Old Feb 14, 2013, 11:11 AM
Hungary Hajduszoboszlo
Joined Jul 2008
Hi,
Started to prepare my second F5J-400 competition season with Open9X.
I plan to fine tune my settings, if somebody interested i can share my program for competition plane.
Also I managed to use the trainer setup to mentor my friends with an easy glider.
Its worked flawlessly and can be set within 5 min.
BR
Tamas
Varicopax is offline Find More Posts by Varicopax
Old Feb 14, 2013, 12:05 PM
LI, New York, USA
Joined Mar 2003
Thanks for the update. I am sure someone will take you up on your offer.
aeajr is offline Find More Posts by aeajr
Old Feb 14, 2013, 03:22 PM
Quincy Fl
Joined Aug 2010
Turnigy
If you want you can add to here BUT that will make you the Turnigy Guru!
http://www.rcgroups.com/forums/showt...8&goto=newpost
tlar633 is offline Find More Posts by tlar633
Old Feb 17, 2013, 07:35 AM
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
Tamas
I just finished flashing my Th9x and converting to FrSky modules and am ready to start programming. The first thing on the list is an electric sailplane for ALES/F5J so your offer to share your program would help me a lot.
John Lueke
John Lueke is offline Find More Posts by John Lueke
Old Feb 17, 2013, 03:01 PM
Port Elizabeth. South Africa
Joined Aug 2010
Templates available here
http://9xforums.com/forum/
WaynejG is offline Find More Posts by WaynejG
Old Feb 17, 2013, 04:39 PM
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Well I know I am blind and I could not find them...
Here are my templates. I have not tested the Windsong (e-powered) configuration with Open9x (it flew fine using ER9x before I migrated to Open9x).
The Windsong is a 134" span 3 servo wing - 1 flap servo, 2 aileron servos, 1 rudder, and 1 elev servo. It has crow and slow motion flaps (down) so you can see how that was done as well as various different elevator mixes for flap, motor, etc. If I remember correctly I used a curve to create my own aileron differential, there is a built in function in the release to simplify that now. Not included is an Airtronics legend that is 4 servo wing - I have not moved that one to Open9x.
Two 4 channel MRES electric powered Sagittas, one that uses Rudder dual rate switch for flight thermal mode, a Gentle Lady, a Craft Air Viking, a test mode - you can use that to cycle servos - remove any prop from electric powered craft until you understand what it does.
Scott
This is NOT a zip file but I attached it as a zip (just remove the .zip) so that I could place it here... Then open the file in Companion 9X
ScottSails is offline Find More Posts by ScottSails
Old Feb 18, 2013, 02:17 AM
Joined Jul 2008
Give me 1 or 2 days and i will create a "switch map" picture also.
BR
Tamas
Old Feb 18, 2013, 07:54 AM
LI, New York, USA
Joined Mar 2003
Template library?
http://9xforums.com/forum/viewforum.php?f=38
Old Feb 18, 2013, 04:11 PM
ScottSails's Avatar
Upstate NY
Joined May 2005
Looks like there are some nice templates there with notes...
Scott
Old Feb 24, 2013, 06:37 AM
LI, New York, USA
Joined Mar 2003
I just want to thank everyone for their continued support and contribution to this discussion. Keep it coming for the benefit of new glider pilots looking for a low cost glider radio.
Old Feb 27, 2013, 01:23 PM
Joined Jul 2008
Sry i am very busy, so here is my switch setup for my 9x for competition.
Let me know your opinions, I use this for all of my gliders and works quite well for me. In the future i plan to add a variable to mix for ail to rudder for one of the pot meters and maybe some variable elevator compensation for butterfly or throttle for the remaining potmeter. And also maybe snap flap.
Old Feb 27, 2013, 01:28 PM
Joined Jul 2008
Hoooopss. I almost forget the program, the glider name is Respect .
Its an old revision it needs an update for the latest companion.
BR
Tamas
Old Apr 03, 2013, 08:48 PM
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Apr 09, 2013, 01:55 AM
Joined Jul 2008
Hi,
Check the manual, search for differential.
http://code.google.com/p/open9x/down...x%20Manual.pdf
Its explain the differ curve now.
Alternative option to get more mixes to upgrade your radio with atmega128, I not remember by how many but its should be enough, also increase flight phases and curves and everything.
If you are familiar in electronics and soldering its not a big deal, you can order it from digikey or farnell. Only setting the fuses is tricky.
BR
Tamas
Old Apr 18, 2013, 08:10 PM
Closed Account
Joined Aug 2011
Discussion Turnigy 9X - for sailplanes? aeajr Radios 19 Mar 05, 2012 09:43 PM
Help! Turnigy 9X Full throttle really full throttle? Kamu Radios 3 Dec 28, 2010 03:35 AM
Discussion Anyone flying Aurora 9 with full house ship? 12ten Sailplane Talk 208 Jun 18, 2010 06:50 AM
Discussion Opinions on best 7-ch 2.4 GHz radio for full-house sailplanes Forest Flyer Sailplane Talk 29 Oct 12, 2008 09:10 PM
anyone flying full house photon II ? wing warrior Hand Launch 3 May 01, 2005 11:31 AM
