Old Mar 03, 2012, 10:49 AM
Alan W is offline
Find More Posts by Alan W
Alan W's Avatar
NY
Joined May 2000
Moldie Aileron servo install help needed ...
Im sure this has been covered a bazzilion times but my search didn't turn up anything ...
Looking for the "modern" way to install an aileron servo into a molded wing. Last time I did this was about 10 years ago ... then I Shrink-wrapped the servo's, roughed up the inside surface a bit and I "think" I used epoxy to glue it down ...
... Is this still a suggested method ? Anything better than epoxy to suggest - i.e. goop, silicone based glue ... etc ?
I thought of potting them but there isn't enough clearence to work in there as the covers want the servo arm in the center of the hole meaning about 1/3rd of the servo is tucked inside.
Appreciate advice or links to such
Alan W is offline Find More Posts by Alan W
Old Mar 03, 2012, 11:14 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
That's still a great way to do it.
You may find this thread will open a real can of worms. At the end of the day there are as many ways of doing this as there are modellers it seems...
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Mar 03, 2012, 11:39 AM
flyzwell is offline
Find More Posts by flyzwell
flyzwell's Avatar
So Cal
Joined May 2008
I've had servos pop loose from epoxy on hard landings so I use Goop.
I wrap them in blue painters tape, but shrink wrap should work just as good if not better.
flyzwell is offline Find More Posts by flyzwell
Old Mar 03, 2012, 11:45 AM
BigSwede is offline
Find More Posts by BigSwede
Ninja Master
BigSwede's Avatar
United States, CA, Thousand Oaks
Joined Feb 2007
I don't like using epoxy, others have had success with it though. I also wrap servos with painters tape, but I use Bob Smith Rubberized CA. Goop works well, as does silicone adhesive. I've heard that the silicone vapors are bad for electronics, but I don't know about that. The CA is fast, which I like. The best way though, in my opinion, are servo frames. They don't always fit in some installs though.
BigSwede is offline Find More Posts by BigSwede
Old Mar 03, 2012, 02:27 PM
flyzwell is offline
flyzwell's Avatar
So Cal
Joined May 2008
If you use the painters tape it needs to be cleaned off with rubbing alcohol to remove the release agent, then lightly roughed up with some sandpaper.
Old Mar 03, 2012, 07:42 PM
bluzharp is offline
Find More Posts by bluzharp
setting CG with ceiling fan on
bluzharp's Avatar
USA, CA, Bakersfield
Joined Apr 2010
I do not use blue masking tape. The beige sticks better and lasts longer. The blue is meant to not hold as well. A bit of alcohol or acetone to clean the release agent from the back of the tape and you're ready to use whatever glue.
bluzharp is offline Find More Posts by bluzharp
Old Mar 03, 2012, 09:18 PM
SethPenery is offline
Find More Posts by SethPenery
SethPenery's Avatar
Eldorado CA
Joined May 2010
Us ds guys trust a nice dab of gorilla Ca in the middle of the servo and around the outside of the servo where it contacts the wing. Holds up while flying in the 3 to 400mph. And with some delicate work can still be removed if servo failure occurs.
SethPenery is offline Find More Posts by SethPenery
Old Mar 04, 2012, 07:59 AM
Brian Kloft is offline
Find More Posts by Brian Kloft
Windy City Flyer
Brian Kloft's Avatar
Chi Town
Joined Jul 2004
Not sure what plane that is but I know there is an insert (looks like a small tuna can) that might fit right into that wing. I cannot remember what website had them but I know they are out there. Worth a look.....
Good Luck,
Brian
Brian Kloft is offline Find More Posts by Brian Kloft
Old Mar 04, 2012, 02:48 PM
kpeevyhouse is offline
Find More Posts by kpeevyhouse
Sane til the lift starts!
kpeevyhouse's Avatar
Laguna Beach, CA
Joined Jun 2008
Good Luck,
Brian
You mean like this one? Might be too thick for a moldie wing.
http://www3.towerhobbies.com/cgi-bin...?&I=LXN690&P=7
kpeevyhouse is offline Find More Posts by kpeevyhouse
Old Mar 04, 2012, 03:01 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Some good tips about using the "tape first" method of fixing servos here!
My current preferred method is to first make a channel to fit the servo with a front and back ledge that rises to the level of the servo. I do this on my vac bagged wings by using a small piece of wood the same size as a servo wrapped in cling wrap as the "plug". The use microshperes/epoxy splooge to cast the shape around it.
When cured, remove the plug and cling wrap and press the servo into place. A few spots of hot melt glue is all that is required to retain it. To remove later, simply heat a piece of wire and melt the glue. If preferred, splooge can be used which is easy to dremel away for servo removal.
For a moulded wing, the channel can be made from suitable wood blocks glued to the wing skin.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Mar 04, 2012, 09:21 PM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Epoxy, no tape and don't roughen or clean the servo case. Holds fine and will pop out with a bit of effort if needed. use just enough epoxy to make a tiny lip round the bottom of the sevo case.
mr_editor is offline Find More Posts by mr_editor
Old Mar 05, 2012, 08:29 AM
Alan W is offline
Alan W's Avatar
NY
Joined May 2000
Appreciate all the advice ...
Are you guys preferring Gorilla Super Glue to Goop because of its "Tiny Rubber Parrticles ..." ?
Old Mar 05, 2012, 08:50 AM
Joined Dec 2005
Jim.
I like that.
I now only use hot melt glue to fix the servo into the lower skin (preferably using a plug or blocks as per Jimbello above), then I epoxy a bridge (ply or thin steel, depends on the space available) across the top to tie the servo into the top wing skin as well. Should the servo need replacing, the bridge is relatively easy to break out, then there's only hot glue to contend with. The top bridge is the biggest advance in my installs yet, it stops flex and control slop dead in it's tracks.
Old Mar 05, 2012, 09:04 AM
winchdoc is online now
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
what about mounts?
Did I miss something here?
What about making mounts?
You can make the from 1/4" basswod and box the servo in.
Notch out for the tabs, and you are good. You can even use a wood screw as long as it is short enough as not to poke out the top surface.
WinchDoc
who cuts wood once in a while too
winchdoc is online now Find More Posts by winchdoc
Old Mar 05, 2012, 04:15 PM
Joined Aug 2008
Wing servos - best mounting.
I think mounts are the very best for "proper" wing servos. I've never graduated from cheap (reliable) chinese servos with regular mounting tabs, which I cut off.
One day I'll buy some expensive wing servos and mount them like you describe.
I don't want to drift this thread into yet another chapter of the "great servo debate", but so far my cheapies are providing valiant service!
Jim.
Discussion Control Horn Install - Hollow Plywood Aileron Gamerjoe The Builders Workshop 5 Dec 21, 2011 02:23 AM
Discussion Aileron/Servo adjustment Help? Dale 813 Radios 3 Nov 07, 2011 09:51 AM
Question Aileron Servo Install with one servo per aileron? Brownie433 Beginner Training Area (Fuel) 4 Aug 05, 2009 10:10 PM
Discussion Aileron servo install Ewok Foamies (Kits) 8 May 14, 2009 04:17 PM
Help! Magpie Aileron Servo Installation Help Needed! mook Foamies (Kits) 4 Jan 13, 2008 01:27 PM
