Old Mar 03, 2012, 01:52 AM
babanan is offline
Find More Posts by babanan
Joined Mar 2011
How to connect the Sony Nex5n to a Immersion transmitter
As the the headline says, I want to connect my Sony Nex5n to my Immersion transmitter so I can send the videosignal to the fatshark googles. How do I do that?
babanan is offline Find More Posts by babanan
Old Mar 03, 2012, 02:07 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
http://www.quadrocopter.com/HDMI-to-...VBS_p_534.html
you use a HDMI to Composite converter.
this one is about $99 off ebay and then you strip it, solder some wires to it....
or use a FPV CCD camera mounted on the camera to frame with
lots of threads here and at APLanding about it....
Adidas4275 is offline Find More Posts by Adidas4275
Old Mar 03, 2012, 02:53 AM
babanan is offline
Joined Mar 2011
Thank you so very much.
Is there also some cheaper sollutions than that?
Old Mar 03, 2012, 03:16 AM
Adidas4275's Avatar
Joined Mar 2011
$99 on eBay the same device.
Or a cheap CCD camera.
Old May 09, 2012, 03:21 PM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Exactly the same product, Ģ35 delivered:
http://www.ebay.co.uk/itm/1080P-HDMI...02893538699202
I've just received mine and it works perfectly. I'm now in the process of stripping it down
David
Hogster is offline Find More Posts by Hogster
Old May 09, 2012, 03:44 PM
Adidas4275's Avatar
Joined Mar 2011
i have the same one.... even stripped down it is a beast!
also i have found that a thin flexible cable is a must
like this
http://www.hypershop.com/HyperThin-W...able-s/192.htm
Old May 10, 2012, 01:35 AM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Wow that is a thin cable!
I bought two of these and stripped one down last night to see how light I could make it.
http://www.cinegearpro.com/hdmi-cabl...dmi-cable.html
Unfortunately when I was designing my camera mount I hadn't considered how large the mini HDMI connector would be (at that point I was still planning on using a separate FPV camera), so I was also trying to see how tightly I could bend the cable as it comes out of the mini HDMI connector. Despite my best efforts I couldn't get the radius small enough so I've had to re-think my camera tray design ...
By stripping the insulation off the cable and the thick plastic housing off the plugs, I still managed to halve the cable's weight from 18g to 9g which isn't too bad. The wires are all potted in some kind of silicon so it's still waterproof / dustproof with the plastic plug housings removed ...
I want to know where DJI got their right-angle mini HDMI ribbon cable from ... look around 2m40s:
DJI Spreading Wings S800 English closeup demo/interview (GPS stabilization) (6 min 42 sec)
That might even work with my current camera tray, but after searching for many hours the best I could find was the CineGearPro cable I linked to above ... oh well, c'est la via
Cheers
David
Old May 12, 2012, 02:16 PM
bananawhiz is offline
Find More Posts by bananawhiz
Canada, QC, Montreal
Joined Feb 2011
here is your cheapest option, only weight 40g
http://www.goodluckbuy.com/hdv-m610-...r-scaler-.html
bananawhiz is offline Find More Posts by bananawhiz
Old May 12, 2012, 03:06 PM
Adidas4275's Avatar
Joined Mar 2011
yeah that HDMI ribbon looks great..... i want 10x
Old May 12, 2012, 10:40 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
Fast question. I see that there is 1000 models of this "HDMI to Composite" and with a lot of difference in prices. What are the differences? Weight? Delay?
I'm asking because I'm in Brazil and I don't have many options here, so if I buy it here I want to know what to expect.
Reginak is offline Find More Posts by Reginak
Old Jun 02, 2012, 07:48 PM
mbsteed is offline
Find More Posts by mbsteed
Multicopter AP centric
mbsteed's Avatar
Canada, AB
Joined Jan 2011
I just ordered this one - it is cheap and light.
mbsteed is offline Find More Posts by mbsteed
Old Aug 19, 2013, 04:18 PM
mike668855 is offline
Find More Posts by mike668855
United States, WI, Milwaukee
Joined May 2013
my pick
surprised no one posted this one:
http://www.ebay.com/itm/R-C-Helicopt...item2a2f2b4ea1
http://www.goodluckbuy.com/hdmi-to-a...5cm-cable.html
mike668855 is offline Find More Posts by mike668855
Old Aug 20, 2013, 06:57 PM
dikke_tetten is offline
Find More Posts by dikke_tetten
dikke_tetten's Avatar
Belgium
Joined Jul 2013
The last one posted is the best without a doubt. It is designed for aerial photography use.
dikke_tetten is offline Find More Posts by dikke_tetten
Discussion Show us your Sony Nex5 / Nex5N videos babanan Aerial Photography 87 Aug 01, 2014 02:38 PM
Discussion Need a tip on hoe to align outrunner mounting holes to firewall hog2soar Electric Sailplanes 0 Jan 22, 2012 12:07 PM
Discussion Intervalometer for Sony Nex5n babanan Aerial Photography 2 Dec 06, 2011 04:27 AM
Discussion Sony NEX5n Live view downlink Show what works for you?? DENHAMDULAKE Aerial Photography 4 Nov 19, 2011 03:29 PM
Discussion Sony NEX5N shutter trigger modification Photoship One Aerial Photography 3 Oct 26, 2011 12:04 PM
