Portugal, Lisbon, Cascais
Joined Mar 2010
I think this was already discussed, but can't find it.
Is there a way to lock the roll? without locking the pan and tilt? If I disconnect the channel of the roll, the software will say disconnected but sometimes it will drift. |
Joined Dec 2010
Odd, my roll is disconnected and I dont have any drift problems. I think you only need roll connected if you want to control the roll axis. Gimbal stabilization is handled by the CAN bus connector going from the WKM to your Zenmuse. You should be able to disconnect everything but the power and CAN bus from your zenmuse and have completely stabilized video (just no zenmuse controls).
Joined Dec 2010
Does anyone know if there is a way to limit the zenmuse pitch (tilt) axis when in Orientation-locked mode? I don't want the pitch axis to rotate 360 degrees. Instead I would like to have it locked proportionally to the channel controlling it. Essentially, I want it to behave like the pan axis when in orientation-locked mode. Is this possible? I can't be the only person wanting to do this...
Joined Mar 2010
Romania, TM, Timisoara
Joined Mar 2008
Australia, SA, Renmark West
Joined Sep 2011
I haven't used the GH2, which apparently has an issue with recording and transmitting throught the Z-15 in NTSC (and I'm in a PAL area in any case) but I have used the NEX-5N and NEX-7 and both are quite straightforward to set up for video transmission.
Joined Feb 2011
I have installed new radio (mx 16 hott) for the Z15G and upgraded FW.
And now I get this behaviour. Maybe 1 of 20 tries it calibrates and work ok. Even in Assistant lights are blinking. I also tried to downgrade FW and get the same behaviour. But I have managed to set correct radio settings. Can someone help me with this issue?
| Thread Tools | |
| Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... | GGoodrum | Multirotor Talk | 7987 | Today 08:34 PM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Video Piloting (FPV/RPV) | 9 | Jul 13, 2012 10:42 PM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Wanted 3 axis gimbal on a budget =) | Vyas | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Mar 20, 2012 10:57 AM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Aerial Photography | 2 | Sep 12, 2011 06:44 PM |
