Old Sep 15, 2012, 02:29 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
Assignment one man operation
My flight controls as much as possible are on the left side and gimbal on the right
Futaba 8fgs
Starting left to right
sf=fpv mode up or down (only gimbal control on left)
se= off/course/poi
sa=gps/atti/man
sb=standby/neutral/go home
ld=pan sub trim
rd =roll
sc=h trace/reset/h free
sd= tilt up/down
sg= pan l/ pan r
sh= shutter
2 man is same
except sf operates the trainer mode. (may make it sh)
The way the trainer option works is easy once you have it going.
i am using a wtr 7 which gives are wireless link between 2 transmitters. (upto 7 channels on trainer )
I have the setting for 2 man as above.
With trainer mode enabled
using the mix function I remap the elevator and rudder controls of the 2nd controller to the gimbal pan and tilt controls. I also make them vpp (rather than elv and ail as this allows me to change the curves and make the pan and tilt to be much smoother at start and end of the move.
I remap any other control (upto seven) so the camera op can start the camera ajust roll etc etc.
hope this helps
fb
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Sep 15, 2012, 02:35 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
I see, so the WTR 7 is the Futaba wireless trainer link.
Guess, I need to get one of those.
Thanks for sharing that in such great detail.
UAVProducts is offline Find More Posts by UAVProducts
Old Sep 15, 2012, 02:45 PM
Joined Apr 2012
yes I guess you can go hard wired, but this nice to have upto 30 ft away.
Old Sep 15, 2012, 03:02 PM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Cool. Thanks, flyingbiscuit1.
AEMontoya is offline Find More Posts by AEMontoya
Old Sep 15, 2012, 03:13 PM
Joined Apr 2012
Originally Posted by smudg View Post
Has anyone used Maxamps LiPo 11,000mah 6-Cell 22.2v with their S800/Z15? I'm interested in hearing everyones opinion...
Yes I have one, it's ok one of the cells seems to be low and it takes a long time to balance, I fly conservatively and land at 3.6 I get about 12 minutes of flight time, (fully loaded) but I think I will get longer when I have finished tweaking.
I think its a good battery for the s800 but very expensive, I am going to try the dupu once I can find a way of getting them from china, they are 1/3 the cost, I would rather have 3 of them than one max amps, (although they are yet to be tested here)
Old Sep 15, 2012, 06:36 PM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
Wow! Those maxamps 11000s are really expensive!
DUPU 10400 is also available in Taobao, btw.
http://mydupu.taobao.com/search.htm?...&queryType=cat
Ab74 is offline Find More Posts by Ab74
Old Sep 15, 2012, 06:49 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
Anything close to the lipo price was more than that when I was in China for 17 months, and they were 15C at 1,000 pc/lot. Let's see how they work out .... keep us inform.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Sep 15, 2012, 08:45 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
15c
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Sep 15, 2012, 09:27 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by EndOfDays View Post
@rsun77
welcome to the club (of non-S800 Z15-flyers) mine has 4,3kg AUW, I am not sure if it is possible to build a multirotor with retracts (and Z15) with AUW below 5kg.
best regards
Ferdinand
Ferdinand - what are the specs on your hex? I'm looking for some none S800 airframe options for use with the Z15 but not seen anyone posting what sort of setup,they are using in therms do motors, frames, etc.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Sep 16, 2012, 03:22 AM
fritz99 is offline
Find More Posts by fritz99
Joined Apr 2012
Di you order some pieces ?
I would but do not know how because I cannot read chinese.
Fritz
fritz99 is offline Find More Posts by fritz99
Old Sep 16, 2012, 04:05 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
@flightlab
Motors:
http://www.hobbyking.com/hobbyking/s...ter_Motor.html
Escs Hobbywing 30A
Props: Graupner 14x8 E-Prop
Carbon Hex Frame 800mm m2m 500gr:
http://www.kopterframe.de/shop/produ...products_id=36
I run on 4S8000 (750gr Zippy) gives about 10-12min flighttime,
AUW with Video Downlink with batteries but without langing legs: 4300gr
This setup is ok up to 4500gr. If you add more equip, add more weight it will not work.
Please let me state, that this is not a recommended copter for the Z15, use at your own risk, DJI recommends the S800.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Sep 16, 2012, 04:09 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Thanks. The motor link isn't working however.
Site Sponsor
Old Sep 16, 2012, 05:43 AM
Topper_MUC is offline
Find More Posts by Topper_MUC
Germany, BY, Munich
Joined Jan 2012
Originally Posted by Knilch View Post
Don't know why someone would fall for some brand names, though. I don't know how many factories are producing the actual LiPo cells themselves but there aren't many. So the cells in your insanely expensive Hyperion or ThunderPower batteries might actually be the same as in the "cheapo" Zippy or Turnigy batteries.
In fact I have better reliability with these cheap cells than with some more expensive ones and I am not alone.
So I don't know why I should buy some LiPo from a German brand (in my case) if I can just source the batteries from their origin myself without all the margins for different resellers bleeding into the resale price.
One fact that speaks for the 11000 Maxamps is the low weight for the amount of MHa you can use. 1280 gr. is quite low. I have very save 15 minutes with them, 17 minutes with 20% left in the Lipo.
The reason to go for "German" Lipo brands start when traveling with S800/Z15 and Lipos. You will never ever get any large 6S HK lipos into a plane, you have to have written certificates that are not available for any of those HK Lipos.
Same counts for any Lipos > 5000. So you alway need to decide your preferred Lipo Brand and Size according to your further plans od usage.
Topper_MUC is offline Find More Posts by Topper_MUC
Old Sep 16, 2012, 07:46 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
Are there any reason to not fly with 2x5000mAh packs of this one:
http://www.hobbyking.com/hobbyking/s..._6S1P_25C.html
does anyone here fly with Turnigy\Rhino\zippo ?
25c should be OK to use on the s800 z15 ?
liteglow is offline Find More Posts by liteglow
Old Sep 16, 2012, 08:12 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
I just purchased 4 6S 25-50C 5000mAh Turnigy Nano-Tech lipos. I have never had a problem with them.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 11:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 11:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 07:44 PM
