Old May 20, 2012, 05:08 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Originally Posted by tkeeg View Post
Just to let you all know, I now have about 20 hours or more of actual flight time on my quad while using the CC 25 amp Phoenix ESC's. I have been doing a combination of slow-steady & fast-aggressive flying and so far they are still working perfectly with my DJI WK-M controller with no anomalies.
Tom
What is your ESC setup and what motors are you using?
RC Man is offline Find More Posts by RC Man
Old May 20, 2012, 07:06 AM
ddmt is offline
Find More Posts by ddmt
Gravity sucks :)
Indonesia
Joined Jul 2005
OK I just tested my hexa, Tiger Motor MT2814 motors, APC 11x47, CC 25 with firmware 4.01 & DJI WKM (firmware 5.02). Oh wow, what a difference to the old Hobbywing flyfun 30A ESC setup. Much much less wobble, almost no wobble I would say, and it was quite windy I was tested the hexa. So much smoother and another plus, now it takes less than 5 seconds to get the full GPS signal.
ddmt is offline Find More Posts by ddmt
Old May 20, 2012, 11:36 AM
tkeeg is offline
Find More Posts by tkeeg
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
I'm using the Avroto 2814-11s motors with the Graupner 11x5 Electro props.
My ESC's are all set to the default settings with the exception of the Voltage Cutoff which is at "9v" and the Current Limiting which is set to "Disabled".
In regard to Motor Timing & PWM Rate, I tried different setting of both & did not notice much, if any, difference in performance.
Setting all of my praise of the CC firmware aside, there is ALWAYS room for even more stability & performance so I hope that CC continues to tweak their multi-rotor firmware to make it even better than it currently is!
Tom
tkeeg is offline Find More Posts by tkeeg
Old May 20, 2012, 08:34 PM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
Tom
Couldn't agree more, 1 bug that I found that really scare the hell out of me, it keeps beeping before I started the hexa and the prop move quite a bit (because of the beeping).
Oh my friend just tested my hexa, and now he wants to replace his ESCs on his hexa with CC25s too
Old May 20, 2012, 08:52 PM
tkeeg is offline
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
The beep you are hearing may be the programmable beep to let you know that there is power going to the ESC’s.
When configuring the ESC's with Castle Link, under the “Other” page there is an option called “Power-On Beep”. If that is enabled then the ESC’s will give out a tone every 30 seconds when there is power going to them when no motor is running. This is done to let you know that the power is active in case you forget to unplug the battery. I have mine set that way, but I have NEVER had a prop move by itself using the WK-M auto pilot without a command from me. I would call CC's tech support about that!
Tom
Old May 20, 2012, 09:08 PM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
Ah cool, will try to disable that option. I didn't set anything other than prop rotation and the motor timing. Thanks.
Old May 20, 2012, 09:09 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Depending on motors, it IS possible to turn the prop a bit when the esc beeps. For example MK's roxxy motors and MKBL will twitch the prop slightly.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 21, 2012, 07:17 AM
tkeeg is offline
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
Yes, all of the Mikrokopterís that I have built twitch the motors/props for second when powering up the ESCís, but I have never seen that happen on a WK-M system yet.
Old May 21, 2012, 07:36 AM
timecop is offline
Joined Dec 2010
The twitch is MKBL examining fets by switching them on/off and measuring current consumption. None of the standard ESCs do that as they would rather just explode when fets are shorted for whatever reason.
Old May 21, 2012, 07:53 AM
mmalik4 is offline
Find More Posts by mmalik4
United States, IL, Schaumburg
Joined Dec 2010
Did the Castle fixed the manual end points for throttle in the latest firmware.I am deciding to buy the phonix for my hexa but just wondering....
Also were there lot of improvements when switching from chicnese esc to phoenix
mmalik4 is offline Find More Posts by mmalik4
Old May 21, 2012, 07:56 AM
mmalik4 is offline
Joined Dec 2010
So did we achieve this with the latest firmware,the ability to use fixed end points throttle to allow to calibrate once.
Will all 6 six esc's will have similer end points......
Originally Posted by Clintstone View Post
RC
The auto-calibrate throttle has been a feature and function of the T-Birds... We have asked engineering to give us the ability to use fixed endpoint throttle to allow us to calibrate the throttle once... also we have asked to give us the multirotor function in the T-Bird line... May even be more to come on top of this ... I know they are working on some more stuff...
Old May 21, 2012, 08:54 AM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
My friend did a test flight this morning with my hexa, the weather was calm. No post stabilization, no gimbal stabilization, only cut 1:30 of 5 minutes from the raw video using sony vegas, uploading 700M is a pain with my slow internet access. The wkm is not tuned well enough, still have a lot of wobble during descend.
DJI WKM CC25 AV130 Test (1 min 31 sec)
I should take back my hexa, he flew again this afternoon and it was windy, I'll post the video soon-ish. I should take back my hexa, my friend has too much fun with it
Old May 21, 2012, 08:58 AM
ddmt is offline
Gravity sucks :)
Indonesia
Joined Jul 2005
I did this (not sure the correct way), connect each esc one at a time to ch3 of the rx (futaba). Set the lower and upper end-point of the throttle ch to +75 and -75. Turn on the tx and full stick for the throttle, connect the batt, slowly increase the upper end-point until you hear a beep (mine is around 91-92%). Then full down on the throttle stick, again slowly increase the endpoint until you hear 2 beeps (I think), mines are around 115-117%.
Old May 21, 2012, 10:26 AM
mmalik4 is offline
Joined Dec 2010
Thanks ddmt for the input here...
Also the CC Phoenix 25 does that take 600Hz PPM input
Old May 24, 2012, 05:15 PM
Ruszek83 is offline
Find More Posts by Ruszek83
Denmark, Central Denmark Region, Aarhus County
Joined Apr 2012
What settings should i use with 4.01 Firmware for DJI F450 with NAZA and standard DJI motors(920KV)... step by step please
Michael
Ruszek83 is offline Find More Posts by Ruszek83
Sold NIP Castle Creations Phoenix 25 ESC $38 phoneguy Aircraft - Electric - Power Systems (FS/W) 1 Jan 20, 2012 09:12 PM
Sold E-Flite Power 60 - Castle Creations Phoenix 80 ESC - Castle Creations 10 amp BEC moxjett Aircraft - Electric - Power Systems (FS/W) 6 Oct 18, 2011 08:49 PM
Sold Castle Creations Phoenix-25 Brushless ESC 5478Jimmy Aircraft - Electric - Power Systems (FS/W) 3 Sep 19, 2011 08:02 PM
Sold Two new Castle creations ESC's in package - Phoenix 45 and phoenix 25 GyroRon Aircraft - Electric - Power Systems (FS/W) 10 Aug 19, 2007 11:07 AM
For Sale Phoenix Castle creations ESC 25's and 35's brushless stealthy Aircraft - Electric - Power Systems (FS/W) 11 Mar 21, 2007 06:27 PM
