tape front & rear for reinforcement and mine balanced perfectly @ 70mm w/ 1800mAh 3s 35c,,,,I was shocked @ how it was spot on after all the tape I added.
Old Oct 23, 2012, 10:08 PM
rcdw is offline
United States, CA
Joined Aug 2012
The CG is at 5 to 5.5cm from leading edge of the wing, the elevator about 3mm down and it's still nosing up.
Old Oct 23, 2012, 10:18 PM
Crashmaster
Swammy1979's Avatar
Joined Jul 2012
If you're talking about the tendancy to pitch up at full throttle, that's normal for this plane. I believe it comes from the angle the motor is mounted relative to the rest of the plane. Only thing that I can suggest is to either:
1. Trim your plane so that it flies straight and level at your normal cruising speed, compensate with elevator at any other speed.
2. If you have a programmable transmitter, set up a throttle/elevator mix so that the elevatoe goes slightly down the faster you go
Be careful with option 2 not to give TOO much down elevator, or you will find yourself in a mess at full speed. HTH.
Cool Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest 3D Flying 41 May 19, 2012 07:17 AM
Discussion crash Video - Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest Crash Discussion 1 Jan 01, 2012 10:51 AM
Video Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest Electric Plane Talk 2 Dec 12, 2011 12:02 PM
Wanted Want: Trainer/Easy Fly - 3DHobby Shop EBT Trainer or similar rstoomanyhobbies Aircraft - Electric - Airplanes (FS/W) 3 Sep 11, 2008 10:56 AM
