Old Apr 11, 2012, 03:36 PM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Originally Posted by jkarran View Post
Nintendo Wii handset?
This is really cool work Chris.
You got it i took the handle from a nice logitech joystick...
Chris T is offline Find More Posts by Chris T
Old Apr 11, 2012, 03:50 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Chris T,
Dude, you are strictly cutting edge! Been watching from afar. Will love to see this one fly.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Apr 15, 2012, 12:13 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Hi,
I am looking for a source of disc magnets for servos. D2mm x 1mm N50 magnetized through the length. Anybody knows where to get that?
Chris
Old Apr 15, 2012, 03:43 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Originally Posted by Chris T View Post
Hi,
Chris
Closest thing I know of, some of which I own, and have bought through this company: 1/16" dia, 1/32" thick, so guess its more like 1.5mm dia x .8mm. Link to magnets.
Freddie B is offline Find More Posts by Freddie B
Old Apr 18, 2012, 12:43 AM
shagrug is offline
Find More Posts by shagrug
Oak Ridge, Tennessee
Joined Dec 2007
How many disc magnets do you need? I've got some from here:
http://www.supermagnetman.net/produc...roducts_id=145
shagrug is offline Find More Posts by shagrug
Old Apr 18, 2012, 08:14 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Damn, how come I didn't find these? I ordered a bunch of N48 ones here
http://magnetmonster.de/
They are not N50, but the difference should be small. Dan, I would love to get some more of the brass tubes for .5mm shafts you sent to me once. Would you tell me where I can buy these?
Chris
Old Apr 18, 2012, 10:06 AM
shagrug is offline
Joined Dec 2007
Not easy to find, only a few KS vendors carry this size:
K&S Round Tubing .006" 1/32" TT61
It comes in 12" lengths, usually 8 sticks per package. The ID is undersize so you will need to ream the bearings with a .020" bit. (.5mm for you)
Old Apr 18, 2012, 12:27 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
If you find a vendor, please share. I'd love to have some of that too!
Fred
Old Apr 18, 2012, 02:46 PM
devmonkey is offline
Find More Posts by devmonkey
United Kingdom, England, Surrey
Joined Aug 2002
Hi Chris and all,
Thanks for your help on the sensorless controller, I now have a working controller and have built a couple of motors. For speed control I centre the on period between two zero crossings (based on the interval between the last two zero crossings) and vary its width, max throttle being 70% on. So for example if the last interval was 100ms, at full throttle I switch on 15ms after the last ZC and off at 85ms, then wait for the next ZC.
Is this similar to what you do? I don't have a reliable startup yet, I have to flick the prop, any pointers?
Something I can't explain is the two motors i've built so far (4x8mm magnet, 0.2mm wire) one 40 and one 60 turns seem to show identical RPM at the same voltage? I was expecting the RPM to change, maybe I need to try thinner wire and more turns, coil resistance was <2ohms so maybe the KV in both motors was just too high for the prop I'm spinning (AA prop).
Cheers, Joe
devmonkey is offline Find More Posts by devmonkey
Old Apr 18, 2012, 10:27 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
vendors for tubing...
http://www.amazon.com/Engineering-Ro.../dp/B0006NAT4I
http://www.hobbylinc.com/htm/k+s/k+s15035.htm
SteveH
shoutchen is offline Find More Posts by shoutchen
Old Apr 18, 2012, 10:29 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Originally Posted by shoutchen View Post
Thanks SteveH. Very pricy but very hard to make too I imagine.
Fred
Old May 01, 2012, 01:49 PM
pem is offline
pem
Find More Posts by pem
pem
Frankfurt Intl, Germany
Joined Feb 2004
for tubes look there as well:
http://www.hero-berlin.de/German/Pra...agerliste.html
pem is offline Find More Posts by pem
Old May 02, 2012, 02:12 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Hey guys,
here is an update: I finished a prototype of my all new wii type tx. I wanted to show a photo of that good looking piece right here. I still can do but I have to report that I am a lot less enthusiastic about it now I got it to work well, I even resolved my range problem by introducing a printed circuit bifa antenna, so I shouldn't have those motor dropouts anymore, which the big squall showed from time to time. Now comes the problem. I figured how important a reproducible neutral position of the controller is. On a stick tx, I first perfectly trim the model and then control the plane by short stick movements and letting the stick return to its neutral position. This way I know exactly, when the model is going straight. With the wii type controller you don't have a reproducible neutral control. You kind of have to feel where the orientation of the controller is that corresponds to neutral and every tiny deviation will make the model roll, climb or dive. I tested with the 6'' squall to have a comparison. I managed to handle it in the end and did a full circle. Then with full speed I went over my head and through the sun, while turning my body and the tx to the other side. Here comes the other problem. That movement causing centrifugal forces looks to the controller like elevator down. I knew that already and intended to make a compensating up movement. But by the time the model came out of the sun, It was diving in with full speed and 70000rpm. I have done about 50 launches with that controller and abused the 6'' so much that I came to the conclusion that that type of control will never give the authority and precision we are used from a stick. Too bad, but that seems to be the fact.
The motor mount of the squall came loose when it knocked in and the running rotor broke. That's it. The fuse is fine. Incredible. Now I might improve the motor setup, since it is already out
I will continue on the 3'' model as soon as this is fixed. At least I know that I shouldn't put a lot of effort into the tx
Chris
Old May 29, 2012, 05:10 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Update:
Hi,
I have been buzy optimizing my servo code lately. I didn't want to hear that noise any more the servos made. So I introduced a 30kHz pwm and PI-control. Now you have to go really close with the ear to be able to tell if they are running. The loudest noise they make now is the stepping through the target positions on a fast transition, since the ppm signal is updating the target position only every 20ms, which on a fast stick movement is quite a step. I am planning to filter this by interpolating the the ppm information. Also I will try to mix in D-control for better stability. It is stable now, but the damping is not very much, and I want the code to run on different setups without adaptation. BTW, the current consumption has dropped significantly too. Very good for the nano squall...
Not such good results on the tiny rx yet, bad range still. I prepared a test board to find out a suitable setting. One of the next steps will be the bl controller with the A3903 bridge.
Cheers,
Chris
Old May 29, 2012, 05:03 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Sounds like lots of R&D going on over your end Chris! Thanks for the update.
NitroCharged is offline Find More Posts by NitroCharged
Discussion 6'' Micro Squall (20mm EDF, Single Phase Sensorless Motor) Chris T Micro EDF Jets and Power Systems 264 Dec 10, 2015 09:50 PM
Sold New Phase 3 Squall! 40A 11.1v ESC + used 3s ducted fan setup jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 01:45 AM
For Sale Phase 3 Squall kit plus motor/fan combo SmoothCruizer2 Aircraft - Electric - Jets (FS/W) 5 Oct 05, 2011 11:50 PM
Sold NIB Phase 3 Squall EDF 4-cell Hi-Perf ARF w/Fan/Motor/ESC $85 each Shipped Insured jmrust Aircraft - Electric - Jets (FS/W) 6 Nov 18, 2010 09:41 PM
For Sale 63mm EDF combo 3S (fan,motor,esc) squall phase 3 crd Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2010 08:19 PM
