Old Dec 16, 2012, 12:31 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Steve,
this is a sensorless controller design, which means that you don't need a hall sensor on the coil. This allows to separate the two heat sources coil and driver. Also throttle control is better than on the A1442 and I believe my controller has a better efficiency. But not for Dan's motors since they don't run with my controller Seems like the timing is not covering high inductance motors. Just a question of adaptation...
Chris
Chris T is offline Find More Posts by Chris T
Old Dec 16, 2012, 01:10 PM
Carbondale PA
Joined Aug 2005
Hi Chris,
I tested several of Dan's motors that he set me and they all ran with your controller. I am now wondering if it has something to do with the transmitter. I could not get your controller to work with my DX-8 transmitter, but it worked with my converted Plantraco Hip Hop transmitter. Maybe it is has something to do with the throttle settings. I know that you tested the controllers before you sent them out.
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Dec 17, 2012, 02:03 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Really? that is interesting. Maybe Dan can make a shot of the servo signal with his usb scope.
Chris
Old Dec 17, 2012, 12:16 PM
mudville
Joined Nov 2002
ChrisT
I presume your controller responds to plain vanilla servo pulses
(1 to 2 mec wide, every 22 msec or so)..
SteveH
shoutchen is offline Find More Posts by shoutchen
Old Dec 21, 2012, 08:17 PM
mudville
Joined Nov 2002
ChrisT,
Also check out the TI DRV8835 dual hbridge, maybe that can drive a couple of your
servos.. Sort of like a better version of the a3901..
Pololu electronics has a test breakout board for these for 6 bucks..
http://www.pololu.com/catalog/product/2135
SteveH
Old Dec 21, 2012, 09:33 PM
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Chris, the new capacitor arrived yesterday!
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 28, 2012, 02:49 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
DRV8837 is running
Old Dec 28, 2012, 10:59 PM
mudville
Joined Nov 2002
Chris
Kool..hope it works out for you..
Check out the Drv8851. Ldo plus hbridge
Not available yet but looks worth tinkering with
I got my drv8835 test board from polulu today..
it seems to work aok as well..
SteveH
Old Dec 29, 2012, 10:20 AM
mudville
Joined Nov 2002
All
I know you guys are working on high
Rpm motors for the jet .. but i am interested
in this stuff to try to build motors for a nano size
Helicopter.. i know shagrug is the guru here on the
Motors and i was wondering if he or anyone else could
Speak about how to go about
designing the motors for that application..
More or less turns.. bigger or smaller wire...bigger or smaller magnet..etc..
Those are questions i wish somebody could try to address to steer me in the right
direction
SteveH
Old Jan 01, 2013, 05:37 PM
mudville
Joined Nov 2002
All..
Happy New Year to everybody!!!!
ChrisT,
When is the optimum time to turn on the hbridge to
maximize the amount of torque applied to the magnet?
I would think it would be closet when the poles of the radially polarized magnet
are not othrogonal to the motor windings electromagnetic field..
Is what you are trying to do is measure the measure the back emf
to determine the rotor position so you know when to apply the current
to the motor? and use pwm to control the speed?
I am kinda new to this brushless motor stuff..
SteveH
Old Jan 05, 2013, 06:51 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Happy new year too to everybody!
I think I found something on the controller. While developing the new rx, I figured that if the rx goes crazy during motor start, the pulse width of the motor control can increase severely, most likely due to the fact that there are multiple edges on the rx line triggering the ppm read sequence by the pin change interrupt. This way, switching off the coil in time is delayed and supply voltage is dropping enough to reset the atmel while the coil is drawing the current. I am now making a start routine that is only triggered by the ppm signal, but during startup, the ppm signal is ignored until I am in sync mode. This mode disturbes the radio signal much less (not at all for me). So the performance of the actual controller code is dependent on the behavior of the rx during disturbance and this might explain the different experience you guys had with the c3blc1. Seems like it is time for a c3blc2 with the new bridge
Chris
P.S.: Just to get it straight: I caused the multiple edges by switching off the tx and running a start routine that wouldn't read throttle from the ppm signal. Still a high frequency on the ppm line, which you get without a radio signal, did increase the pulse width.
Old Jan 07, 2013, 02:46 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Servo installed and working. ..
Old Jan 07, 2013, 03:47 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Sweet!!!
Old Jan 09, 2013, 03:04 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
fan design
Old Jan 10, 2013, 02:37 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
first 3D shot
Discussion 6'' Micro Squall (20mm EDF, Single Phase Sensorless Motor) Chris T Micro EDF Jets and Power Systems 263 May 08, 2013 10:31 PM
Sold New Phase 3 Squall! 40A 11.1v ESC + used 3s ducted fan setup jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 01:45 AM
For Sale Phase 3 Squall kit plus motor/fan combo SmoothCruizer2 Aircraft - Electric - Jets (FS/W) 5 Oct 05, 2011 11:50 PM
Sold NIB Phase 3 Squall EDF 4-cell Hi-Perf ARF w/Fan/Motor/ESC $85 each Shipped Insured jmrust Aircraft - Electric - Jets (FS/W) 6 Nov 18, 2010 09:41 PM
For Sale 63mm EDF combo 3S (fan,motor,esc) squall phase 3 crd Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2010 08:19 PM
