Old Nov 28, 2012, 02:11 PM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
These are high frequency vibes for shure. You will have to balance your props and maybe the motors.
hugy is offline Find More Posts by hugy
Old Nov 28, 2012, 02:13 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
Originally Posted by banga View Post
Can u suggest what can i do in my config to remove jello so i can get nice videos like all of u.
gains? balancing props? move a bit z15 forward or backward? pls give me some suggestions so i can fly and record without jello
tnx and cheers
Balance the props like others have said also...
What shutter setting were you shooting with? Video should be 1/60 - 1/120, if you are in the 1/1000 you may get some jello type effect.
Dolby is offline Find More Posts by Dolby
Old Nov 29, 2012, 12:14 AM
swarfworks is offline
Find More Posts by swarfworks
United States, MI, Mt Pleasant
Joined Nov 2010
Here's one from a couple days ago. Nothin fancy. Just playing around.
Bridal Veil Falls - Provo Canyon, UT (4 min 43 sec)
And here's a fun one from a new friends 1500fps high speed camera. We also shot some from straight on to see how responsive the z15n is when rocking side to side.
Slow motion RC Helicopter TREX700e AP/AV Aerial Rig at 1500fps (0 min 21 sec)
Cheers,
Paul
swarfworks is offline Find More Posts by swarfworks
Old Nov 29, 2012, 12:29 AM
banga is offline
Find More Posts by banga
banga's Avatar
Croatia, Slavonski Brod-Posavina, Slavonski Brod
Joined Nov 2009
Originally Posted by MCrites View Post
banga what type of memory card are you using? Size and Class plz.
banga is offline Find More Posts by banga
Old Nov 29, 2012, 12:37 AM
ksrimoungchanh is offline
Find More Posts by ksrimoungchanh
Lost in the wind
United States, KS, Overland Park
Joined Jun 2012
any house for sale? I am tempted to get rid of everything and start retirement early.. the water looks awesome!
KS
Originally Posted by Ab74 View Post
http://vimeo.com/54405654
A fishing town, 3 hours south of Manila.
ksrimoungchanh is offline Find More Posts by ksrimoungchanh
Old Nov 29, 2012, 01:38 AM
banga is offline
banga's Avatar
Joined Nov 2009
Originally Posted by semich View Post
Interesting... do you use the ring to support the lens? is the lens the one supported (due balance)? are you using the recommended settings - at the end of the documentation? can you take pictures of the zenmuse with the camera on?
Z15 doesn't have the ring to support the lens like Nex. Yes i am using recommended settings from the end of doc. I will take some pictures after i get home.
Old Nov 29, 2012, 01:40 AM
banga is offline
banga's Avatar
Joined Nov 2009
Originally Posted by Iceman575 View Post
I also had jello on my stock S800 with the Nex-5n. There where a LOT of high frequency vibes. Didn't look to bad until i touched it in flight. I changed to XOAR props (you need to balance them) and stiffened up the arms. Since then no more jello.
Can u give me link where did u buy XOAR props?
can u send me a photo of ur S800 how did u reinforce arms?
cheers
Old Nov 29, 2012, 01:55 AM
DashieBrad is offline
Find More Posts by DashieBrad
DashieBrad's Avatar
Joined Nov 2012
OK I am just going to throw this out there because it made me feel like a moron in case anyone is looking for an answer to this...
Troubleshooting why a z15 wasn't initializing... it just kept on spinning around and around... my first time putting a system together. There's a g6 and g8 connector on the zenmuse controller, with one ribbon cable coming out from the zenmuse to the g8 port. I assumed that is all I needed. Probably 5 hours of troubleshooting later, after swapping gimbals and swapping zenmuse controllers I got the bright idea to plug in the extra 6 pin ribbon cable to the middle port on the top zenmuse motor, and the other end to the g6 port on the controller... and then smacked my head on the table when the z15 initialized. Yes, apparently you need both cables... which makes perfect sense now that I think about it, for the ability to use 3rd party IMUs.
DashieBrad is offline Find More Posts by DashieBrad
Old Nov 29, 2012, 03:31 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
cheers
I got the props from Kopterworx. They carry the whole range of wood XOAR props.
First try was to simply ziptie a square 10x10 carbon fiber rod underneath the arms. It did almost nothing in flight. Next try was to use clear silicon to glue the tube underneath the arms and then use some zipties as added security (as somebody on this thread did). This worked quite well.
At the moment i still have 5 arms reinforced with square tube. One arms i laminated with braided Carbon fiber sleeves. It did not turn out very pretty but it seems very very stiff. However i did not test it yet as i have been working on another Octo unrelated to the whole S800-Zenmuse stuff.
Iceman575 is offline Find More Posts by Iceman575
Old Nov 29, 2012, 08:09 PM
blbills is offline
Find More Posts by blbills
Joined Jul 2008
http://youtu.be/N0sA0qhUu5o
http://youtu.be/HpA9UspgJ5k
Cheers,
Paul
I'm loving that 1500fps. What camera is that?
Also Bridal Veil Falls is my backyard! I live in Orem. Cool stuff.
blbills is offline Find More Posts by blbills
Old Nov 29, 2012, 10:43 PM
Griffo is offline
Find More Posts by Griffo
Griffo's Avatar
Australia
Joined Oct 2003
Looks like the Phantom Gold.
Griffo is offline Find More Posts by Griffo
Old Nov 30, 2012, 12:32 AM
Joined Nov 2010
He said it was the Phantom Miro M320S. The files (converted to a full HD .mov) are crazy big at 15gb per 3 seconds of recording. Yowza...
It's was hilariously deceiving at the falls. It looked like I was so high but really wasn't. Had a little free time on vacation and thought that it'd be fun. I lived in Orem and Provo several years ago as well. Fun (but increasingly crazy-busy) place now.
Old Nov 30, 2012, 02:47 AM
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
Guys, any info about "low cost dji head"?
this was published a month ago
DJIlowCostHeadMalibu-test (1 min 30 sec)
mitmit is offline Find More Posts by mitmit
Old Nov 30, 2012, 03:02 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
http://vimeo.com/50726722
Was that the GoPro Mount>
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Nov 30, 2012, 03:36 AM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
Footage doesn't look like from a gopro.
Ab74 is offline Find More Posts by Ab74
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
