Old Feb 11, 2013, 06:21 PM
DorianJ is offline
Find More Posts by DorianJ
DorianJ's Avatar
Freehold, USA
Originally Posted by EndOfDays View Post
In the meantime (while this feature is implemented on the one or the other side, and you do not want to change your tx) you can use this:
http://www.hobbyking.com/hobbycity/s...idProduct=8863
or that:
http://www.d2air.at/index.php?templa...rtikel&id=5292
or that:
http://www.hoelleinshop.com/Servo-Im...rodNr=EMA18090
best regards
Ferdinand
Thanks Ferd, but these are not good options. An inline delay filter in between the servo and signal will delay BOTH the stabilized signal and stick input signal giving us a delayed stabilized system..not good. We only want the stick input signal to have a delay and not the stabilized signal coming from the stabilization sensors (Radian, Hoverfly etc)
DorianJ is offline Find More Posts by DorianJ
Old Feb 11, 2013, 06:27 PM
DorianJ is offline
DorianJ's Avatar
Freehold, USA
Originally Posted by TruckBasher View Post
Sadly 10CG has no way of doing it, except 2 man OP by using the servo delay of throttle ch (3) tho it may not be direct equivalent but worth a try
http://www.futaba-rc.com/faq/faq-10c-2_4ghz-q1068.html
If not possible on 10C, 14mz is not necessary, my old 12FG have it look at page 74 of manual
Wow, great info Thanks! I read through the steps for the 10C and it's only able to set servo delay on one channel...Ideally I'd like both left and right sticks. Looks like the 10C is out.
The 12FG is a good option. If anyone else know of any Futaba radios capable of servo delay please let up know.
Old Feb 11, 2013, 06:28 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
We are talking about the Z15 right (there is no servo)?
You put them between your RC-RX and the Z15-Controller, it does just the same as my Hitec Aurora with "servo-speed" it smoothes the signal coming from the RC-TX, this has nothing to do with stabilization.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Feb 11, 2013, 06:30 PM
DorianJ is offline
DorianJ's Avatar
Freehold, USA
best regards
Ferdinand
Ahh understood. my apologies. I thought these mounted inline between servo. I totally got it wrong. Back in business! Thanks! wonder how well they work? Someone should test
*uck it i'm ordering the Turnigy to test: http://www.hobbyking.com/hobbycity/s...idProduct=8863
Old Feb 11, 2013, 07:24 PM
animau is offline
Find More Posts by animau
Canada, QC, Montreal
Joined Jun 2012
Any news about gopro zenmuse?
animau is offline Find More Posts by animau
Old Feb 11, 2013, 07:36 PM
Brett1868 is offline
Find More Posts by Brett1868
Australia, NSW, Stanhope Gardens
Joined Aug 2012
Futaba 18MZ page 85 of the manual "End Point (ATV)" allows the speed to be adjusted from 0 to 27. I'll give it a go once I swapout my S800 from Spektrum to Futaba.
Brett1868 is offline Find More Posts by Brett1868
Old Feb 11, 2013, 09:26 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
Think you can do the same on a Futaba 8FG. I will give it a go when I get my S800/Zen built..
Jelico is offline Find More Posts by Jelico
Old Feb 11, 2013, 10:14 PM
DorianJ is offline
DorianJ's Avatar
Freehold, USA
Thanks guy, When you're all setup can you also confirm that servo delay can be mapped to both left and right sticks on your radios for pan/tilt control? Thanks!
Old Feb 13, 2013, 02:03 PM
Aerono51 is offline
Find More Posts by Aerono51
Joined Feb 2013
Hi guys, i'm a new one on the forum. Just read about the delay. You can do it on a Futaba 8FG but just for the throttle channel, then assign it to the J4 for example ... you've got a nice movement around 20 sec delay.
Aerono51 is offline Find More Posts by Aerono51
Old Feb 13, 2013, 02:30 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
I have to give this a try this afternoon.
UAVProducts is offline Find More Posts by UAVProducts
Old Feb 13, 2013, 07:49 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
It also appears to be possible in my JR9503. Almost done getting everything back together and ready to reprogram everything. 4 day weekend coming up to play.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 13, 2013, 08:09 PM
westsideav is offline
Find More Posts by westsideav
Osprey
westsideav's Avatar
Joined Jan 2013
Flight test of Zenmuse and S800
Not a lot of wind but enough to knock the S800 around a bit.
I was real happy to see how well the Zenmuse handled it.
This is raw footage no post stabilization. Flying with 2 6000 30-70c in parallel, pretty heavy and a little cumbersome but pretty smooth I think.
CSRR Winter (3 min 2 sec)
westsideav is offline Find More Posts by westsideav
Old Feb 13, 2013, 09:09 PM
DorianJ is offline
DorianJ's Avatar
Freehold, USA
https://vimeo.com/59617201
Very nice and smooth. Lovely scenery too. Good job sir! Which camera?
Old Feb 13, 2013, 09:48 PM
Osprey
westsideav's Avatar
Joined Jan 2013
Sony NEX5n with a #9 ND filter on the 16mm pancake lens.
Old Feb 13, 2013, 10:56 PM
animau is offline
Joined Jun 2012
Did someone ever put a zenmuse under a dji f550 heavy conversion kit? is it possible?
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
