Old Jul 31, 2012, 06:05 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
You do not need to use X2 and X3 on the WKM, so then it would be 3 channels (for mode, pan, tilt on the Zen)
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Jul 31, 2012, 07:49 AM
nathasm is offline
Find More Posts by nathasm
United States, SC, Charleston
Joined Nov 2011
I'm also experiencing an issue on start-up. See the video for details. But basically I have to plug in the batteries twice in order for initialization to finish. Once done, the gimbal will pan/stutter back and forth and then eventually stop off center.
I have SBUS from my receiver to the WKM and then I've hard-wired MODE from the GCU to ch8 on my receiver.
Zenmuse Z15 Startup Issues (0 min 57 sec)
nathasm is offline Find More Posts by nathasm
Old Jul 31, 2012, 07:52 AM
nathasm is offline
Joined Nov 2011
Ok, so you loose the ability to do POI this way? I'll play around with it. I will probably set up MODE/TILT and that way I can keep POI.
Old Jul 31, 2012, 08:23 AM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
http://www.youtube.com/watch?v=aW9Yb0KUcvo
Try it outside with full GPS reception. I think its hunting being inside.
The Z15n and WKM have to "handshake".
UAVProducts is offline Find More Posts by UAVProducts
Old Jul 31, 2012, 08:43 AM
nathasm is offline
Joined Nov 2011
That makes sense...although I had full GPS lock (even while inside). I'll try again when I'm home.
Having to connect the batteries twice anything to worry about as well?
Old Jul 31, 2012, 09:22 AM
Joined Mar 2004
Sometimes mine does that (connecting twice).
Inside, maybe the compass is being affected. Just thoughts
Old Jul 31, 2012, 12:27 PM
EndOfDays's Avatar
Joined Jan 2010
Has anybody experience with the sigma 19mm lens for the Sony nex5? I think I will try this lens on the Zen (before I will do what I think I have to do and go for the Zeiss)
best regards
Ferdinand
Old Jul 31, 2012, 12:47 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
The 24mm Z15 I think would be the best if I wanted to run the stock 18-55m lens? Trying to brainstorm here I see the Zeiss 24mm is only 1mm longer and about 30g heavier. Thoughts to make balancing easiest?
Sid3ways is offline Find More Posts by Sid3ways
Old Jul 31, 2012, 03:41 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
18-50mm has OSS (Sony's lens-based image stabilization mechanism) making it not very good for this kind of use. Of course, you can certainly try using it. It is just not recommended by DJI.
http://www.photozone.de/sony-alpha-a...ny1855f3556nex
24mm lens used will be supported; due to still large qty of backorders; it will have a few weeks waiting time.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jul 31, 2012, 03:54 PM
Hypam is offline
Find More Posts by Hypam
Joined Jul 2011
Support for 24mm Zeiss means tuning the Zenmuse PID settings or provide a special
mounting to correct the Center of Gravity?
Hypam is offline Find More Posts by Hypam
Old Jul 31, 2012, 04:57 PM
nathasm is offline
Joined Nov 2011
So I believe I figured out my issue. During my testing with just the S800, I did some straight line tests and according to the WKM user manual (pg 41) you should offset the GPS unit if the craft flies off angle.
With the GPS offset, the Z15 will also be offset. Basically the Z15 is pointing in the direction of the GPS.
There doesn't really seem to be a way to counteract that. Either fly at an angle or fly with the Z15 at an angle.
Has anyone else experienced this issue?
Old Jul 31, 2012, 07:04 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Thanks for the heads up. I saw Ferdinand adjust the 16mm mount to use the stock lens and it looks great so I figured the 24 would be easier to modify.
N/M misunderstood Robert after looking at the email.
Old Aug 01, 2012, 07:20 AM
EndOfDays's Avatar
Joined Jan 2010
@nathasm
After some time you will not be flying the Z15 in a mode where the orientation of the copter is important, to me this is a minor issue.
best regards
Ferdinand
Old Aug 03, 2012, 08:25 AM
EndOfDays's Avatar
Joined Jan 2010
Yet another video ...
Z15- Video-blog 2012-07-31: just practice (2 min 43 sec)
best regards
Ferdinand
Old Aug 03, 2012, 09:17 AM
yeehaanow is offline
Find More Posts by yeehaanow
United States, VT, Bristol
Joined Sep 2010
That's awesome Ferdinand.
Do you have an OSD and ground recording in case it went down in the forest?
When it's sped up like that you can really see the roll drift. Maybe drift is the wrong word, but it definitely leans into the flight direction. Not horrible, and an operator could correct, I'm sure.
Great stuff.
yeehaanow is offline Find More Posts by yeehaanow
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
