Old Jun 28, 2012, 01:38 AM
oylore is offline
Find More Posts by oylore
Joined Nov 2009
Gimbal GCU connection
At first I just want basically the following:
1. Orientation loced Mode and FPV Mode.
2. TILT axis rotation control.
I don┤t need shutter sw.
Is it possible to simply connect only two channels from Tx to GCU? (two 3-position switches)
(I have received my Z15 and want to test it this weekend!)
oylore is offline Find More Posts by oylore
Old Jun 28, 2012, 05:54 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
Are there any test videos made with the GH2?
quadslo is offline Find More Posts by quadslo
Old Jun 29, 2012, 09:43 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Nieder÷sterr., Eggenburg
Joined Jan 2010
@oylore
Yes it is, you just connect the channels you want to have, the others will be at a "default". Today I mounted the Z15 on a carbon hexa and forgot to connect it to the receiver, works also. The cam stays in fpv-mode and the tilt-axis is always pointing at the horizon.
Zenmuse on Carbon Hexa (3 min 0 sec)
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Jun 29, 2012, 09:54 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
What's the z15 weight?
hexa is offline Find More Posts by hexa
Old Jun 29, 2012, 10:29 AM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
http://www.dji-innovations.com/produ...pecifications/
BorisSA is offline Find More Posts by BorisSA
Old Jun 29, 2012, 11:48 AM
quadslo is offline
Slovenia
Joined Feb 2011
Ferdinand, can you do one sample of fast flying arround please? Which lens do you use?
Old Jun 29, 2012, 11:51 AM
EndOfDays's Avatar
Joined Jan 2010
@quadslo
Next time at the airfield, I will try to. I am using the 16mm lens.
best regards
Ferdinand
Old Jun 29, 2012, 04:32 PM
EndOfDays's Avatar
Joined Jan 2010
Here another video of todays flights:
Z15 Videoblog: Flight with Carbon Hex (4 min 56 sec)
best regards
Ferdinand
Old Jul 01, 2012, 05:34 PM
Ab74 is offline
Find More Posts by Ab74
Philippines
Joined Dec 2010
Hello. Am I correct that I wouldn't be able to use the Z15 on a WK-M octo configuration, since it's a requirement that it will be driven from WKM's gimbal outputs?
Thanks!
Arnold
Ab74 is offline Find More Posts by Ab74
Old Jul 01, 2012, 07:43 PM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
Thanks!
Arnold
that is correct and is the reason the s800 is a hexa
chris24g is offline Find More Posts by chris24g
Old Jul 01, 2012, 11:02 PM
piccoloflyer is offline
Find More Posts by piccoloflyer
Australia, New South Wales, St Leonards
Joined Aug 2009
Not, it's not correct, Z15 connects WKM through Can-bus, it will not use any of WKM 's gimbal output.
piccoloflyer is offline Find More Posts by piccoloflyer
Old Jul 02, 2012, 12:08 AM
rsun77 is offline
Find More Posts by rsun77
Danmark, SjŠlland, G°rlev
Joined Jul 2008
The Z15 will work on a octo WKM... as said it is running on Can-bus and you control the gimbal with some more channels on your RX....
rsun77 is offline Find More Posts by rsun77
Old Jul 02, 2012, 12:14 AM
chris24g is offline
Joined Apr 2006
thanks for the correction, piccolo and rsun. i thought that's why they made the s800 as a hexa instead of octo
Old Jul 02, 2012, 01:57 AM
Ab74 is offline
Philippines
Joined Dec 2010
Thank you! I already bought a WK-M but wanted it to be on an octo config. Putting it in a DW frame. I hope this really is the end in my search for the perfect gimbal.
Old Jul 02, 2012, 03:04 AM
quadslo is offline
Slovenia
Joined Feb 2011
Which EU store do you recommend to buy Zenmuse and how long do you wait for it?
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 27, 2014 11:06 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
Discussion DJI Spread Wings S800 and Zenmuse Z15 prices are out! tpnitro Multirotor Talk 120 Jun 19, 2012 01:27 AM
Wanted 3 axis gimbal on a budget =) Vyas FPV Equipment (FS/W) 3 Mar 20, 2012 10:57 AM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd Aerial Photography 2 Sep 12, 2011 06:44 PM
