Old Mar 03, 2012, 09:09 AM
bnb2fly is offline
Find More Posts by bnb2fly
Joined Mar 2012
Help!
Need help setting up my tx/rx
I have had my hausler 450 V2 for a while now and I wanted a new tx/rx combo. So I went out and got a walkera devo 7 and rx 701. I have been trying to hook it up to my heli and for some reason I can not get my three servo's on the swash plate to coinside with each other. how do I hook up the rx and/or setup the tx to make it work?
bnb2fly is offline Find More Posts by bnb2fly
Old Mar 03, 2012, 09:34 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
First step is to select the proper swash type - 3 servos 120*
Next plug the servos into the proper slots on the rx. If the Hauler is a clone of the Align 450, then front right servo is the ail, front left servo goes to aux and rear center goes to elev. Left and right side of heli designation is where the nose points away from you.
Next make sure each servo moves in the right direction by using the servo reversing menu
Finally, to get all three servos to move together properly, reverse the direction of travel in the swash mix menu. If the front two servos move up and the center servo moves down, then in the swash mix menu change it from +60 to -60, for example.
Best suggestion, review Finless Bob's videos over at Helifreak.
http://www.helifreak.com/showthread.php?t=11373
chopper62 is offline Find More Posts by chopper62
Old Mar 04, 2012, 08:23 PM
bnb2fly is offline
Joined Mar 2012
Thank man now I got that fixed I cant get the tail rotor to work with the tx. I have tried many of combos with the tx/rx and nothing works.
Discussion Need some help setting up Elevon in Dx6i FoamieFlier Foamy EDFs 3 Jan 06, 2012 07:59 AM
Help! Need help setting up heli wildone Electric Heli Talk 2 Nov 25, 2011 03:27 PM
Discussion help with setting up my tricopter. imdone Multirotor Talk 2 Oct 10, 2011 06:44 AM
Help! Exceed RC 2.4GHz Tx and Rx Setting's Messed Up - HELP Please!! WillSwain95 Radios 2 May 31, 2010 04:40 AM
Discussion I need help setting up my dx7 as a master trainer of my dx6i lazer155 Radios 14 Oct 14, 2009 11:53 AM
