Old Mar 02, 2012, 07:45 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
$TREE and FFF Homebuilt FPV pusher ideas
I have been looking around a while and have found collections of FFF and $Tree Foam plans but nothing dedicated to FPV plans.
Please Post plane designs to incldue specs on electronics and flight characteristics.
Ill Post my Build designed after rctestflights Micro Drone soon... Just have to get the pics of it...
(Figured to post here since some of the FPV guys seem to only like "Buy and Fly" planes.)
chanyote66 is offline Find More Posts by chanyote66
chanyote66's Avatar
Joined Dec 2011
My Atom Drone V3
AtomRC.com
This is a fun plane, great power and FAST! (Until your wings break off... RIP ATOM DRONE V2)
These Pics are of my V1, the only difference is servo setup and a wood spar. V3 has a 1/4" wood dowel in its wing and servos for each aileron.
Specs:
Motor: 1100kv 6-10A
Prop: 8060 (works better with SF 8048)
ESC: HK 20A
Servos: 9g x 3 (V1 uses only two)
Control: T9X with ER9x Frsky firmware, Frsky telem module
Battery: 3s 1000mAh (Gives about 10 min)
Wing Span: 30"
Wing Chord: 8"
Body width: 2"
Body Length: 12"
Overall Length 25"
AUW: 300g-500g
I have flown this with dual 3s1000mAh batteries and it did fine.
Flying with a 3s 3000mAh battery was a little heavy but it flew ok still with out FPV gear.
ATOM RC - FPV Flight 8 - 1359ft UP! (2 min 26 sec)
Old Jul 03, 2012, 11:38 AM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
I've got one I'm designing at the moment that looks like yours but twice the wingspan at 1.5m (60").
Specs are (in inch as I was inspired by an American not because I am one):
Wingspan 60"
Chord 9" + 2" control surfaces
Airfoil kfm2
Length 40"
Distance between booms 15"
Designed to carry up to 800g of cargo
I have only built the wing so far as foamboard is expensive in Australia, around AU$10 for an A1 sheet (851*500mm).
I have some CAD drawings that I can post but I was meant to be asleep an hour ago so I'll get the shots later (takes ages to boot up AutoDesk).
Darcy
molond is offline Find More Posts by molond
Old Jul 05, 2012, 09:47 AM
molond is offline
molond's Avatar
Joined Oct 2011
Wingspan 60"
Airfoil kfm2
Length 40"
Darcy
Sorry for taking so long, forgot then remembered while I was shopping then forgot when I got back home (more than once)!
Here are the pics,
Darcy
**EDIT** just found a few pic of me making the wing two weeks ago, it hasn't gotten much further, maybe I put the flap servos in thats it
Old Jul 10, 2012, 01:48 PM
chanyote66's Avatar
Joined Dec 2011
wow, I totally forgot about this post....
I havent built a new drone since V4,5 and 6 failed... found out it was wing loading problems... Ill have to make a new one and test a new slower design... Im going to try to get one down to 15mph for easy flights since my larger flying wings are too fast for close proximity flying.
Old Dec 28, 2012, 12:09 AM
SubSonichobby is offline
Find More Posts by SubSonichobby
Joined Mar 2011
Just started to design my first RC plane. Any advice?
http://subsonichobby.blogspot.com/20...cdrone-v1.html
SubSonichobby is offline Find More Posts by SubSonichobby
Old Dec 28, 2012, 01:12 AM
chanyote66's Avatar
Joined Dec 2011
Its a basic drone. Yours looks good, I went with dual tail for a little more stability but I do not use rudder on it.
I sort of got away from FFF and $tree Foam and Hotwire my own wings now...
Chris
Sold Eagle Tree FPV Package! Johnny Ace FPV Equipment (FS/W) 0 Feb 26, 2012 10:59 AM
Cool New homebuilt pusher plane. flies in the street outside my house! Lestertrece Parkflyers 5 Jul 30, 2010 07:52 PM
Discussion Show Your Homebuilt FPV Planes! Flying-Monkey FPV Aircraft 38 Jul 19, 2010 04:43 PM
Discussion Dollar Tree Board or FFF in UK? electriceye Foamies (Scratchbuilt) 7 Mar 25, 2009 04:28 PM
Question WANTED!!! All FFF Landing Gear Ideas? IBbob31 3D Flying 4 Dec 18, 2003 05:56 PM
