Old Oct 22, 2012, 04:04 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Chris, I thought the sound was a lot lower in the second video and did not sound like 98k. I'll get on it some time today.
Good to see you back Chris!
NitroCharged is offline Find More Posts by NitroCharged
Old Oct 22, 2012, 04:15 PM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
just for size comparison
Chris T is offline Find More Posts by Chris T
Old Oct 22, 2012, 04:18 PM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Man you kidding, that's just to small!!!
You wanna use a microscope to fly???
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Oct 22, 2012, 04:34 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Dave, in the second video the sound is a lot more silent, but in terms of frequency you hear something different. There is a very high tone that probably comes from the four blades. The fundamental of the motor transmitted to the coil isn't really noticable due to the good balance. When I made the setup worse that tone kicked in like in the first video. The rattling noice you hear is the shaft bouncing against the bearing from time to time and causing some vibrations. This can be much worse when the balance is off or the play in the bushing is tighter. Kind of funny that you seem to need a sloppy bushing...
Chris
Old Oct 23, 2012, 10:38 AM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
HOLY ****! That's small! How? who? what? HOW?
How much thrust does it produce? I figure you'd need a very light airframe for that.
hanzie is offline Find More Posts by hanzie
Old Oct 29, 2012, 04:22 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Ok, I can confirm now that we are talking about rpms in the 90k range. I measured 92k with the 4-blade on the scope. 100k should be no deal. Actually, the motor doesn't get warm. I need to build a hotter one
I am just finishing a prototype of a sensorless driver for these single phase motors that is controlled by a standard servo signal. Running on SPECTRUM AR6300 right now. Anybody interested
Chris
Old Oct 29, 2012, 07:49 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
How much current is it currently sucking Chris?
How many winds would be a good starting point for a 15mm edf - 3 blader?
Looking forward to getting one of these controller for sure!
Old Oct 30, 2012, 05:22 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Hey Dave,
you will get the first controller
You are asking difficult questions. Current is still around 190mA. RPM after a closer look on the scope is exactly 100k That is the easy part. Number of winds I have no clue. I wound on the lathe and it was a bit too fast to count. I probably will go by wire length in the future. I used .1mm wire for the 10mm. .4mm wire for the 20mm. So the wire thicknes goes with the sqare of the size (constant supply voltage). I would recommend .22mm wire for a 15mm fan to start with. Just wind until it looks fine in terms of magnet/coil volume. I f you manage to count, go from there and rewind until you find the sweet spot. But I don't have to tell a motor crack
Old Oct 30, 2012, 02:52 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
Hi Chris,
You know that I would be interested!
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Oct 30, 2012, 03:02 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Chris,
I take it, to take advantage of your generosity, you need expierence building motors??? If so, I'd need to get spun up (no pun) with the skills. Been watching you from afar and what you're doing is amazing. Really admire what you're doing and you're generosity.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Oct 31, 2012, 07:34 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Chris, clear some space in your inbox... she's full!
Old Nov 03, 2012, 01:04 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Here comes the squall
Smaller than I thought and as easy to build as the large one
I thought I have to push the 3'' project a bit before I send Joe a controller I will assemble a couple of controllers within the next days. The first one shipped yesterday
Chris
Old Nov 03, 2012, 04:34 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Crikey! That shot with you holding the model really shows just how tiny it is!!!
Old Nov 03, 2012, 06:25 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Everything fits and the cg is coming along
Weight so far is 2.1g (only the servos missing)
Chris
Old Nov 03, 2012, 07:06 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I've never seen a 10mah lipo look so huge!!!
This has given me an idea for a nano servo, Chris. I'll PM you later.
Discussion 6'' Micro Squall (20mm EDF, Single Phase Sensorless Motor) Chris T Micro EDF Jets and Power Systems 264 Dec 10, 2015 09:50 PM
Sold New Phase 3 Squall! 40A 11.1v ESC + used 3s ducted fan setup jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 01:45 AM
For Sale Phase 3 Squall kit plus motor/fan combo SmoothCruizer2 Aircraft - Electric - Jets (FS/W) 5 Oct 05, 2011 11:50 PM
Sold NIB Phase 3 Squall EDF 4-cell Hi-Perf ARF w/Fan/Motor/ESC $85 each Shipped Insured jmrust Aircraft - Electric - Jets (FS/W) 6 Nov 18, 2010 09:41 PM
For Sale 63mm EDF combo 3S (fan,motor,esc) squall phase 3 crd Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2010 08:19 PM
