Old Sep 17, 2012, 10:00 AM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Originally Posted by hugy View Post
You must have the wookong connected, so it is somewhere on the gimball.
And that's why he gave this description on the video?
"Zenmuse Z15 autonom, compatibel with any flight Device"
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Sep 17, 2012, 10:02 AM
logicwins is offline
Find More Posts by logicwins
FPV FTW
Austin, TX
Joined Dec 2004
Questions about Futuba 8FG and R6208SB
Is it possible to use the servo output on the R6208 for the zenmuse while using S.bus for WKM/S800?
I only have 3 channels left and was wondering if I could reassign the sbus channels so I can plug in all of the zenmuse servo leads and have full functionality.
Any help much appreciated!
logicwins is offline Find More Posts by logicwins
Old Sep 17, 2012, 10:17 AM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Can GH2 Zen users please share their gains?
quadslo is offline Find More Posts by quadslo
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
The whole gimball is autonome if you put the wookong on the gimball. You don't have to use the wookong as your flight controller.
hugy is offline Find More Posts by hugy
Old Sep 17, 2012, 10:36 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
Okay, easy question then: Where is the WK-M in the video?
Old Sep 17, 2012, 10:57 AM
hugy is offline
hugy's Avatar
Joined Apr 2010
The video is a bit low res, but it looks like it is on the backside. When he turns you can see there is more behind the lipo box.
Old Sep 17, 2012, 04:47 PM
hugy is offline
hugy's Avatar
Joined Apr 2010
Just some testing in the woods.
zenmuse forest testing (1 min 5 sec)
Old Sep 17, 2012, 05:54 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
s800 + z15 + WKM ordered and payed
and 6pack with 6s 5000mAh Nano lipos ordered also.
*sit down for 2-3 weeks and wait*
liteglow is offline Find More Posts by liteglow
Old Sep 17, 2012, 05:57 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
@ liteglow, it is worth the wait.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Sep 17, 2012, 06:01 PM
leemann is offline
Find More Posts by leemann
Canada, ON, Toronto
Joined Feb 2012
So is the final word right now on the radio setup for the s800 and z15 is 2 Futaba 8FGs? I have a DX8 at the moment but I would like to easily switch between a 1 and two person setup.
leemann is offline Find More Posts by leemann
Old Sep 17, 2012, 06:06 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I am using 2xJR9503 with 2xR921 Rx. I think I could get away with a 8 ch on the flight controller and a 7 on the gimbal control. But right now to control every function it takes 2x8 channel or you could try a 14 channel if it has enough switches.
Site Sponsor
Old Sep 17, 2012, 06:42 PM
leemann is offline
Canada, ON, Toronto
Joined Feb 2012
Thanks for the info. How easy is that to switch between a one and two person setup. I am looking mostly for the ease at which I can switch between 1 and 2 person.
Old Sep 17, 2012, 07:03 PM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
My 1st "real" world test.
Hard Hat Area-Aerial Shot in A Construction Site In Azure (2 min 28 sec)
Ab74 is offline Find More Posts by Ab74
Old Sep 17, 2012, 08:53 PM
a1ik is offline
Find More Posts by a1ik
a1ik's Avatar
Canada, ON, Vaughan
Joined May 2011
Originally Posted by EndOfDays View Post
Hello,
Here a short description of what I did to balance for the new lens:
It turned out, that I had to lower the COG on the cam, which I did by adding 10gr on the backside of the display.
Ferdinand
Ferdinand, you are the pioneer of Z-15 rebalancing. You inspired me to rebalance my Z-15 to accommodate my Zeiss Sonnar E 24mm f/1.8. Without your successful tests I wouldn't touch it. I did the rebalancing starting with tilt, then roll and finally pan - i.e from the camera to the base. To balance the pan I had to put the gimbal/landing gears assembly on its side. I managed to get away w/o any additional weights. For each axis I was able to locate adjustment points that allowed to move the parts in pretty big range achieving needed balance. I have not tried to power it up yet but off-power tests look good. So I am wondering why you had to use some lead? Different design?
Thank you,
--Alik
a1ik is offline Find More Posts by a1ik
Old Sep 17, 2012, 09:02 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I am trying to figure that one out. It appears that a 14 channel tx is required for a one man operation, unless you sacrifice all control of the gimbal.
Site Sponsor
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
