Old Nov 08, 2012, 07:23 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Originally Posted by NitroCharged View Post
Joe, did you ever post about your little A10, that you flew at JR, anywhere?
Dave,
Joe's A-10 is here. I was just there looking it over again!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Nov 08, 2012, 03:49 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Thanks Fred, I lost me internet connection for a few days after a wild storm passed through earlier in the week, so missed it.
I think Joe would be in for a treat when he get his hands on these single phase motors!
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 09, 2012, 10:21 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Hey nitro, you get a pm
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Nov 09, 2012, 12:02 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
I am dreaming about it!
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Nov 10, 2012, 05:50 AM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Production has started
Chris T is offline Find More Posts by Chris T
Old Nov 10, 2012, 11:35 AM
Carbondale PA
Joined Aug 2005
Wow, they look great!
Joe.
Old Nov 10, 2012, 12:14 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Those are very pretty. I probably missed it, but what is the difference between the two boards pictured?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Nov 10, 2012, 05:05 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Now that's a small speedie Chris!
Kev, I am thinking the wired up one is the original and the other two boards are the ones he has made for production.
Old Nov 11, 2012, 05:24 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Kev, it's the same board. I just clipped off the programming pads in the end. Anyway, I don't need them. It turned out that it is simpler to solder the uC to a programing board, flash the code, set the fuses and the lockbits and then take it off again and solder it to the final board. It is much more effort to solder 6 wires to each board and then program in circuit. Funny, I always thought in circuit programming is the thing, but it is only for development, not for production of the ultra small stuff. The cap might be a bit oversized right now as you can see. That footprint was ment for a 0402 4.7uF cap, which worked well, but had problems with my all big and slow test motor (6mm magnet). For the smallest projects, this can be exchanged again. I wanted to make sure that the controllers I sent out have the maximum robustness.
BTW, I designed a new board with the new SI4355 rx. This is going to be sweet
Chris
Old Nov 11, 2012, 05:36 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Here's the name of the product: c3blc1
The device ships with magnet wires attached to it. Please refer to the image above for pin assignment. Red is black and plus is minus
Old Nov 12, 2012, 03:29 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
I did some testing with 1 and 2 10mAh FR lipos. 1 isn't doing it at all. 2 seem to be fine. I get stable 200mA at around 3.5V for a while then voltage is dropping slowly towards 3V. It should be possible to wind a slightly hotter motor. This one is still staying cold and so is the controller. This test was also with the small controller with A3903 bridge. The new board with SI 4355 receiver and A3903 bridge is coming along well. It's going to be smaller than the c3blc1! I need to test if this setup is running at all. The difficulty is that I have to handle 2 voltages, because the SI4355 is running on 3.3V.
Chris
Old Nov 12, 2012, 02:51 PM
Carbondale PA
Joined Aug 2005
Chris,
Have you tried the 20 FR cell. The weight would be the same as the 2 cell 10mAh set up.
Joe.
Old Nov 12, 2012, 04:40 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
I know, but it doesn't fit easily. I'll try 2 10mAh, if it works I might as well consider 30mAh which is just a bit thicker than the 20. I would have to cut a slot into the bottom of the fuse for both batteries, which is not yet quite what I want to do. If you can fit the 30mAh you will be amazed what power you can get from two motors. What magnet size are you planning to use?
Old Nov 12, 2012, 11:45 PM
Carbondale PA
Joined Aug 2005
I have some 2.5mm magnets, and even some smaller ones that a friend gave me. I figured that I would build a few motors to test out what is the best magnet, wire size and ohms for the power that I need.
Old Nov 13, 2012, 08:07 AM
Flying Dutchman!
Joined Sep 2011
http://microflierradio.com/Batteries.html
8mah battery! Wow maybe time for one 6mm edf :-)
Discussion 6'' Micro Squall (20mm EDF, Single Phase Sensorless Motor) Chris T Micro EDF Jets and Power Systems 264 Dec 10, 2015 09:50 PM
Sold New Phase 3 Squall! 40A 11.1v ESC + used 3s ducted fan setup jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 01:45 AM
For Sale Phase 3 Squall kit plus motor/fan combo SmoothCruizer2 Aircraft - Electric - Jets (FS/W) 5 Oct 05, 2011 11:50 PM
Sold NIB Phase 3 Squall EDF 4-cell Hi-Perf ARF w/Fan/Motor/ESC $85 each Shipped Insured jmrust Aircraft - Electric - Jets (FS/W) 6 Nov 18, 2010 09:41 PM
For Sale 63mm EDF combo 3S (fan,motor,esc) squall phase 3 crd Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2010 08:19 PM
