Old Mar 04, 2012, 02:26 AM
See is offline
See
Find More Posts by See
See
Joined Mar 2012
elogger no voltageS output to BEC/Engine
hola,
I've installed the eagle tree yesterday on my 600 Trex powered by 10.000 6s battery.
on the beginning everything was fine and I just have to lay one Y cable for the gps working proper.
but I feel that the elogger was very hot the hole time. I read the documentation and cannot find any problem with my voltage 22.2V...
Now the e-logger does not give any output to my BEC anymore. The red LED on the logger is blinking 1-1-1-1-1-1-1-1 ... normal mode...
what is the problem??
best
See
See is offline Find More Posts by See
Old Mar 04, 2012, 05:04 AM
See is offline
See
See
Joined Mar 2012
I found out that i make a wrong measure and the eagle tree is deserving 24V to my KONTRONIK JIVE 100+ LV.
But now the strange thing.. the JIVE does not respond at all.. no sound, nothing
I checked the jive on another copter with the same result: BROKEN
does somebody also have had such problems?
best
See
Discussion time analyzing when running in full power(no PWM output) of BLDC controller liangxiao DIY Electronics 5 Mar 21, 2012 07:13 AM
Discussion Rookie question...BEC or no BEC X650 61retro Multirotor Talk 1 Nov 04, 2011 05:38 AM
Discussion Mamba Monster's BEC Output specs? jmarks Castle Creations 2 Oct 17, 2011 12:37 PM
Discussion BEC Pro Output Leads Warbirds Rule Castle Creations 2 Sep 25, 2011 11:09 AM
Multiple Output Voltages from Flight Pack air DIY Electronics 2 Aug 20, 2004 11:29 AM
