Old Mar 17, 2012, 06:34 PM
bobdaeronort is offline
Find More Posts by bobdaeronort
"Five Easy Pieces"
United States, IN, Terre Haute
Joined Sep 2011
Originally Posted by mchldpy View Post
bob,
thank you for the file, naturally the m/fire link worked today.
thank you again,
michael clyde
Thank you.
media-Fire has had some tech probe of late.
I'm a paying customer now so I feel able to complain as well as praise.
You'll find the Five Easy Piece Raptor's an easy plane to build.
I wanna see your flight videos.
If you have any build questions though just let me know.
Bob
bobdaeronort is offline Find More Posts by bobdaeronort
Old Mar 18, 2012, 06:06 PM
"Five Easy Pieces"
Joined Sep 2011
Up and out on bright calm Sunday Morning and the ESC wire control melts with much smoke cutting the flight short.
F-22 Smoki'n Raptor.mov (3 min 20 sec)
Old Apr 09, 2012, 06:16 PM
"Five Easy Pieces"
Joined Sep 2011
last thirty days the FEP F-22 leads in downloads from my media-fire site.
File Name File Size Transfers Downloaders Bandwidth
1 FEP F-22.PDF 1.5 MB 75 62 94.28 MB
2 Five Easy Piece F-15.PDF 9.4 MB 45 36 353.27 MB
3 FENG SHUI J-20 Model (1).pdf 96.91 KB 26 21 2.58 MB
4 BERKUT HORNET PATTERN 01.26.12.pdf 1.36 MB 28 18 27.42 MB
5 BONE.PDF 1.55 MB 18 16 29.25 MB
6 F-14 MACH TOMCAT.PDF 2.44 MB 13 13 33.24 MB
7 PAK FA T-50 Pattern 12.02.11.pdf 67.44 KB 16 11 1.1 MB
8 FA-37 TALON pattern .PDF 2.21 MB 9 9 20.9 MB
9 Proflie Su-47 BERKUT v1.PDF 1.65 MB 7 5 9.44 MB
10 FENG SHUI J-20 SET-UP Model (1).pdf 41.15 KB 4 4 168.56 KB
11 f14tomcat_p1_tiled.pdf 2.44 MB 4 4 8.47 MB
12 BHP_p1_tiled.pdf 1.36 MB 3 3 4.28 MB
13 Knightsarrow Parkjet PATTERN 01.15.12.pdf 21.64 KB 1 1 22.16 KB
Old Apr 09, 2012, 06:37 PM
9XTremist is offline
Find More Posts by 9XTremist
San Bernacesspool
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
uh oh, a pakfa t-50, guess i'll go look at your blog. if not there i'll use the "google is not my friend" search function. if to no avail... i'llbeback.
michael clyde
edit -
t-50 = found
mig - 29 = not found
su-37 (flanker) = not found
the 29 & the 37 are imo the best & meanest looking aircraft bar none. from the fwiw department.
thanks for the t-50 i'm looking at an owens pink 1/2" x 48" w/s by 6' or so mid-mounted pusher with a scorpion II 3020-1110 that i've been itching to install. which of your 5th gen fighters do you think handles better the 22 or the 50?
thanks again
9XTremist is offline Find More Posts by 9XTremist
Old Apr 09, 2012, 08:07 PM
V-Man is offline
Find More Posts by V-Man
Airplane and Heli Flyer
V-Man's Avatar
Canada, QC, Montreal
Joined Dec 2009
Originally Posted by bobdaeronort View Post
and soon to be rendered F-18.
Got a rough ETA for that F-18? I'm looking for a quick build to fly after work near my place, this could be it.
