This thread is privately moderated by sylair, who may elect to delete unwanted replies.
Old Mar 03, 2012, 02:17 AM
sylair is offline
Find More Posts by sylair
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
For Sale
16 Inch brushless Goliath EPP Wing kits
This kit has all parts needed to build and fly the Goliath except for your electronics.
The Goliath is a very stable, aerobatic and smooth flyer that is fun at all speeds, from "floater", at 25 mph, up to "screamer" at 70 (+?) mph with the kit motor. Flies easy as a much larger wing but can be flown in a small area the size of a baseball outfield or smaller. It has blurring axial rolls and unlimited vertical flight. The AUW is approximately 3.7 oz..
Easy to carry. Easy to store. Outstanding flyer.
The kit contains a brushless ELE C20, 2900kv ,19 gm CD ROM outrunner and 3 GWS 4 x 4 props for both good speed and good power. Kit is also available with 1 APC 4.1 x 4.1 prop in place of the GWS props. The kit includes a pre-attached carbon fiber bearing tube motor mount (see pic below), a prop saver plus all other parts pre-cut and ready to assemble. Very simple, strong build that can be completed and up in the air in 3 to 4 hours. The motor operates on 2 or 3 cell Lipo packs and requires a 15-20 amp ESC.
The wing cores are CNC cut high (1.9) density EPP foam for greater strength and stiffness and can withstand a lot of bad landings. 5 or 6 gm servos are recommended.
Choose a color for the covering tape.(Blu, Y, G, O, Bla, R,W, P.)
Kit Price- $39.95 (Plus S&H)
PayPal accepted
Quick shipping
Note: 5 gm servos in stock..
**************************************Sylvan Aircraft*************************************
GOLIATH KIT CONTENTS(below)
sylair is offline Find More Posts by sylair
Old Mar 05, 2012, 10:45 PM
jabbey71 is offline
Find More Posts by jabbey71
Trader Rating: 2
United States, NC, Greensboro
Joined Mar 2011
Trader Rating: 2
Hey Sylair, what is the wingspan on the wing?
jabbey71 is offline Find More Posts by jabbey71
Old Mar 06, 2012, 12:54 AM
sylair is offline
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
Jabbey,
16 inches
Art
Old Mar 06, 2012, 10:02 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
Trader Rating: 18
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Trader Rating: 18
What are the recommended battery sizes in mah?
Is it, no throttle, glide capable?
Are your 5gs better than hxt500s?
Also, it would be nice if your images were clickable for full size viewing.
They should be attached thumbnails instead of images?
IFlyRCs is offline Find More Posts by IFlyRCs
Old Mar 06, 2012, 11:23 AM
sylair is offline
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
FlyRC,
Sorry about those pics. We lost almost everything in our computer crash last year. We are using a copy from our directions sheets. The original pic was sent to us by a Goliath flyer.
You can use a 2 cell, up to 700-800 mah or a 3 cell up to around 600 mah, tops. A 3-cell 460 mah is very good weightwise.
We carry the HXT 5 gm servos, amongst others.
It will glide in nicely for landings. The AUW is best kept near or under 4 oz.
Art
Old Mar 06, 2012, 11:31 AM
sylair is offline
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
We are transferring our domain from one registrar to another. It's being updated and very close to ready.
For Sale New brushless 16 inch EPP wing kits, complete with motor,prop, etc sylair Aircraft - Electric - Airplanes (FS/W) 3 Dec 20, 2011 10:33 PM
For Sale 16 inch Goliath wing kits with 19 gm brushless motor , prop sylair Aircraft - Electric - Airplanes (FS/W) 10 Sep 29, 2010 09:49 PM
For Sale New 16 inch EPP foam brushless Goliath wing kits, outrunner, FAST+, (Complete) sylair Aircraft - Electric - Airplanes (FS/W) 1 May 08, 2010 03:23 PM
For Sale 16 Inch EPP Goliath Micro-wing Kits with 19gm out runner, props SPRING SPECIAL !!!! sylair Aircraft - Electric - Airplanes (FS/W) 6 Apr 10, 2010 03:24 PM
For Sale Goliath 16 inch EPP Wing Kit With Feigao Brushless Motor at special combo price sylair Aircraft - Electric - Airplanes (FS/W) 3 Jan 17, 2006 05:50 PM
