Old Aug 29, 2012, 12:22 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Originally Posted by RedSky View Post
The prices have (in effect) gone up as the early adopter discount has ended.
I wouldn't spend too much time trying to get a deal, DJI are able to sell all they can make, and more, without discounting.
Ummm...I think we have some of the best combo prices. The combo discount ends at end of month.
UAVProducts is offline Find More Posts by UAVProducts
Old Aug 29, 2012, 01:39 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
Originally Posted by ssjheli View Post
Hi
I use the Sbus reciewer on the WKM and a 14 Cannel on the gimbel.
Binded to the same TX. using multimode 2.
And then then when I go from a 1 to a 2 men operation I just bind the secund transmitter to the 14 cannel on the gimble. Easy and fast using Futaba 8FG.
regards
SsjHeli
What rx tx combination are you using?
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Aug 29, 2012, 02:05 PM
Kamakaze UK is offline
Find More Posts by Kamakaze UK
United Kingdom, England, Birmingham
Joined Nov 2010
Originally Posted by UAVProducts View Post
How can I use the R6208SB and a R617FS for a one man setup?
R6208SB sbus on S800 and R617FS for gimbal.
Can these be binded to same TX?
I hope so I have a R617fs lying around . Not played with multimode2 yet though, I have a more pressing project, its next after that though. maybe ssjheli can help.
Meanwhile, here's the finished 14ch rc vid...
Z15 gimbal and DJI wookong wired to 14ch rx (2 min 10 sec)
Kamakaze UK is offline Find More Posts by Kamakaze UK
Old Aug 29, 2012, 02:23 PM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
Excellent - and another reason not to wait around before ordering.
RedSky is offline Find More Posts by RedSky
Old Aug 29, 2012, 02:47 PM
ssjheli is offline
Find More Posts by ssjheli
Joined Apr 2012
Hi
I use 2 Futaba 8FG tx. And it just to press the bind buttem and you can switch from one to two men operation in seconds without unplugging any thing.
Ssjheli
ssjheli is offline Find More Posts by ssjheli
Old Aug 29, 2012, 02:52 PM
Joined Apr 2012
Do you know if they both need to be 8fg? Or would a 6j work for the gimble are you using the 6014 for the gimble
Old Aug 29, 2012, 03:19 PM
Joined Nov 2010
Hi
Ssjheli
Can you do whilst you are flying?
Old Aug 29, 2012, 04:16 PM
pal72 is offline
Find More Posts by pal72
pal72's Avatar
Joined Jun 2011
price on combo package
Where can i get the best price for a combo package ( S800, WKM, Z15) in Europe?
The best price Shipped to Norway
Pål
pal72 is offline Find More Posts by pal72
Old Aug 29, 2012, 04:31 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
Pål
http://shop.aerodron.ch/index.php/rt...ings-s800.html
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Aug 29, 2012, 04:37 PM
pal72 is offline
pal72's Avatar
Joined Jun 2011
cheaper on this site. http://quadcopters.co.uk/
This site any good?
Old Aug 29, 2012, 07:23 PM
Joined Apr 2012
http://www.youtube.com/watch?v=qJxEW...=youtube_gdata
Thanks for the videos, very helpful. Did we ever get an answer to the question of binding. Do you need 2 8FG's or and does it have to be a 14 channel 6014? or would this idea of an R6017 work?
thanks
Joined Nov 2010
This site any good?
Not sure, not used them.
@flyingbiscuit, not yet, work has gone mad, it's next on my list though.
Here are my results for the 14 ch rx, everything works,and don't forget you can easily set this up to switch into 2 man mode without unwiring anything, either by remote switch, or a land and rebind.
z15 first one man mode test (2 min 56 sec)
Old Aug 29, 2012, 09:38 PM
otlski is offline
Find More Posts by otlski
checkout my Blog
otlski's Avatar
Joined Feb 2008
Just had a thought, i wonder if they hook these up to a wheel balancing type machine in the factory? I wonder if i can get my gains up so high i can get it to hum like a top and balance it with lead weights till it's quiet...
Likely not. What matters is that the composite CG of the gimbal and camera intersect the gimbal's pivot axes. I don't know what a Nex-5 camera weighs but let's say it is 300 grams. If the camera mount hole-slop is say 0.5 mm than the resultant imbalance would equal 15 g-cm. Which means even if DJI needed to do post manufacturing balance at the factory, which is doubtful, they would have to employ a surrogate mass stand-in for the camera. It would be prone to the same kinds of hole-slop uncertainties of 15 g-cm, and beyond that, it would really be meaningless. 15 g-cm is something that DJI can likely determine via CAD and maintain throughout manufacture (considering how small gimbal is). Question, are there any correction weight positions obvious on the gimbal? DJI imprecisely touts this gimbal as the same pointing accuracy as Cloud Cap's smaller Tase gimbal. The difference is that Cloud Cap integrates the camera and gimbal at the factory. Any balancing they do is on the whole unit as opposed to the customer adding their own camera. Most gimbals that have the need for precise balancing are done on static CG machines, the majority of the remainder are done on shakers, other methods including dynamic balance are rarely used.
Dan
otlski is offline Find More Posts by otlski
Old Aug 30, 2012, 01:49 AM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
THis is my question. So I guess its not possible to use the 8FG Super w/R6208SB receiver to run both the S800 plus the gimbal?
shdwkeeper is offline Find More Posts by shdwkeeper
Old Aug 30, 2012, 08:14 AM
Joined Apr 2012
It seems unlikely from what has been posted, but I would still like a clear explanation of how the 14 6014 ch rx and 6208 should be set up with just using binding. Also wondering if you do need 2 8fg to make this configuration work
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 11:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 11:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 07:44 PM
