Old Mar 04, 2012, 07:47 PM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Does the S800 come standard with landing gear? The DJIUSA website shows it with & without.
Is it just me, or does it seem like this announcement was made with about 10% of the necessary information?
Jack
jforkner is offline Find More Posts by jforkner
Old Mar 04, 2012, 08:07 PM
piccoloflyer is offline
Find More Posts by piccoloflyer
Australia, New South Wales, St Leonards
Joined Aug 2009
Originally Posted by Tahoe Ed View Post
If I go there, I already have several 6S lipos, 5000mAh, that I can connect in series.
It will double the c rate of a single battery if two are connect in parallel so 25C or 35C 6S can be used, saving a lot of money , two batteries from DJI will cost you a brand new NEX5
piccoloflyer is offline Find More Posts by piccoloflyer
Old Mar 04, 2012, 08:13 PM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
Tony you are missing point its just a small camera which can be carried with far less then that but I really did not figure you would know that being you have never done aerial photography or posted any aerial videos.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Mar 04, 2012, 09:23 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Michael64
Well maybe some day I will be as good as you
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Mar 04, 2012, 09:27 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
oops I missed that thanks.
Originally Posted by Z06 Tony View Post
I asked and Sidney said it comes with 15" CF props. Look up a few posts LOL
saabguyspg is offline Find More Posts by saabguyspg
Old Mar 04, 2012, 09:28 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I know you know... just yankin your chain
Steve
I knew what I meant to say, I just didn't say it. I think 12S would be a little much. Takes me back to my 700E heli days. Man what a spark from them deans.
Old Mar 04, 2012, 09:56 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
Originally Posted by BorisSA View Post
Hi Sidney,
after having two bigger WKM copters Hexa 900mm and a CS 8 I came to the point the i get better results with higher and when it comes to stability and finding the right gains setting especially when a little wind impacts the frame, smaller props 11 or 12 light weights are the only way to go. Are you guys changing something in the whole WKM FW algorithm etc. PIDs whatever you want to call it, withe release of the S800, or are we getting some additional variables to tune WKM for lower Kv/bigger prop combos ?
Boris
Hi Boris, it a matter of matching props and motors, and yes the right gains.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Mar 04, 2012, 10:07 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
Hi Sidney,
thanks for the answer. So you would recommend us if we dont want to switch to the S800 right away, since we already have 5 grand plus setups to copy the motor prop setup you guys have on the S800 ?
S6 voltage to get the RPM back etc ?
Boris
BorisSA is offline Find More Posts by BorisSA
Old Mar 05, 2012, 12:44 AM
BorisSA is offline
Joined May 2011
How much do you pay for quality batts? HK charges $117 for a NanoTech 65c 5000mAh 6s batt x 3=$351.
A Hyperion 5000mAh 45c 6s is $200 x 3=$600
I would say considering this the price is not bad at all.
I would be interesting to know how heavy that 15000 mAh 6s Lipo is that DJI recommends. This could be an interesting option little more pricey.
Considering that a 4s 11000 mAh ways 820 g http://www.maxamps.com/Lipo-11000-148-Pack.htm
and the 6s 11000 mAh ways 1.2 kg http://www.maxamps.com/Lipo-11000-222-Pack.htm
if there is a significant weight difference tot he DJI 6s, thus flight times would be similar i would prefer taking up less weight all together and bringing down the current
Boris
Old Mar 05, 2012, 12:49 AM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
I would be interesting to know how heavy that 1500 mAh 6s Lipo is that DJI recommends. This could be an interesting option little more pricey.
Considering that a 4s 1100 mAh ways 820 g http://www.maxamps.com/Lipo-11000-148-Pack.htm
and the 6s 1100 mAh ways 1.2 kg http://www.maxamps.com/Lipo-11000-222-Pack.htm
Boris
If the setup is running 6s and you go down to 4s you would have to go up in prop size. Kinda defeats the purpose of this whole setup. As Sidney just mentioned its a matter of the right prop,motor combination but he forgot to mention current also.
You would lose alot of lift going down to 4s and I am guessing it would wobble.
Site Sponsor
Old Mar 05, 2012, 01:04 AM
BorisSA is offline
Joined May 2011
Well thats the reason why i also linked the 6s lipo whos weight reatio is based on the same cells like the 4s which is astonishing for 820g 11000 mAh
sorry got the mAh wrong before
Edit ( as a comparison a 4s 6000 mAh nano weighs 623g )
Old Mar 05, 2012, 04:22 AM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
We really need some picturs of the final product, in some pictures it seems that the top plate is in carbon and others its like the 450 and 550 flamewheels!
Spyde is offline Find More Posts by Spyde
Old Mar 05, 2012, 08:26 AM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Old Mar 05, 2012, 08:31 AM
sidneyw is offline
DJI Zenmuse S800 Spreading Wings test flght (3 min 29 sec)
Site Sponsor
Old Mar 05, 2012, 08:33 AM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Is that a yes?
Discussion Report on CC's Phoenix 25 ESC's multi-rotor firmware & the WK-M Quad-Copter tkeeg Castle Creations 388 Dec 09, 2015 04:39 AM
New Product DJI-WKM Multi Rotor Test and Eval musicwarrior Multirotor Talk 27 Oct 14, 2013 09:39 PM
Wanted WKM DJI - DJI Wookong Multi-Rotor System controller stabilizing rui eduardo Aircraft - Electric - Multirotor (FS/W) 2 Mar 14, 2012 08:26 AM
Wanted WKM DJI - DJI Wookong Multi-Rotor System controller stabilizing rui eduardo Aircraft - Electric - Multirotor (FS/W) 0 Feb 28, 2012 05:05 PM
