Old Mar 03, 2012, 10:31 AM
texasdrifters is online now
Find More Posts by texasdrifters
Joined Apr 2011
Aileron Does Not Work with Guardian
Bill or anybody that can offer help,
I am in the final stages of setting up my Eagle Tree system and I am having a problem with the ailerons working when the Guardian is turn on. I have a skywalker and video, audio, and all functions work fine. When Guardian is turned off, "Configure Radio Controls/Stabilization/Elevon Mixing On?" parameter selected "off". All control functions work fine. However, when I select "on", the ailerons will not function. All the other control surfaces work, but not ailerons. When I select "off", all is OK. I have tried manipulating the Overall Guardian gain with no response.
Any help is appreciated.
Hector
texasdrifters is online now Find More Posts by texasdrifters
Old Mar 03, 2012, 01:32 PM
Joined Apr 2011
Hector
I believe I solved the problem with equipment replacement. I installed a spare OSD module, uploaded the software, ran servo wizard. All works as expected.
I ran servo wizard several time with the original OSD, but the aileron would not function with Guardian turned on.
I will contact Eagle Tree for repair.
Hector
Old Jul 14, 2012, 10:55 PM
NhutSgn is offline
Find More Posts by NhutSgn
Joined Jul 2012
Please help
Hector
Hi Hector,
I am new to FPV and have installed Eagle Tree with Guardian. Mine, I think, is the same with your system. At first, only elevator don't work but later on, aileron also don't work. How did you solved this promblem? Pls share as FPV is new hobby in Vietnam and nobody has ever experienced.
Thanks for your soonest support.
Nhut
NhutSgn is offline Find More Posts by NhutSgn
Old Jul 18, 2012, 01:55 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
NhutSgn, could you please click "Factory reset" on the OSD Pro setup page in the PC software, and then reconfigure your OSD, and run the servo analysis wizard again?
if that doesn't work, could you please save your OSD configuration (.TXT file) from the OSD Pro setup page, and attach the .TXT file here? Thanks.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jul 20, 2012, 04:53 AM
NhutSgn is offline
Joined Jul 2012
Hi Billpa,
My trouble is because the sticks had been centered before the counter reached "0" when I run the servo analysis wizard. The problem was fixed after I have the sticks centered timely.
Thanks for your reply.
Nhut
Discussion Lawmate receiver 1280 on channel A? B does not work surf1punk FPV Talk 16 Feb 15, 2013 01:43 PM
Discussion HPP-22 update does not work Kimi Hitec/Multiplex USA 5 Nov 14, 2011 10:09 AM
Help! HEX config using Pro and GPS does not work cicadafx Hoverfly Technologies 2 Oct 23, 2011 10:18 PM
Question FlyDream failsafe does not work John Kim Power Systems 1 Oct 04, 2011 08:30 PM
Question FlyDream failsafe does not work John Kim Radios 4 Oct 04, 2011 07:40 PM
