Old Sep 04, 2012, 06:14 AM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
Originally Posted by EndOfDays View Post
The HDMI Kable is on the Kamera-tray, there is no extra HDMI-Kable necessary. Just have a look, I cannot imagine that it is missing, since you cannot unplug it from the tray.
best regards
Ferdinand
Thanks Ferdinand - I've worked it out - for some reason the HDMI cable on mine had been solidly glued to the side of the AV module. After convincing myself it wasn't supposed to be like that I managed to separate it using a single edged razor balde.
My confidence in DJI engineers is restored but the uncertainty caused by the shattered English used in the manuals remains!.
RedSky is offline Find More Posts by RedSky
Old Sep 04, 2012, 06:31 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by pal72 View Post
I have ordered a S800 and Zenmuse And i am going to use it as a 1 man and 2 man setup. Using a Graupner MX20 as primary TX and a JR for the camera man.
Question is: how to hook up this, so i can switch between 1 and 2 person operation in the easiest way?
I know u can use ppm on the WKM , but not on the gimbal... And the Graupner is only 12Ch, but i don't need all ch in the 1 man setup.
I can also hookup the JR to the Graupner, an assign som of the channels to the JR.
Anybody who could help me with this?
Regards Pål
I don't think you will find an easy solution to this. You really need a receiver that has 12 physical channels. Then you can buddy box in the 4 channels for the gimbal channels 9-12 using the trainer method through your primary TX. Until DJI has a way to pass the PPM or S.Bus through the CAN-BUS (if even possible) there will be no easy way for you to do it.
One reason why the 14 channel Futaba RX makes it easy to have a 1/2 man operation.
Sid3ways is offline Find More Posts by Sid3ways
Old Sep 04, 2012, 08:28 AM
magic1 is online now
Find More Posts by magic1
United States, CA, Laguna Niguel
Joined Oct 2005
I have the dx18 transmitter. I want to set up the z15 and s800 for single opperator use. I am confused if this is possible. Help Please! I can buy a different transmitter if I need to. What is the simple 1 man set up?
Thank You!
magic1 is online now Find More Posts by magic1
Old Sep 04, 2012, 09:49 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
Hello magic1
I am using th 9ch Aurora 9
1-5 for WKM (A,E,T,R,Flightmode)
6-9 for Zen (Pan, Tilt, Shutter, Zen-mode)
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Sep 04, 2012, 11:39 AM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Originally Posted by shdwkeeper View Post
I think I need two receivers to do this with s-bus, in the WKM manual it says only the first 8 channels are used at the moment (page 17) so I think that is where we are at.
Would like to know how Robert has his mapped out at the moment.
I just used ch 5, 6, 8 for the Zenmuse and all the rest were set for sbus to the wkm.
UAVProducts is offline Find More Posts by UAVProducts
Old Sep 04, 2012, 02:00 PM
EndOfDays's Avatar
Joined Jan 2010
Hello,
Just had the great idea that I could shoot panoramas with the camera in "portrait" to enhance resolution. But I found out that in all modes "roll" is limited to 30°. To me it would be great, if DJI could drop this limitation at least for the "non-orientation-locked" mode.
best regards
Ferdinand
Old Sep 04, 2012, 02:16 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
Ferdinand, the problem with that is as the roll axis of the gimbal exceeds 45 degrees the effects of gimbal lock become present. at 90 degrees (portrait) there is no longer a tilt axis and there are two pan axis.
The limitation is physical and no amount of software will correct for gimbal lock. A 4 axis is required or as in some industrial robotics, 120 degree offset simultaneous drive axis can mitigate the effects of gimbal lock.
http://en.wikipedia.org/wiki/Gimbal_lock
Photoship One is offline Find More Posts by Photoship One
Old Sep 04, 2012, 06:45 PM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
Wuhuuuu!!
I thought I heard angels when I opened the box. =)
Next problem:
Install here...
or here...
Ab74 is offline Find More Posts by Ab74
Old Sep 04, 2012, 07:15 PM
buhojean is offline
Find More Posts by buhojean
Joined Dec 2006
Originally Posted by Ab74 View Post
Wuhuuuu!!
Next problem:
Install here...
or here...
Congratulations
Is z-15n or z-15g?
buhojean is offline Find More Posts by buhojean
Old Sep 04, 2012, 07:16 PM
blbills is offline
Find More Posts by blbills
Joined Jul 2008
Hey guys sorry to interject. I've got a WKM and a GH2 Z15 on their way. My plan is to initially mount the combo to a heli (completely independent of the flight control system) until I see some better reliability reports and retracts on the s800.
My question, can someone that has the z15/WKM/s800 combo simply disconnect the s800 from the equation to ensure that the z15 functions properly? (Simulating a 2 man setup with my heli so to speak)
I'm sure my request sounds rather weird but I'm getting reports from reputable sources that have tried this and the z15 didn't behave properly until a multirotor (eg s800) was in the loop.
Just wanting to confirm.
Thanks!
blbills is offline Find More Posts by blbills
Old Sep 04, 2012, 07:42 PM
RedSky is offline
Joined Sep 2011
Thanks!
I think you're going to need a WK-M or ACE-1 controller for the Z-15 but not necessarily the S800 airframe (I'm installing on a custom built 1100mm motorbase octo with WK-M controller).
Old Sep 04, 2012, 07:47 PM
piccoloflyer is offline
Find More Posts by piccoloflyer
Australia, New South Wales, St Leonards
Joined Aug 2009
Thanks!
You need WKM or DJI ACEONE connect with Z15 to work, so to use it on your heli, you need install ACEONE on the heli, or don't have $3500 ACEONE, you can still mount your WKM on the heli to make it work if you can find enough space to mount it all
piccoloflyer is offline Find More Posts by piccoloflyer
Old Sep 04, 2012, 07:56 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
Originally Posted by BorisSA View Post
Short Z15 GH2 test
https://vimeo.com/48718895
just at the beginning but really loving the z15 !
only bummer is the GH2 characteristic of switching to 1080i when HDMI is plugged in . But thats not a DJI issue but Panasonic related !
Boris
I know what you mean, I guess you don't have to use the Hdmi, just tape it to the Z15
shdwkeeper is offline Find More Posts by shdwkeeper
Old Sep 04, 2012, 08:04 PM
blbills is offline
Joined Jul 2008
I'm aware that I need the WKM for the Z15 to function. My question is does it work just like that? eg without a multirotor connected to the WKM. I just want someone else to confirm this for me as I already have someone that's tried it with no luck.
I've had an aceone in the past. I've gone a different route on the heli flight control system. I just want to put a z15 on the heli with the absolute least fuss.
Old Sep 04, 2012, 08:44 PM
RedSky is offline
Joined Sep 2011
Hello,
best regards
Ferdinand
As was pointed out, you can't roll to 90 derees without crossing the gyros but a different cradle, which held the NEX in portrait orientation could do it.
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
