Austria, Wien, Vienna
Joined May 2011
Expo helps but it is till rough one with the given firmware, the new one is out already anyways think it handles that, can't install it though since it seems to not like the GH2 version at the moment FW changes think one of there might be addressing it: Optimize the pan control in Orientation-locked Mode, to make pan control much more accurate and stable. Fix the roll control in Orientation-locked Mode. Roll is locked level in range of 0~2/3 command stick. Command stick stands for roll rotation velocity in range of 2/3~endpoint, the large the command stick movement, the bigger the rotation velocity. In Orientation-locked Mode and FPV Mode, cancel the servo driver module self-protection when gimbal is blocked, in order to keep the gimbal retaining the original status during sharp turn. |
United States, TX, Houston
Joined Jan 2012
I saw this thread yesterday... might be a $15 solution for a $3500 problem.
http://www.rcgroups.com/forums/showthread.php?t=1722815 |
Joined May 2011
If i want to use a HD transmitter at the moment there is no way because of the 360 continuous that can come in the way for example something like this ! http://www.kopterworx.com/vmchk/Coom...D-Wireless-Kit The question is if it would work with a soft cable and not disturb the balance of the zenmuse ? But it goes into the direction of the question I had before. Ruling the DJI remote was introduced to have HD module I am wondering how it should work with the given configuration of the Z15. Were can i link into the HD signal and keep on using the 360 continuos ? Boris |
Joined Jul 2008
United States, CA, Anaheim
Joined Dec 2011
Joined Dec 2011
Australia, SA, Renmark West
Joined Sep 2011
http://www.gentles.ltd.uk/ |
Joined Sep 2011
You could set the LED on the airframe and return the camera gimbal to a position where it can "see" the LED when you wanted to stop/start the video. (yeah - very clunky, but I don't see DJI's approach to camera control as particularly lacking. - it's only a minor hardship to D/L and trim the 10-15 minute clips and firing the stills shutter on command might be better than the 1 FPS burst mode as watching the EVF image during 1 FPS operation will send you blind.)
Joined Feb 2011
No It isn't. The GH3 is bigger and heavier, it is built like a tank! Panasonic clearly wants to give you a “DSLR feeling” going away from the “smaller is better” philosophy. That sucks! |
| Thread Tools | |
| Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... | GGoodrum | Multirotor Talk | 8037 | Today 08:55 AM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Video Piloting (FPV/RPV) | 9 | Jul 13, 2012 10:42 PM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Wanted 3 axis gimbal on a budget =) | Vyas | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Mar 20, 2012 10:57 AM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Aerial Photography | 2 | Sep 12, 2011 06:44 PM |
