Old Jan 30, 2013, 03:17 PM
flyingbiscuit1 is offline
Find More Posts by flyingbiscuit1
Joined Apr 2012
Originally Posted by AVMEDIA View Post
Tahoe Ed: So I updated the firmware. Still the same. What I did find out in the process however is that when I switch to PAL instead of NTSC, the iOSD works as it should! Which basically brings me back to the original problem of not being able to shoot in NTSC. This is getting really frustrating. I have the V2 GH2 HDMI board. Anyone have any other ideas of what to do to get this thing working in NTSC?
I am seeing the same problem with the OSD Mk2 what ever the problem is it goes across both the MK1 and Mk2 osd. It works in PAL but not NTSC, can others please confirm they are seeing this as well in NTSC. I have tried and FPV camera in NTSC and it also freezes the osd information overlay making it useless.
flyingbiscuit1 is offline Find More Posts by flyingbiscuit1
Old Jan 30, 2013, 03:46 PM
Michiel van Son is offline
Find More Posts by Michiel van Son
Zenmusement
Michiel van Son's Avatar
Belgium, Vlaams Gewest, Gent
Joined Dec 2012
Hey folks, I posted on here before about an issue I was having with the Zenmuse GH2 and DJI iOSD. I now have a video that I hope explains the problem better, hopefully someone can help me out! (http://vimeo.com/57574169). You may have to copy/paste link in browser.
A little background info...So originally I had the Z15GH2 with V1 of the HDMI board. I was getting the black and white/blurry picture issue. Robert sent me a V2 HDMI board. This solved the black/white downlink issue. However, after installing the V2 HDMI board, my iOSD no longer works properly. When my camera is off, the iOSD works just fine. As soon as I turn my camera on, the iOSD basically "freezes" and shuts off after 30 seconds or so. I am still getting a video downlink. As soon as I turn off my GH2, the iOSD works again, but obviously I do not have a video downlink. I am using all DJI components (VTX/iOSD/WKM etc). Anyone have any ideas? The HDMI cable has been replaced so that is ruled out. Robert also sent me a SAO adapter which also does not solve the issue (actually makes it worse, makes the video downlink all grainy and dark). As I have not heard of anyone else having this problem I wonder if it something I am doing wrong? Any ideas? Thanks for your help!
This might be a stupid remark, but what happens if you turn the camera on before powering on your iosd?
Michiel van Son is offline Find More Posts by Michiel van Son
Old Jan 30, 2013, 03:59 PM
AVMEDIA is offline
Find More Posts by AVMEDIA
AerialTech
Canada, AB, Lethbridge
Joined Jul 2012
Same thing, the overlay still freezes up and eventually shuts off. In PAL mode it works no problem...
AVMEDIA is offline Find More Posts by AVMEDIA
Old Jan 30, 2013, 05:26 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Originally Posted by leemann View Post
I want to build one of these as well. Have anymore details on the setup? How hard is it to hold by just hold the ends of the rods.
Its pretty light and easy to hold by the rod ends.
All we did was setup the Zenmuse and WKM and mounted everything.
Then we used some CF rod for handles.
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Jan 30, 2013, 06:25 PM
Joined Apr 2012
Not stupid, but I have tried as many options as I can see. The mk2 has the same problem in ntsc, and if any on else can test this on ntsc ver 2 hdmi board, I would appreciate it. in fact any ntsc camera would work.
Old Jan 30, 2013, 06:56 PM
leemann is offline
Find More Posts by leemann
Canada, ON, Toronto
Joined Feb 2012
Hi Guys I am trying to setup a second Futaba 8FG to control the Z15 via SBUS. It seems like everything is working other then the FPV setup. I can't get aux2 to work in order to change which direction (either forward or down) right now its stuck in down so it doesn't help me too much. Any ideas? I know in the Wookong assistant you have to set SBUS do but I don't see any place to do that in the Zen assistant. Any help would be great!
leemann is offline Find More Posts by leemann
Old Jan 30, 2013, 08:09 PM
NVMax is offline
Find More Posts by NVMax
North Vancouver, B.C.
Joined Dec 2005
V2 Board Install
Hey Guys,
Are there any instructions, guide lines for replacing the HDMI board? is it plug-n-play? do i need to update firmware?
Please help, i really don't like the idea of pulling apart a $3500 piece of gear without at least TWO instructions...
And maybe I'm blind but none of my searches have come up with anything.
Thanks.
NVMax is offline Find More Posts by NVMax
Old Jan 31, 2013, 02:34 AM
Topper_MUC is offline
Find More Posts by Topper_MUC
Germany, BY, Munich
Joined Jan 2012
Originally Posted by NVMax View Post
Hey Guys,
Thanks.
http://www.rcgroups.com/forums/showp...postcount=4117
Topper_MUC is offline Find More Posts by Topper_MUC
Old Jan 31, 2013, 12:28 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Anyone knows how to re-calibrate Zenmuse and re-flash motors?
I got info that this could be the problem to my roll drift.
quadslo is offline Find More Posts by quadslo
Old Jan 31, 2013, 12:32 PM
Aviator1 is offline
Find More Posts by Aviator1
Aviator1's Avatar
United Kingdom, England, Surrey
Joined Jan 2012
Just a thought? have you upgraded to latest Z-15 firmware?
Aviator1 is offline Find More Posts by Aviator1
Old Jan 31, 2013, 12:38 PM
quadslo is offline
Slovenia
Joined Feb 2011
Yep, tried everything. It was working ok for 3 months.
Old Jan 31, 2013, 12:39 PM
NVMax is offline
Joined Dec 2005
Thank You!
Old Jan 31, 2013, 01:04 PM
Hypam is offline
Find More Posts by Hypam
Joined Jul 2011
The Hero-gimbal from DJI at the Toy-Fair in Nürnberg:
http://upload.masu.de/daten/1359641368_gimbal1.jpg
Hypam is offline Find More Posts by Hypam
Old Jan 31, 2013, 01:32 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
It's happening.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jan 31, 2013, 02:31 PM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Originally Posted by sidneyw View Post
It's happening.
Another piece of quality looking gear from DJI. Is this only for the gopro 3?
Paul@SCC is offline Find More Posts by Paul@SCC
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 11:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 02:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 11:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 07:44 PM
