Aileron Differential - Rudder
I was just curious what other people use for aileron differential. Typically I use about 10% less on down than I do for up. Anyone else have different percentages?
The same goes for the rudder. I will mix in rudder to aileron at around 15% left for left and 15% right for right. Just curious if others use differential and rudder mix. -Paige |
Latest blog entry: Freestyle Flight - The Last Frontier
Thanks Phil. I appreciate your feedback. I appreciate it.
-P |
Same as Dawson for me. I guess it depends upon what style of flying you are aiming for.
For aeobatics, diff and rudder mix are not required and are counterproductive. As a full size glider pilot, I am averse to ail/rudder mix anyway! (or prejudiced some might say! )I entered into an extended discussion/debate with others on another thread regarding aileron/rudder mix. I'll see if I can find where it was. Jim. edit: It starts about here: http://www.rcgroups.com/forums/showt...34497&page=141 |
Makes complete sense Dawson...thanks.
-P |
I should probably clarify my original post. My question about differential was based on a question I got from a customer for a non-aerobat concerning reducing yaw during rolls. While I don't use differential myself on my aerobatic planes, I have used a rudder assist (mix) to prevent a similar problem. From what I have read here, I should probably induce rudder manually and allow it to become second nature (as Awesome Dawsom does). The bottom line is trying to find ways to make axial rolls tighter while reducing yaw. Thanks for the feedback. For the record, I agree with the "symmetrical" approach to settings when applied to aerobats.
-Paige |
-P |
My personal experience is ,it depends on the model . For instance a scale DG600 would not respond cleanly without diff on the ailerons actually 100% up 50 % down and without out rudder input would drag its tail low . 50% rudder mix to aileron on a switch takes the drama out of this ,of course you still have the option of doing it manually with the mix switched out ,but that's like not using the cruise control in your car IMHO
Typically smaller PSS stuff fly's fine on aileron elevator with equal throws .The best thing about the modern radio's is the ability to mix controls and get the best possible flight performance from the model. Not using the functions sort of defeats the purpose of buying a radio that has that capability in the first place I feel . All my large PSS models run diff and mix and it makes them a joy to fly .just my 2 cents. |
Latest blog entry: 4 days
While proper ruddering can help with making rolls pretty, it's probably more important to treat the cause than the symptom.
In my experience, non-axial rolls can be caused by a number of things: - Too much total aileron throw - Too much aileron differential - Differential setup incorrectly (more down than up) - CG is off - Rudder > aileron mixing is turned on Those are all things worth fiddling with. Rudder > aileron mix won't help and in fact will hurt, as you'll get the wrong rudder input for the first 180* of the roll (assuming upright entry) and this will cause the nose to drop and the roll to generally look non-axial. I have some mechanical aileron differential on a couple of planes, but none mixed in. I just use the rudder. Steve |
Latest blog entry: And now for something completely...
I try not to look at it as too daunting...but rather an opportunity to take advantage of your radio's abilities. Thanks Steve... -Paige |
-Paige |
What I mean re: CG - if the plane is too noseheavy, it may be carrying sufficient elevator trim such that it won't roll nice and axial, but instead does a sort of barrel thing. Just something else to check.
Steve |
| Thread Tools | |
| Question Flaps and Aileron differential | xiaoyu80305 | Sailplane Talk | 16 | Nov 05, 2012 10:29 AM |
| Help! Aurora 9 aileron differential | RJPIoW | Radios | 4 | Oct 10, 2011 03:41 PM |
| Rudder Input vs. Aileron Differential | down_shift | Hand Launch | 14 | Jul 25, 2009 06:25 PM |
| Discussion Aileron differential verses rudder mix | jjc | Thermal | 6 | Dec 15, 2008 10:12 AM |
