Philippines
Joined Dec 2010
Made a little cinematic touch to our aerial inspection at a construction site.
Joined Dec 2010
I am doing this with a Futaba 8FG (WKM) and T7C (Zenmuse). 1) Wire up your receiver to both WKM and Zenmuse. 2) Map all of your Zenmuse controls to a single Tx for 1 man operation. I use the Futaba 6014 14-CH receiver for this. The 6014 receiver is split, Channels 1-7 go to my WKM, channels 8-13 go to my Zenmuse. 1 spare channel left unused (can't use it anyways, no swtiches left). 3) Plug the WTR-7 into the Tx you wish to use as the student Tx (controlling the Zenmuse) and bind the Tx to it. 4) Plug the WTR-7 into your trainer Tx (WKM) and map a switch to allow student transmitter control. 5) Map Zenmuse channels to student channels using the FUNC option. Configured this way, you can have 1 pilot operation. Or you can flip the trainer switch and turn on the second transmitter and instantly add a second pilot. No reconfiguration necessary. Futaba says the WTR-7 will work up to 33 feet away, I think it will work much farther but 33 feet is plenty. I'll try and get some pictures of how I have mine set up. Quote:
DJI Manual Says: S-Bus/PPM Channels GCU Channel 1 ROLL 2 TILT 4 PAN 7 MODE 5 SHUT 8 AUX1 9 AUX2 6 AUX3 If, when using SBUS, zenmuse takes over channels 1-9 only, how would you fly? Using the method above, you can. |
Joined Dec 2010
Here is a shot of the 6014 receiver. You can see where my servo wires go back into the S800 and connect to the WKM and the rest running to the Zenmuse.
![]() ![]() I used some servo extension cables and labeled them for easy connect/disconnect of the S800 body from the landing gear. There are 6 cables to connect each time. It works, but I would rather have just 1 SBUS cable instead. ![]() Futaba wireless trainer module connected to trainer Tx via trainer port. ![]() Mapped trainer channels using the FUNC option on Trainer Tx. Here you can change mappings to your student Tx to be whatever channels you want. ![]() Trainer switch set to SB. When I flip the switch, it sends channels that I mapped to the student Tx.
| Thread Tools | |
| Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... | GGoodrum | Multirotor Talk | 8029 | Yesterday 03:12 PM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Video Piloting (FPV/RPV) | 9 | Jul 13, 2012 10:42 PM |
| Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! | tpnitro | Multirotor Talk | 120 | Jun 19, 2012 01:27 AM |
| Wanted 3 axis gimbal on a budget =) | Vyas | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Mar 20, 2012 10:57 AM |
| New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro | crd | Aerial Photography | 2 | Sep 12, 2011 06:44 PM |
