Old Nov 15, 2012, 06:14 AM
Topper_MUC is offline
Find More Posts by Topper_MUC
Germany, BY, Munich
Joined Jan 2012
Originally Posted by Iceman575 View Post
First of all they should fix the IR shutter. Not being able to switch from video to photo is bad. But not being able to even take photos is worse. Mine (and i am not the only one) does not take pictures from time to time. I have to flick that damn shutter switch 10 times for it to start working again...
But yeah they could implement a whole lot of improvements.
PS. Nice setup with the poti's on the sticks.
I'm not missing the video and/or photo IR controll as I never will take pictures with the settings I'm using for Video.
If you have issue with the IR and Sunlight you have some options.
1. Cover the area between IR LED and IR Cam sensor with a "black paper housing"
2. Move the IR unit closer over to the right and rebalance the Zenmuse roll axis by moving the backside tube.
3. unsolder the IR put cables in between and fasten it direct in front of the IR Sensor.
...and yes myself thinks as well all 3 option suck's for a 3K Euro gimbal were you expect its perfect out of the box.
Topper_MUC is offline Find More Posts by Topper_MUC
Old Nov 15, 2012, 09:57 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
the 3k gimbal is (as I see it) almost perfect.
The IR transmitter is only a "bonus" for taking pictures, and have nothing to do with the video (as I see it), and it does work
but yes in sunny light it can be blinded.
What I am more worry about is the calibration and drifting of the zen!
liteglow is offline Find More Posts by liteglow
Old Nov 15, 2012, 11:03 AM
Iceman575 is offline
Find More Posts by Iceman575
Romania, TM, Timisoara
Joined Mar 2008
I do not agree with you. I use 1/60 to 1/80 for video and that works out quite well for photo's as well. Besides i use the mount just for photos quite often and even when there is no direct sun it still doesn't work. That being sad i have a separate IR shutter that is mounted 30cm away and in the same condition that one works 95% of the time. So it is not just a sunlight problem. And switching from video to photo can be very useful sometimes. And it is something even a 15$ shutter can do... but the Zenmuse can't do it... makes no sense what so ever...
Iceman575 is offline Find More Posts by Iceman575
Old Nov 15, 2012, 11:11 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Originally Posted by flytahiti View Post
any news about the retract gear and dji new props ?
Whilst searching zenmuse vids on YT I came across this. Not DJI.
http://www.fox-jp.com/DJIS800/DJI-S800.htm
http://m.youtube.com/#/watch?v=ogGk5pNSSU0
Paul@SCC is offline Find More Posts by Paul@SCC
Old Nov 15, 2012, 03:56 PM
toberal is offline
Find More Posts by toberal
Joined Oct 2012
Originally Posted by hexa View Post
There are few features I would like for the z15.
Can Dji ad to firmware radio controls similar to standard gimbal control.
Eg.when Tilting the cam using a radio pot, the tilt stops when I stop turning the pot.
With the z15 Movement only stop when the pot turn position is in the middle
Z15 could have 2 modes one for 1 man and other for 2 man.
Radios are now being made with pot in-stick. A pilot flying and controlling his pan and tilt with a pot in-stick setup can achieve some really nice filming over a 2 man operation.
This would make it easier for one mam filming.
Also the robot movement that other members mentioned.
We should to be able slow stuff down.
Pot instick
Attachment 5304832
" What I am more worry about is the calibration and drifting of the zen! "
++1
That´s what I was asking for
toberal is offline Find More Posts by toberal
Last edited by toberal; Nov 15, 2012 at 04:03 PM. Reason: What I am more worry about is the calibration and drifting of the zen!
Old Nov 15, 2012, 10:41 PM
neavissa is offline
Find More Posts by neavissa
Pot instick
Attachment 5304832
Not sure if i understood you right, but I believe you are mistaken about the pots. They are not what they seem to be... not like the controls of a Sony playstation. They are in the inside the same as any other radio... take a look at this video:
DC-16 Transmitter Stick Switch Installation (4 min 39 sec)
G
neavissa is offline Find More Posts by neavissa
Old Nov 15, 2012, 11:11 PM
justiina is offline
Find More Posts by justiina
Suomi, JKL
Joined Apr 2011
Can someone look zenmuse dimensions?
See the picture.
justiina is offline Find More Posts by justiina
Old Nov 16, 2012, 12:02 AM
Griffo is offline
Find More Posts by Griffo
Griffo's Avatar
Australia
Joined Oct 2003
Length x Width = 115mmx156mm
Griffo is offline Find More Posts by Griffo
Old Nov 16, 2012, 02:08 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
RC Shutter, video switch, high current switch
Hi guys,
Thought you could be interested in my device that combines RC shutter, 3way RC video switch and High current switch.
Includes Low Battery warning and can be used with sum PPM.
More info here: http://www.rcgroups.com/forums/showthread.php?t=1756771
PM if interested.
Kristaps
kristaps_r is offline Find More Posts by kristaps_r
Old Nov 16, 2012, 02:36 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
http://www.youtube.com/watch?v=tBS16GRIU7o
G
Yep the pots don't work as good as the ps3 thumb sticks. When using pots to control the z15 I get very slow drifting.
Am thinking maybe the Sony psp micro thumb stick could be mod to the radio sticks
I modified the jeti radio sticks with pots. At the moment jeti don't sell the stick pots they only have switch in sticks.
I spoke to jeti firmware programmer who said he will add the pots in-stick calibration feature to the next second firmware.
Description:
Description:
hexa is offline Find More Posts by hexa
Old Nov 16, 2012, 03:30 AM
rruiz is offline
Find More Posts by rruiz
rruiz's Avatar
Joined Oct 2012
Little 2d party Cameras
Besides your Sony Nex or Panasonic ... can you share with me what second tiny camera you are using ?
Are you using it with the iOSD ??
Regards
Roberto
rruiz is offline Find More Posts by rruiz
Old Nov 16, 2012, 04:40 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
@rruiz
I am using the Horizon HD as second cam (no iOSD, but EzOsd), and a video switch to toggle between the cams.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Nov 17, 2012, 07:21 PM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
Some aerial shots @ Republ1c Wakepark, Nuvali, Philippines.
Wakeboarding @ Republ1c Wakepark, Nuvali (3 min 27 sec)
Ab74 is offline Find More Posts by Ab74
Old Nov 17, 2012, 08:40 PM
leoli0205 is offline
Find More Posts by leoli0205
JUN
United States, MD, Elkton
Joined May 2011
do you guys have any white led when you r flying !?
kinda afraid to fly....
JUN
leoli0205 is offline Find More Posts by leoli0205
Old Nov 18, 2012, 10:46 AM
liteglow is offline
Joined May 2005
JUN
Got white LED many times, never been any problem !
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
