No need to feel bad scorp. I thought it looked pretty much where it needed to be too. Hmmm wonder if that would help the Arapaho.
It does run light in the front wp. Larry also pointed out the "aerolift" that the hull has. It didn't get caught on video but it did a really nice gainer with 1/2 twist when Chris and I were running together. Scared me, I thought it was going to land on his boat when it came down. |
Latest blog entry: Hobby King "SIX" hexa
Too late for that now. I've already started modding it for a wet box and strut. Just haven't shot any photos yet.
I suppose this one is about due for an update. I've been working on it, but thought I'd get it pretty much done before posting though.
None of the local hobby shops had enough tube sizes to go from big enough to small enough so I kinda winged it and built a real "wet box" inside the hull. This way the exit hole is plenty tall enough and not overly wide like it would have been with a tube anyways. Now I have to let it finish curing so I can go test it for leaks in the tub.
Bad thing is it leaked. Got a small trickle at the top rear port side (right at the nut holding the bottom of the strut). After it dries out good I'll fix that with some more epoxy and milled glass. It won't really show back there so won't even have to worry about trying to hidie it.
After getting the leak fixed moved on to other things.
Before re-installing the motor and esc wanted to offset any extra weight the box created and try to get the cg forward as zozer suggested. Just so happened that a friend had given me a 5 cell 4500 ma ni-mh rx pack, so cut an opening in the foam and installed it up front. With the addition of the stuffing box found a new way to mount the steering servo as well. With the original setup I had to install the trim tabs before putting in the shelf. This way I still have access to install them if needed after initial testing. edit: Took me a while to find it but knew there was an almost empty divers soft weight pack around here somewhere. There was just a hair over a pound of lead shot left in it so shrink tubed it to make sure it doesn't spill all over the place. Then added some velcro to the hull's keel and the tube and set it in as close to cg as I could get it. Worked out well as it now balances exactly at 10-1/2" from the transom. I think we're ready to test again next Sunday. (Since were not running on Easter. Really just as well since we're having near gale force winds this weekend).
I do have that option available. Right now the weight is being held in place with a strip of velcro.
I never did get around to weighing this one. I know it feels kinds heavy when fully loaded though. I'll have to dig out the scales again in a bit and see where it's at.
| Thread Tools | |
| Sold Titan 33 with Feigao 7L Motor | propilotguide | Boats (FS/W) | 1 | Oct 03, 2011 10:21 AM |
| For Sale * F/S: Seaducer (33") Mono electric with hacker 8xl and schulze esc * | KenSmith | Boats (FS/W) | 1 | Sep 16, 2011 04:19 PM |
| For Sale Custom Airbrushed RARE Aeromarine Mini X Deep Vee Mono Hull | hydrofreak1 | Boats (FS/W) | 2 | Feb 13, 2011 08:56 AM |
| Sold Aeromarine XXX Mono ARTR | K.R.Joye | Boats (FS/W) | 0 | Feb 04, 2008 07:21 AM |
| For Sale R/C Aeromarine Scorpion FE Offshore Mono | K.R.Joye | Boats (FS/W) | 0 | Jan 16, 2006 09:30 PM |
