Old Sep 07, 2012, 07:32 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Originally Posted by UAVProducts View Post
A little off topic.
Can some share their workflow with the NEx5n on Mac for FCPX?
Also, camera setup workflow before flight?
Thanks and sorry for the slightly off topic questions.
Camera setup:
-format card
-set frame rate and shutter speed for desired look.
-set ISO and f-stop (auto iris is bad) for proper exposure and to achieve largest DOF possible
- white balance
- set focus to and estimated distance camera will be from subject matter (IMO autofocus is amateur)
Post:
-use log and transfer tool to import footage.
-edit footage
-use minor post stab if necessary
-color correct footage
-Export for vimeo
I hope this helps. I could go into more detail but it would require writing a complete tutorial. vimeo, dvinfo.net, creative cow and linda are great sources for learning how to set up cameras properly and for editing.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Sep 07, 2012, 10:29 AM
jdm66 is offline
Find More Posts by jdm66
jdm66's Avatar
France, Pyrénées Orientales
Joined Feb 2009
Hello,
I just got a Nex5N
Assembly work restarts
Question:
how did you fix the GCU and where, please ?
Thank's
jdm66
jdm66 is offline Find More Posts by jdm66
Old Sep 07, 2012, 10:36 AM
semich is offline
Find More Posts by semich
Portugal, Lisbon, Cascais
Joined Mar 2010
mine is on the gimbal, on the main top plate, near the screws that attach the gimbal to the s800.
semich is offline Find More Posts by semich
Old Sep 07, 2012, 10:39 AM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
hope you can see it.
Boris
BorisSA is offline Find More Posts by BorisSA
Old Sep 07, 2012, 10:54 AM
semich is offline
Joined Mar 2010
yup, just like mine
Old Sep 07, 2012, 06:20 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Boris
You have your receiver on their as well? Do you have to keep unplugging it when disassembling it from top plate?
shdwkeeper is offline Find More Posts by shdwkeeper
Old Sep 08, 2012, 06:06 AM
BorisSA is offline
Joined May 2011
Nope I have to unplug main power lead to zenmuse and can-bus going to the zenmuse and wkm LED can-bus and than i can separate S800 from the landing gear/zenmuse.
RX and Zenmuse stay together and no unplugging that why I put the RX on the zenmuse !
Old Sep 08, 2012, 10:42 AM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
This how my DW Skyjib build is looking right now.....
But at this point it is too heavy too use for commercial use in Denmark..and still need the NEX7 with CZ 24mm....
So maybe I have to build another MR frame for my Z15 .... anyone interested.... ???
But man I love it right now.....
rsun77 is offline Find More Posts by rsun77
Old Sep 08, 2012, 01:01 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
where should I buy my Z15 ? (in US or in Europe) and who have it in stock?
I also wonder if I should buy the zenmuse + s800.
Or maybe I can use my AVroto+WKM and build another HEX frame and save some money?
I feel that buying the zenmuse is a big investment (for a hobby user) so I need to be sure I get it all right
thanx for all help
liteglow is offline Find More Posts by liteglow
Old Sep 08, 2012, 01:53 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
that looks a whole lot nice than a S800!
Adidas4275 is offline Find More Posts by Adidas4275
Old Sep 08, 2012, 02:14 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
@rsun77
welcome to the club (of non-S800 Z15-flyers) mine has 4,3kg AUW, I am not sure if it is possible to build a multirotor with retracts (and Z15) with AUW below 5kg.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Sep 08, 2012, 02:40 PM
rsun77 is offline
Joined Jul 2008
Ferdinand
I only nede to get under 7 Kg.
I have put it ip for sale now and going to try a cinestar6 and some ideas.
The thing about the skyjib is the wight of the engine mounts and the retracts.
You says that your retracts that you made for the s800 only have a wight of 300 gram. Where did you find the retracts for it. ?
Rene
Old Sep 08, 2012, 02:46 PM
EndOfDays's Avatar
Joined Jan 2010
I used this one:
http://shop.lindinger.at/product_inf...ducts_id=32253
the 300gr are mainly due to the legs I made of 12mm (0,5mm) CFK Tubes, but this might be too weak for 7kg.
best regards Ferdinand
Old Sep 09, 2012, 02:41 AM
Joined Dec 2011
But you need to have some cables that go from your Rx to your WKM MC, or is that also on the landing gear.
Old Sep 09, 2012, 10:24 AM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
What values are people changing as far as COG when flying with a zenmuse, I have balanced it on x and y axis, but assume that the z axis must have shifted down quite a few cm, what values have you changed?
Fb
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
