Old Feb 14, 2013, 01:51 AM
consoleworld is online now
Find More Posts by consoleworld
consoleworld's Avatar
Greece, Athina
Joined Nov 2012
I think is not possible to add in F550 is verry heavy the zenmuse , total weight 3000-3500 grams , and the flight time no more than 3 minutes .
But almost nothing is impossible!!!!!!!!!!!!!!
Christian
consoleworld is online now Find More Posts by consoleworld
Old Feb 14, 2013, 09:10 AM
westsideav is offline
Find More Posts by westsideav
Osprey
westsideav's Avatar
Joined Jan 2013
Originally Posted by animau View Post
Did someone ever put a zenmuse under a dji f550 heavy conversion kit? is it possible?
I dont think that would be worth it, by the time you buy bigger motors etc. I think the 550 would be over stressed. And the weight is part of the reason the kit is smooth.
I do think there will be other copies of the Zenmuse direct drive system (there already are some). Both lighter and less expensive. Those may be a nice match to a lighter MR. DJI is working on a smaller Zen for GoPro as reported in this thread.
My guess is there will be a lot of development and much lower weights and prices in the future.
But one thing that is true in all camera work is bigger heavier cameras are always smoother. When I shoot with my StediCam and my FS700 I actually add weight to the rig to help smooth it. Electronic stabilization can only do so much. This is even true just on a tripod, a heavier camera on a heavy tripod is the only way to use long lenses in windy conditions.
westsideav is offline Find More Posts by westsideav
Old Feb 14, 2013, 11:12 AM
plingboot is offline
Find More Posts by plingboot
Joined Oct 2010
Servo delay is also available on the DC-16, set it up today…
The delay is quite big for demonstration purposes.
Jecti DC-16 (0 min 26 sec)
Will post a clip with the zenmuse later.
plingboot is offline Find More Posts by plingboot
Old Feb 14, 2013, 12:49 PM
Appcam is offline
Find More Posts by Appcam
Joined Jan 2013
Hello.
I dont get it so i start asking some newbie questions here, please be patient....
I'm trying to understand this thing with zenmuse Z15 for 1pilot solution. the problem is that I do not understand the manual after struggling for 2 days with this. I have allready calibrated my transmitter with WKM and I'm useing ports 1,2,3,4 and 7 on my R6208 SB receiver ports, looks great so far.
I guess that i must connect the remaining ports between the Zenmuse GCU and reciver (3ports left in the reciver 5,6 and 8/8), but how and where do I find the solution to that if I don't understanding the manual correctly by now. I want to run with 1pilots solution,,, anyone knows, any tutorials on Zenmuse (can't find any)? Is this where the S-bus should be used for the S800/WKM or for the zemnuse?
Thanx for any help in this matter!
Happy Valantines day..
Appcam is offline Find More Posts by Appcam
Old Feb 14, 2013, 02:28 PM
Osprey
westsideav's Avatar
Joined Jan 2013
Originally Posted by Appcam View Post
Hello.
It can be done but you need a few more parts, to split the signal. I was working on it and I gave up after talking to Patrick at AerialMediaPros at length about this. I ended up getting a second T8FGs and receiver.
It works really well and you can do single pilot if you set yourself up right.
This way you can use all the features of the Zen. It is very hard to get smooth moves with the sliders, much easier with the sticks. And it is less confusing to have all the cam controls on one radio and the WKM switches on another.
Just the conclusion I came to, it may not be right for you. And I really like it this way. You need a stand for a monitor anyway so just put your camera TX on the same stand.
Old Feb 14, 2013, 02:45 PM
Brett1868 is offline
Find More Posts by Brett1868
Australia, NSW, Stanhope Gardens
Joined Aug 2012
Hello.
Single pilot solution requires 14 channels bare minimum, 18 if you want full functionality.
Brett1868 is offline Find More Posts by Brett1868
Old Feb 14, 2013, 03:10 PM
Appcam is offline
Joined Jan 2013
Ok, Thanx for input and ideas...
