Old Dec 05, 2012, 02:22 PM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
The final rx + blc board will be 12 x 5 mm.
Chris
Chris T is offline Find More Posts by Chris T
Old Dec 05, 2012, 02:29 PM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
Impressive!!!
Ivan2280 is offline Find More Posts by Ivan2280
Old Dec 06, 2012, 07:13 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
You crazy microdudes are epic!!!! So smallll!!
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Dec 11, 2012, 05:37 AM
shagrug is online now
Find More Posts by shagrug
Oak Ridge, Tennessee
Joined Dec 2007
Hi Chris-
I received the second controller today, and just finished some quick tests.
It seems much the same as the first, even a bit worse. The throttle range is even narrower on all three test below. About half what it was before (all three tx'es) and speed the same (rpm-wise) Removing the prop makes no difference again, switching coil wires, etc.
I'll try it some more soon as I can, using a different motor (smaller and more ohms?) and whatever else I can think of. I only had a hour or so to spend on it tonight. Since both controllers worked for you I'm thinking the problem is at my end.
The odd sound in the vid is one of our beagles having a dream.
testing new sensorless controller (1 min 4 sec)
shagrug is online now Find More Posts by shagrug
Old Dec 11, 2012, 01:15 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
ChrisT,
Check out the new hbridges from TI...
DRV8837,,, like an a3903 but higher current..
DRV8830.. I2c hbridge, for those with no pwm output on the CPU..
SteveH
shoutchen is offline Find More Posts by shoutchen
Old Dec 11, 2012, 02:08 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Dan,
strange but interesting, still looking at your video. I would recommend to try a lower ohmic coil with a clipped prop, maybe 15mm diameter. This will get us closer to a edf setup. And use your scope to monitor the ppm signal. I would have assumed the motor to kick in harder and run faster when throttling up. Maybe the controller is really set for faster motors. Don't fear the amp draw, fear the low rpm Maybe that brings us ahead. And check if the radio signal is dropping out by looking at the rpm. Right, it must be the difference in your setup. That doesn't mean you are doing a mistake, maybe the controller doesn't cover the operating points of your motors. Pretty sure it is not a hardware failure, since both boards were tested and worked for me.
Chris
P.S.: Interesting also that I hear everything but the motor. It must be really low kv. The thing I'd expect is that when kv is too low for the controller, there is a timer overflow within one half revolution and then timing calculation goes mad. I am using an 8 bit counter and have set the ck divider according to the high rpms I have. As I said before, I never tested prop setups, so this seems to be the must likely explanation. Get the kv up, the load down and see what happens just for reference, I had 20 turns around the D6 x 5 mm magnet.
Old Dec 11, 2012, 02:41 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Wow, rdson at 5V is 1/4 of the A3903. This is one of the best finds next to the SI4355 for years. Thanks a lot Steve! Now I just have to find a suitable solution for the different pinout...
Chris
Originally Posted by shoutchen View Post
ChrisT,
SteveH
Old Dec 11, 2012, 04:54 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
I wish i knew what you guys are talking about because this sounds very interesting!
chester2240 is offline Find More Posts by chester2240
Old Dec 12, 2012, 11:25 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
chester, Rdson is the resistance of the motor driver. The lower, the more power you can draw at the same operating temperature. Also at same power level, the efficiency of the controller is higher. 1/4 of Rdson makes a huge difference. The rating is 1.8A vs .5A.
Seems like I already designed the new device into my 5 x 12mm board without increase of size. Doesn't look so nice but is still single sided
Chris
Old Dec 12, 2012, 06:17 PM
mudville
Joined Nov 2002
ChrisT
Did you port the Si4355 code from the SiLabs EZRadio examples to the T44?
SteveH
Old Dec 13, 2012, 03:07 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Steve, that's what I am currently working on. I am using the Wireless development suite and the IDE from SILABS to generate sample codes. Then I copy and paste the easy config array, the check sum and the number of config words to the atmel code. Well part of that I have done. The easy config array syntax is compatible with atmel assembler. I generate an eeprom file from the assembler code with just the array pasted into the code. The 202 bytes are beeing transferred to the rx already. Tonight I will send the checksum too to see if everything went right. I am going through the c code in the generated IDE examples to see which programming sequence is needed. After easy config, there are only a few steps to do, I think switching to rx mode and configuring the GPIOs. The C code example is a little difficult to follow, cause it is separated in several files. But I made it almost to the finish line
Chris
Old Dec 15, 2012, 07:26 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Radio link with the new SI4355 established!!!!
Chris
Old Dec 15, 2012, 10:30 AM
mudville
Joined Nov 2002
Direct or packet mode?
BTW, what technique do you use to solder the 20 pin
3mm qfn to the pcb? I am just starting to build smd stuff
around that size and wondered what has been successful
for others..
SteveH
Old Dec 15, 2012, 11:48 AM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Hey Steve,
I am using direct mode so far to transfer the ppm signal. It is a bit different as I was used to from the SI4320. Looking at the rx data, it seems to be quantized according to the datarate setting. I probably have to set the data rate higher or use the raw data. The raw data looks fine but is probably not filtered and thus more sensitive. Either way, from now on, optimization is quite straight forward, no blind flight anymore I will try some different settings now.
Soldering qfn and bga is not difficult with a hot air rework station. Using the thin boards you can even heat from the bottom. I did so with the ldo and the crystal. The "big" 3 x 3mm qfn chips I pick with a tweazer and put it in place while applying hot air from the top. Once it is sticking, I push it down more so all pins make contact and very often I have to shift it into place, cause I didn't hit the place exactly. Most important is that you don't fear doing it wrong. It is very forgiving and you can always take the part off again or push it sideways. If it is close to the correct position, it will slide on spot by itself. I pre-tin the board and then add sticky solder flux. Go for it
Chris
Old Dec 15, 2012, 07:01 PM
mudville
Joined Nov 2002
ChrisT,
Will do. So about your bldc controller, is it sort of like a cpu based replacement for
chips like the a1442? Or something else...
SteveH
Discussion 6'' Micro Squall (20mm EDF, Single Phase Sensorless Motor) Chris T Micro EDF Jets and Power Systems 264 Dec 10, 2015 09:50 PM
Sold New Phase 3 Squall! 40A 11.1v ESC + used 3s ducted fan setup jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2012 01:45 AM
For Sale Phase 3 Squall kit plus motor/fan combo SmoothCruizer2 Aircraft - Electric - Jets (FS/W) 5 Oct 05, 2011 11:50 PM
Sold NIB Phase 3 Squall EDF 4-cell Hi-Perf ARF w/Fan/Motor/ESC $85 each Shipped Insured jmrust Aircraft - Electric - Jets (FS/W) 6 Nov 18, 2010 09:41 PM
For Sale 63mm EDF combo 3S (fan,motor,esc) squall phase 3 crd Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2010 08:19 PM