V-Man is offline Find More Posts by V-Man
Old Apr 10, 2012, 09:14 PM
"Five Easy Pieces"
Joined Sep 2011
michael clyde
edit -
t-50 = found
thanks again
I had a decent setup on my 1st Five easy piece 44" Pak Fa but I've yet to get my 48" sorted out. I cut a new pattern for a 42" PAK FA that will use a three channel elevon set-up on for simplicity. IMHO the PAK FA with operating LERX was more nimble but really touchy. I like my simple 42" five easy piece F-22 three channel w/ elevons. It is easy to fly.
I like my five easy piece Su-47 berkut v1 and larger 3D v2 with active canards for fast and nimble flying.
I haven't rendered the Mig-29 or the others you mentioned in the FEP format as of yet.
Old Apr 10, 2012, 09:17 PM
"Five Easy Pieces"
Joined Sep 2011
Oh geee. I was working on it the other day. I think I have the nacelles and gizmo box sorted out. It's gonna be 48" long and use a 2200kv motor.
I'll post as soon as I can complete the build and maiden.
My new job just so cuts into my flying.
Old Apr 11, 2012, 06:56 AM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
i hate to admit it but, "LERX" stands for
michael clyde
Old Apr 14, 2012, 09:38 AM
"Five Easy Pieces"
Joined Sep 2011
michael clyde
No problem.
Leading Edge Root Extension = LERX.
I had to disable them on my PAK FA. I wasn't using them like real LERX anyway. I was trying to use them like canards which they are not. They are meant to maintain airflow over the wing and keep the nose down as the PAK FA like most fighters runs tail heavy. The were connected to the top arm of the elevator servo I tried to set them down a 1/4" when the elevator was neutral. Despite a stiffing rod the LERX would fail and bend up pitching the nose up so I would have to trim the elevator down to balance. Lottsa drag. So I cut 'em loose and taped them down.
Gonna build a 42" PAK FA the same size as my F-22 and use the smaller motor.
Old Apr 14, 2012, 09:46 AM
"Five Easy Pieces"
Joined Sep 2011
On the last flight low temp Hot glue on the motor mount melted as the motor warmed up and was drawn into the spinning motor shaft increasing the drag and amp draw till the ESC gave out and the black wire turned cherry hot and burned off the insulation and almost caught the role Raptor on fire. That's the debrief on the previous smoke'n raptor flight video. So new motor new 20amp ESC and all is well.
F-22 Raptor Skies.mov (4 min 40 sec)
Old Apr 15, 2012, 07:49 AM
San Bernacesspool
9XTremist's Avatar
Joined Feb 2010
thanks for the info
michael clyde
Old Apr 20, 2012, 02:25 PM
"Five Easy Pieces"
Joined Sep 2011
Here is the F-18 Glide testing
Glide Testing Mig 25 & 29 and F-18.mov (3 min 48 sec)
Old Apr 21, 2012, 02:19 PM
"Five Easy Pieces"
Joined Sep 2011
Here is my F-18E Super Hornet build thread.
http://www.rcgroups.com/forums/showthread.php?t=1636630
PDF Plans will be available soon.
Old Apr 21, 2012, 03:54 PM
V-Man is offline
V-Man's Avatar
Joined Dec 2009
Much obliged, sir.
(Though it's mostly for references as mine will be a CF-18 and will be smaller to fit the flying area better.)
Old Apr 21, 2012, 06:41 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I didn't get a chance to guess how many pieces, but this is a nice plane.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion F-15 EAGLE in "Five Easy Pieces" bobdaeronort Foamies (Scratchbuilt) 41 Sep 17, 2012 06:50 PM
Discussion Looking for someone to build my twin F-22 Raptor chicago IL sherlockshah Electric Ducted Fan Jet Talk 3 Feb 27, 2012 06:43 AM
Sold Sapac F-22 Raptor - Dual EDF - Lowered Price!!! omster Aircraft - Electric - Jets (FS/W) 3 Sep 26, 2011 02:58 PM
For Sale Starmax F-22 Raptor Jcopter Aircraft - Electric - Airplanes (FS/W) 2 Sep 16, 2011 08:02 PM