I have a Futuba T8FG 14 channels.
I also have a Spektrum X7, would that work for the Zenmuse?
I figured that i just wanted to try the zenmuse on the s800 in FPV mode as a maiden flight before getting one more T8FG + Reciver... And I still do but can't figure out the wiering...
Cheers and thanx for respons...
Old Feb 14, 2013, 04:53 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
Looks like a few of us have the Futaba 8FG and are trying to run this as a single pilot machine.
IF anyone has already done it - I would really appreciate them letting us know how they they did it (channel mapping/Sbus setup etc).
Jelico is offline Find More Posts by Jelico
Old Feb 14, 2013, 05:05 PM
Jelico is offline
Joined Jul 2008
I am only just building my S800/Zen now so am curious about this comment. Here is how I had planned to use my Futaba 8FG with 14 channels on S-Bus:
1- Aileron
2-Elevator
3- Throttle
4-Rudder
5- FC mode (atti, man, GPS etc)
6-FC Return to home
7- IOC switch
8- Zenmuse Pan
9- Zenmuse tilt
10- Zenmuse roll
11- Zenmuse Shutter
12-Zenmuse Mode
13-iOSD
14-AUX
It looks like i am missing something here - how would you make up the other channels? Thanks for your help
Old Feb 14, 2013, 06:13 PM
apvxtreme is offline
Find More Posts by apvxtreme
aka RacingFPV aka HAMM3RDOWN
Canada, ON, Toronto
Joined Sep 2012
HDMI V2 Help for Z15N maybe?
Hey guys, I just installed the new board and everything is working as it should except the switch I mapped for the video record function isn't picking up in the assistant nor is it working? Tried just about everything.
My setup:
Spektrum DX 18 tx
Spektrum AR9020 rx
Spektrum XPlus8 expansion *Zenmuse
I know it says to map Aux 3 and I did, it shows in the TX that it's working but nothing in the assistant or on the camera? Everything is plugged in proper, what am I missing? (and why am I one of the few running spektrum lol?)
apvxtreme is offline Find More Posts by apvxtreme
Old Feb 14, 2013, 06:17 PM
Canada, ON, Toronto
Joined Sep 2012
One of the Z15 channels can be hooked up so that in FPV/Reset mode it levels horizon or points down far as I can tell... There is a HDMI switch on AUX2 of Z15 as well but not sure what it does. (might be backwards, HDMI may be AUX1 but whatevs...) Oh and there is video record on AUX3. Not sure if that helps but?
1- Aileron
2-Elevator
3- Throttle
4-Rudder
6-FC Return to home
7- IOC switch
8- Zenmuse Pan
9- Zenmuse tilt
10- Zenmuse roll
11- Zenmuse Shutter
12-Zenmuse Mode
13-iOSD
14-AUX
Old Feb 14, 2013, 09:05 PM
Jelico is offline
Joined Jul 2008
Another question...
Do you know if I Can use all 14 channels of my 8FG with the included SBUS Futaba R6208SB receiver?
The Wookong supports S-Bus so in theory its possible right? Or am I missing something and need to buy a 14 channel receiver for it.
Or is that receiver limited to 8 channels whether you use it as an Sbus receiver or not.
Really appreciate your advise here- I need to be able to run 13 channels so working out what I need to to to make that happen.
Old Feb 14, 2013, 11:37 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
http://youtu.be/XaiC9W9SKC4
ah great it that easy thought i had to get the jeti box out !
great thanks now i have the motivation to do it
BorisSA is offline Find More Posts by BorisSA
Old Feb 15, 2013, 01:25 AM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
Another question...
It only have the 8 channels.
You will need the 14 channel receiver to get the channels for s800 and the zen on one receiver.
rsun77 is offline Find More Posts by rsun77
Old Feb 15, 2013, 09:20 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
Hello,
Do you know where I can get this part to mount on the lens of a Z15 (Sony Nex)?
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 11:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 11:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 07:44 PM
