This thread is privately moderated by chiloschista, who may elect to delete unwanted replies.
Old Mar 03, 2012, 09:19 AM
chiloschista is offline
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Proxima II ! My most complex UDB4 plane. A tribute to Bill Premerlani
Hi all,
after a lot of research, programming, setting and tuning, I'm proud to announce that my Proxima II went in flight.
It was already, but without any autopilot, only to set the right controls, trims, CG and wings angle of attack.
Now it is fully autonomous. This is the more complex autopilot equipped plane I ever build.
Here you can see the plane in full action.
Proxima II ! (3 min 20 sec)
In this video there is a demonstration of the controls possibilities.
Proxima II functions (4 min 1 sec)
The pilot has the following controls over the plane :
  • throttle
  • elevator
  • rudder
  • ailerons, differential !
  • flaps, with those functions : thermal flaps, crow flaps
  • autopilot mode
  • coming next will be camera pan / tilt and camera mode controls
Possibilities are :
  • roll control over two (ailerons) or four surfaces (ailerons and flaps)
  • camber control over four surfaces (I could program it over two surfaces too, but actually I don't need it)
  • crow flaps, with roll control over two or four surfaces
  • fine trimming of both ailerons and flaps for roll or camber
About the plane :
Proxima II, 2.78m, Selig 3021 (Reichard)
MVVS 3.5 / 1200
Castle Creations ICE 50A ESC
Thomas Scherrer RC system
UavDevBoard 4 stabilization / autopilot unit
And finally an amazing board that allowed me to have all those functions mixed with the autopilot.
FpvKiwi Channel Wizard
This mixer is incredibly flexible in programming.
It is fed with PPM stream from RC rx. The UDB is daisy chained to it and feeds back to it again ailerons control for stabilization and autonomous flight.
Attached are the schematics of all the connections :
Here you can watch some more pictures of the plane.
Next plans are to mount a video system and use it as an FPV platform, for long time flying using thermals.
This plane is dedicated to Bill Premerlani, as a tribute to him for starting this amazing adventure, for all the improvements he achieved and for letting me the privilege to travel a short distance on this long road with him.
Thank you Bill !
Best regards,
Ric
chiloschista is offline Find More Posts by chiloschista
Old Mar 03, 2012, 03:30 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
Interested to know what video and rc frequencies you'll be using?
Also what part of NZ are you from, I'll be working there for six months later this year.
tobermei is offline Find More Posts by tobermei
Old Mar 03, 2012, 03:31 PM
tobermei is offline
Joined May 2008
Woops, just saw your location is switzerland. Sorry about the NZ reference, I thought the board with 'kiwi' indicated NZ
Old Mar 03, 2012, 04:37 PM
Switzerland
Joined Feb 2008
Hi tobermei,
yes, Switzerland, so a bit far away from your location (16341 km).
Video equipment still has to be defined.
I don't know if I'm going to use a Gopro (I don't like the rolling shutter), or a CCD cam. Camera turret ? I like to look around, while doing FPV.
Frequency ? Still to be decided. I have the choice between 2.4GHz, 5.8GHz or 1.3 / 1.2 GHz.
Best regards,
RIc
Old Mar 03, 2012, 05:03 PM
tobermei is offline
Joined May 2008
Thanks.
Old Apr 09, 2012, 09:03 PM
b5ff is offline
Find More Posts by b5ff
Joined Mar 2006
Hi choloschista. I was flying a Proxima II as an FPV ship on autopilot, until this past weekend when it autopiloted itself into a remote, rugged mountain, the exact location of which I'm not sure.
I was using an APM with AP2.24 software, and FM RCRx (JR Tx and SL-8 Rx) and a 900MHz Vtx/ground station. I'd had many flights on it and was very happy with the performance. In a remote environment (away from urban or microwave RF noise) I was able to fly > 3km and have solid video and RC control.
I used a GoPro (no enclosure) as a wing camera. Initially I used it as the FPV camera, but it has a tendency to cut out so I started using a nice FPV camera a few flights before its final flight. I was flying a 4S power setup at about 800W which made for nice fast launches with 2.65, 4.9 or 5.3 Ah packs.
The Proxima II is a real pleasure to land - it's so well-mannered on approach. It was never a stellar thermal ship, especially after I strapped the GoPro to the wing. It will be greatly missed, as will all the tricked-out goodies I had it loaded up with. I have a high-performance glider to replace it with but am considering also building up another, less expensive glider. I might even try the Sirius, which looks like the Proxima's slightly bigger sister.
b5ff is offline Find More Posts by b5ff
Discussion Proxima II Reichard Model hladas94 Electric Sailplanes 234 Jul 17, 2013 03:33 AM
Discussion **Katie Martin Tribute Fly-In II, Torrey Pines** June 9th PropWorks West Slope 174 Feb 04, 2013 02:56 AM
Sold Proxima II 2.8m full-house electric glider Marcelz Aircraft - Sailplanes (FS/W) 6 Jul 09, 2009 09:17 PM
Discussion Which motor fo Proxima II Wilbrod444 Electric Sailplanes 9 Dec 11, 2008 05:17 PM
