Old Mar 03, 2012, 07:56 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Build Log
Aeromarine Titan 33 (P mono)
After a few years of bashing and abuse of my Delta Force 33, I decided to build myself a new P boat. The DF33 is really starting to show what stress can do over a period of time. It's had it's nose broken on a submarine that made it all the way to the bottom, the transom has started to crack along the bottom of the hull, etc, etc.
I really like the way my Aeromarine Sprintcat and Mean Machine cats handle so decided to give the Aero Titan 33 a shot. It arrived Thursday, but after having my main computer die last weekend, just finally got around to taking it out of the box for some photos this morning.
More to come later.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Mar 03, 2012, 11:16 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I like the deep vee and the lack of a ride pad, should corner very well. I'd recommend my Pursuit setup with the 4082 on 4s2p, i have not had one problem on plenty of runs now and i'm running it with a T180 which does not LVC early in 4s config.
scorpion1 is offline Find More Posts by scorpion1
Old Mar 03, 2012, 11:47 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Actually I'll be moving the Neu 1521 and CC 240 that's in my DF over to this hull instead of buying another motor/esc. I am using new hardware though. That way I can still run the DF until getting to the last portion of the build.
Got the rudder bracket and stinger base mounted already but haven't drilled the stuffing tube hole yet. Thought I'd get another opinion on height before locking it in. Right now it can be moved about 3/32" up or down from the location shown in the photo below. Once the tube goes in the height will be locked in.
In the meantime, I'll go drill the holes for the turn fin brackets.
Old Mar 03, 2012, 12:53 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I try to err on the side of it being a bit high if anthing, that position looks perfect to me, too low and it rides too high and can be squirelly.
Old Mar 03, 2012, 01:12 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks scorp. I thought it looked pretty close too but it never hurts to get a second opinion. There's a slight offset to the right (when it's right side up) in it too but the camera angle didn't show it.
Looks like it's going to be a good weekend for working on boats (or anything else that keeps you indoors) this weekend. Wind are blowing pretty steady around 20 mph here and gusting close to 30. The extreme high pollen count from the oak trees isn't doing my sinus' much good either.
Old Mar 03, 2012, 04:20 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Got all the holes punched in the transom except for trim tabs. I'm going for the "Jan seal of approval" on this one. I'll try it without them 1st then add them in if needed.
Went ahead and put in the front hatch hold down tabs as well. Now it's time to break out the sandpaper and start getting it ready for some paint.
Old Mar 03, 2012, 04:25 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Bill,
If it were my hull, I'd make the offset for the stinger a bit more, 3-4 mm.
This way you won't have to steer left, or shim the stinger to run straight.
[edit] too late...[edit]
I know how your sinus' feel, I'm on medication and light therapy from january until august due to the pollen...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Mar 03, 2012, 06:21 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Heard me talking about you didn't you?
Seems like the older I get the more the pollen bothers me. This year has been really bad due to the mild winter we've had. It's the 1st time I've used an anti allergy medication and it's not agreeing with me either. I can breathe but it doesn't let me sleep very well.
Old Mar 03, 2012, 10:31 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Hey Bill, if for some reason the Neu doesnt work out, i found this listing on ebay. Just throwin this out there as an option...............price seems fair too
http://www.ebay.com/itm/2-rc-eletric...item4cfefeebad
Old Mar 04, 2012, 05:16 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Not a bad price but it would need free shipping to get my seal of approval
Old Mar 04, 2012, 05:56 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Shot some color on the hull & hatch last night but I'm going to have to let it cure for a week or so then re-sand and repaint the top deck and hatch if I want it to look good. The sides and transom came out fine but for some reason the deck and hatch came out with what I think is called "fisheye" in the body shop world.
I really don't know what happened here. Paint was from the same can, same prep which consisted of a 400 grit wet sand followed by a soapy water wash and lacquer thinner wipe down prior to spraying. I'm just wondering if maybe the upper and lower portions are of different ages and the top needed more cure time before shooting it.
Old Mar 04, 2012, 07:11 AM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
I may be mistaken, but I believe "fisheye" is caused mainly by oil contamination of the surface that's been painted.
osprey21 is offline Find More Posts by osprey21
Old Mar 04, 2012, 08:36 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Could very well have come from your hands . Use a good degreaser and use gloves when handling the surface your going to paint
highflyerbill is offline Find More Posts by highflyerbill
Old Mar 04, 2012, 09:22 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Fisheye may not have been the correct name. It's like certain areas of the deck repelled the paint. I suppose it's possible that it could have been from some mold release agent or something trapped in the gelcoat but can't unserstand how it was still there.
When I 1st pulled the boat out of the box I gave it a good wipe down with acetone. After getting all my holes drilled, wet sanded it thorougly with 400 grit automotive grade paper. Washed it all down with soapy water and rinsed. After it dried, did the masking and then gave it another wipedown with lacquer thinner about 10 minutes before I started spraying.
The sides and transom came out just like they have in the past with good results. The deck... not so much. I can get away without doing anything on the hatch. It just has a couple of small spots that I can hide with a sticker or something. The deck I'll have to fix though.
Old Mar 04, 2012, 12:10 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Unrelated to the paint, that hatch looks like a bit of a PITA to tape down... Are you planning on running a flat sub hatch to make life easier?
wparsons is offline Find More Posts by wparsons
Sold Titan 33 with Feigao 7L Motor propilotguide Boats (FS/W) 1 Oct 03, 2011 10:21 AM
For Sale * F/S: Seaducer (33") Mono electric with hacker 8xl and schulze esc * KenSmith Boats (FS/W) 1 Sep 16, 2011 04:19 PM
For Sale Custom Airbrushed RARE Aeromarine Mini X Deep Vee Mono Hull hydrofreak1 Boats (FS/W) 2 Feb 13, 2011 08:56 AM
Sold Aeromarine XXX Mono ARTR K.R.Joye Boats (FS/W) 0 Feb 04, 2008 07:21 AM
For Sale R/C Aeromarine Scorpion FE Offshore Mono K.R.Joye Boats (FS/W) 0 Jan 16, 2006 09:30 PM
